Icon on dock for Sublime Text on Manjaro 21.2.4
bug report and fix
Manjaro 21.2.4
i notice that Sublime Text on dock appear as “unknown” where every where appears ok. taken the config file of Sublime Merge i found and fixed the bug.
the file /usr/share/applications/sublime_text.png, Exec entry is just “subl”, and changed to the complete executable location fixed the bug
:wink:
Great!
Now you just need to report that to the proper upstream place because there isn’t even a Manjaro package for sublime text…
oh! sorry, this is my 2nd post on forums :grimacing:
could you point me where i should report?
Did you get sublime text from the AUR?
https://aur.archlinux.org/packages?K=sublime-text
If so - contact the maintainer of the package you installed.
thanks! commented there!
