Hello today, after another icon change, I ran into such a problem, but the link to the screen Icons problem - Album on Imgur changing icons to others does not help, restarting the system does not help
Hello, and sorry, but the issue is not very obvious, so maybe you get more specific?
The icons in the folder on the launch pad used to be larger, but now they have decreased
From a developer at Gnome
Maybe that is the case, so not the icon theme.
Care to share your resolution so i can dig deeper about this?
I think they are working on this issue, hence establish the correct sizes
