Comment on Pamac practically unusable after latest upgrade - #25 by federation
In this case, what’s the point to have a package called Manjaro-aur-support ?
Also, pamac is not only working funny when operating with the AUR …Federation is right !
I personally have issue with the searching of packages. The result of a search get wrongly display in the side filters menu. Also the search algorithm seems to somehow changed from previous version. In fact he seems to limit the search on the specific keyword used to search, and also it won’t display all the results but a limited amount.
Also, after a number of search… sometime even after only 1 search, clicking on the search icon would not result in showing the search textbox and there will be no way to make it happened and so only closing and opening again will allow to go back to normal.
Also, and this for me it has always been, there are issues with the packages pending “left in memory”. For example… an error was generated during the installation of 5 packages for example. Then clicking on PENDING and deselecting the package and give another go, will sometimes produce the desired effect, but most of the time pamac will still consider the package as it was never been unselected.
Also, sometimes get worse and even closing the app and reopening won’t be enough to solve the issue as pamac will keep trying to install the previous section package.
This is a very limited list of the current issues I have encounter with pamac. Bauh seems to work way better and not sure why it was deleted from the “included” packages of Manjaro Distro.
I love Manjaro, but recentely it was very unstable with KDE being the most unstable on my opinion.
I notice that it is not only me thinking so, you can see on DistroWatch to have a vague idea on how people have moved to different distro and this is a pity because Manjaro has been really the boss of the distro and still has lots to give away… but something seems to be changed internally and it does not seems to be working :/.
Please made us proud and be once again the King of all !
