AlanP
22 July 2021 11:36
1
Hi everybody,
I use the WhiteSur theme for icons but I’ve got a problem. The icons for the mounted volumes and devices displayed on the dock are not good. I’ve a white icon with a wheel and not a removable drive. Do you think that the problem come from Dash-to-dock or from the icons theme ?
Thanks.
Note: Gnome 40 with the last Dash-to-dock extension from Manjaro.
Hello,
If i recall correctly, the code had a slight change so it doesn’t happen this
opened 09:20PM - 25 May 20 UTC
Hey,
First of all, thanks for your amazing work. Dash to Dock is one of the g… ems among GNOME Extensions.
Now, onto the bug report... On Wayland, when Dash to Dock is setup to show mounted drives and a drive is plugged in at login, then the dock is empty or shows only the application grid button, like [this](https://i.imgur.com/YlcMbY7.png).
More specifically, here's how I reproduce the bug:
-disable all extensions but Dash to Dock, so as not to misattribute the issue
-make sure "show mounted drives" is toggled on in the extension's settings
-plug a removable drive
-reboot (just logging out and back in may not be enough), and log in to a Wayland session. Xorg is unaffected.
-the dock is empty, as well as the application grid.
The bug goes away after a minute or so; in the meantime however, I need to search an application by name or run a command to do anything.
System information:
* Dash to Dock v68
* Gnome Shell v3.36.2
* Ubuntu 20.04, up-to-date. I'm on a vanilla GNOME session, not the default Ubuntu session, so Ubuntu extensions and in particular Ubuntu's fork of Dash to Dock are disabled.
* Single monitor
* Display protocol: Wayland
* Intel integrated graphics with default drivers
Extension settings:
apply-custom-theme=false
autohide=false
click-action='previews'
custom-theme-shrink=true
dock-fixed=false
dock-position='LEFT'
intellihide-mode='ALL_WINDOWS'
running-indicator-style='DOTS'
show-apps-at-top=true
show-mounts=false
show-show-apps-button=true
And here's the [output of `journalctl /usr/bin/gnome-shell | grep dash-to-dock`](https://pastebin.com/YuwVQBi3).
Thanks in advance for having a look!
You can follow what is done so far, to properly port it to Gnome 40
micheleg:master
← ewlsh:ewlsh/gnome-40
opened 05:17PM - 28 Mar 21 UTC
~~This only achieves "bare minimum" functionality.~~
~~Settings aren't all te… sted (the Unity style stuff is probably broken, for example), the settings UI needs fixing, and it is _very much_ WIP.~~
~~The most basic functionality is usable though - and I'll be adding to this branch (though other contributors' work is welcome)~~
We're approaching _initial_ release quality :partying_face:
Known issues:
- [X] Windows glitch when returning from overview without autohide
- [X] Overview workspaces are the wrong size
- [X] Top mode is quite broken (~~I'm considering disabling it for now as other extensions support the "top" experience better~~ UPDATE: It is mainly only broken in shrink mode now)
- [ ] Fullscreen autohide is glitchy (haven't had a chance to debug it, I don't consider it a blocking feature)
- [ ] Custom background colors can't have custom opacities (this impacts pretty much all the settings at the intersection of opacity/background colors)
- [x] Dynamic icon sizing isn't working correctly
- [ ] Investigate dynamic icon sizing's impact on the overview, see if multiple dimensions are possible and decide if the desktop dock should instead be constrained to the overview dimensions by default :thinking:
- [ ] Trash and volume icons aren't sorted correctly with drag-n-drop, etc.
- [x] Trash has incorrect menu
- [x] Padding for bottom panel on left/right needs to be added w/ shrink disabled.
- [x] Workspace previews are `2:1` :thinking:
- [ ] Startup issue with file-manager applications (marking proper app as running)
- [ ] z-alignment on dash appicons labels
- [ ] Dnd of favorites in left mode
- [ ] Open locations from nautilus
- [ ] Too many dots on many windows
- [ ] Check monitors vertical arrangement
- [ ] Ensure windows minimize to the right spot
- [ ] Check padding when showing show-apps at beginning
(will update as issues get fixed or found)
Known trade-offs:
- [x] Animations out of the applications view are a bit janky, 40 doesn't provide a simple way to fully exit the overview from the app view. (the context is slightly more complicated, it also involves the show app button state and how it is managed)
AlanP
1 August 2021 11:01
3
@bogdancovaciu : I made a bug report in the github of Dash-to-dock website
