Would anyone know if it is possible to increase or decrease the spacing between icons in the KDE Plasma panel? I have looked at all the settings and searched the web, and the only thing I’ve found relates to the icon spacing in the “system area” of the panel, but not on the panel itself, as shown on the image below.
Sorry, misunderstood. You mean open a config file with nano or other editor and edit it. I’m using Breeze, I try not to stray too far off Plasma’s defaults.
Not sure what to modify, now I think about it, it may be the ‘task manager’ that would need modification. But I was not talking about a configuration file, but modifying the code of the style/plasmoid.
I think it would be in there /usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/
I tried the latte dock and wasn’t crazy about it. I guess I’ll live with the excessive default spacing in Plasma’s own panel, not the worse thing in the world. Thanks a lot, fellas.
Whaddaya know!!! It was at “48”, next tick down was “32”, and while the actual icon size did not change, the spacing between icons was reduced considerably, exactly as I wanted. Son of a gun!
Thanks, Jabber!!
