Iio-sensor-proxy without ambient light? (gnome)
Hi,
following ArchWiki on Yoga 900 I’ve installed iio-sensor-proxy to get rotation on screen enabled. This works well, but from what I understand (and what I can see) it also activates the “ambientlight” (screen’s back-light varies according to the ambient light).
I saw a gnome webpage on the package:
https://developer.gnome.org/iio-sensor-proxy/1.0/gdbus-net.hadess.SensorProxy.html#gdbus-method-net-hadess-SensorProxy.ClaimAccelerometer
I understand there are kind of functions that activate the ambient light but to be honest I do not know how to use them.
How could I have the movement detectors activated (so that my screen display can rotate according to my laptop orientation) without activating other stuff like ambient light?
I use Manjaro Gnome 3.30.2 on a Yoga C930.
Thank you.
From this wiki page, it looks like you can use the following commands to disable the automatic adjustment of the backlight:
Disable for current user:
dbus-launch gsettings set org.gnome.settings-daemon.plugins.power ambient-enabled false
Disable for the login screen (GDM):
sudo -u gdm dbus-launch gsettings set org.gnome.settings-daemon.plugins.power ambient-enabled false
That’s perfect! Thank you.
