Ignoring a package group
Hi,
Suppose I put into /etc/pacman.conf this line:
$ IgnorePkg texlive-most
Will it suffice? Or do I have to ignore every package of the texlive-most group explicitly?
Since texlive-most is a package group, It needs to be added to IgnoreGroup. Only individual packages can be added to IgnorePkg.
IgnoreGroup = texlive-most
:warning: Disclaimer: Holding back packages can cause a partial upgrade state which is not supported. Things can and will break eventually.
Thanks! One can buy time, at least :slight_smile:
This is obviously an XY Problem. The real question is, why do you think you need to hold these packages back? That’s a discussion for a new topic, however. :wink:
TexLive updates are so destructive that I got a habit of installing TexLive from the official media only. I’ve got a 7000+ line file full of tables which builds correctly only on TexLive 2018-, for instance.
Now it’s Raspberry Pi 4 installation and I have to deal with the official repositories. At the very least, I don’t want to get disabled the day somebody else decide.
