Good day everyone.
My exact device name is Lenovo Ideapad 5-14ALC FHD R5-5.
And as said in in the title I can not use WiFi connections.
I searched for people with the same network card and followed the solutions they had no effect.
I enable the Arch Depositories. Installed the “rtl8821ce” driver. And the kernel headers for my kernel version. Im only confused by this moment, this is my first linux usage.
inxi -Fxxxz
Outputs:
Kernel: 5.15.2-2-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm 4.16.1
vt: 7 dm: LightDM 1.30.0 Distro: Manjaro Linux base: Arch Linux
Type: Convertible System: LENOVO product: 82HU v: IdeaPad Flex 5 14ALC05
serial: <filter> Chassis: type: 31 v: IdeaPad Flex 5 14ALC05
serial: <filter>
Mobo: LENOVO model: LNVNB161216 v: SDK0J40709 WIN serial: <filter>
UEFI: LENOVO v: GJCN22WW date: 04/28/2021
ID-1: BAT0 charge: 51.3 Wh (100.0%) condition: 51.3/52.5 Wh (97.8%)
volts: 13.1 min: 11.5 model: Celxpert L19C3PD6 type: Li-poly
serial: <filter> status: Full cycles: 44
Info: 6-Core model: AMD Ryzen 5 5500U with Radeon Graphics bits: 64
type: MT MCP arch: Zen 2 rev: 1 cache: L2: 3 MiB
bogomips: 50321
Speed: 1406 MHz min/max: 1400/2100 MHz boost: enabled Core speeds (MHz):
1: 1406 2: 1470 3: 1397 4: 1397 5: 1750 6: 1428 7: 1397 8: 1567 9: 1397
10: 1397 11: 1396 12: 1397
Device-1: AMD Lucienne vendor: Lenovo driver: amdgpu v: kernel
bus-ID: 04:00.0 chip-ID: 1002:164c class-ID: 0300
Device-2: Acer Integrated Camera type: USB driver: uvcvideo bus-ID: 1-4:3
chip-ID: 5986:212a class-ID: 0e02
Display: x11 server: X.Org 1.21.1.1 compositor: xfwm4 v: 4.16.1 driver:
loaded: amdgpu,ati unloaded: modesetting alternate: fbdev,vesa
resolution: 1920x1080~60Hz s-dpi: 96
OpenGL: renderer: AMD RENOIR (DRM 3.42.0 5.15.2-2-MANJARO LLVM 13.0.0)
v: 4.6 Mesa 21.2.5 direct render: Yes
Device-1: AMD driver: snd_hda_intel v: kernel bus-ID: 04:00.1
chip-ID: 1002:1637 class-ID: 0403
Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor
vendor: Lenovo driver: N/A bus-ID: 04:00.5 chip-ID: 1022:15e2
class-ID: 0480
Device-3: AMD Family 17h HD Audio vendor: Lenovo driver: snd_hda_intel
v: kernel bus-ID: 04:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.15.2-2-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.40 running: yes
Device-1: Realtek vendor: Lenovo driver: N/A port: 2000 bus-ID: 02:00.0
chip-ID: 10ec:8852 class-ID: 0280
IF-ID-1: enp4s0f4u2 state: unknown speed: -1 duplex: half mac: <filter>
Device-1: OnePlus (Shenzhen) OnePlus type: USB driver: rndis_host
v: kernel bus-ID: 3-2:5 chip-ID: 2a70:f00e class-ID: 0a00 serial: <filter>
Device-2: Realtek Bluetooth Radio type: USB driver: btusb v: 0.8
bus-ID: 3-4:4 chip-ID: 0bda:4852 class-ID: e001 serial: <filter>
Report: ID: hci0 rfk-id: 2 state: down bt-service: enabled,running
rfk-block: hardware: no software: yes address: N/A
Local Storage: total: 476.94 GiB used: 9.44 GiB (2.0%)
ID-1: /dev/nvme0n1 vendor: Micron model: MTFDHBA512QFD size: 476.94 GiB
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 0011P6LN
temp: 37.9 C scheme: GPT
ID-1: / size: 468.09 GiB used: 9.44 GiB (2.0%) fs: ext4
dev: /dev/nvme0n1p2
ID-2: /boot/efi size: 299.4 MiB used: 288 KiB (0.1%) fs: vfat
dev: /dev/nvme0n1p1
System Temperatures: cpu: 47.0 C mobo: 43.0 C gpu: amdgpu temp: 44.0 C
Processes: 299 Uptime: 2m wakeups: 5 Memory: 15.06 GiB
used: 1.47 GiB (9.8%) Init: systemd v: 249 Compilers: gcc: 11.1.0
Packages: pacman: 1094 Shell: Bash v: 5.1.8 running-in: xfce4-terminal
inxi: 3.3.08
