Ibus not getting installed properly Manjaro Gnome 16.06.1
I have been trying to install ibus for my local language support. (ibus-avro-git)
The package might seem old but it used to work with manjaro 15.12 XFCE version.
Recently I installed manjaro gnome 16.06.1 from scratch.
Now when I am installing ibus this error pops out.
sudo pacman -S ibus
[sudo] password for user:
resolving dependencies...
Packages (1) ibus-1.5.13-2
Total Installed Size:  6.29 MiB
:: Proceed with installation? [Y/n] y
(1/1) checking keys in keyring                     [######################] 100%
(1/1) checking package integrity                   [######################] 100%
(1/1) loading package files                        [######################] 100%
(1/1) checking for file conflicts                  [######################] 100%
(1/1) checking available disk space                [######################] 100%
(1/1) installing ibus                              [######################] 100%
(1/6) Compiling GSettings XML schema files...
No such key 'documen-font-name' in schema 'org.gnome.desktop.interface' as specified in override file '/usr/share/glib-2.0/schemas/99_manjaro-settings.gschema.override'; ignoring override for this key.
No such key 'scroll-method' in schema 'org.gnome.desktop.peripherals.touchpad' as specified in override file '/usr/share/glib-2.0/schemas/99_manjaro-settings.gschema.override'; ignoring override for this key.
(2/6) Probing GTK2 input method modules...
(3/6) Probing GTK3 input method modules...
(4/6) Updating icon theme caches...
(5/6) Updating manpage index...
(6/6) Updating the desktop file MIME type cache...
I also looked in the /usr/share/glib-2.0/schemas/99_manjaro-settings.gschema.override file:
[org.gnome.desktop.background]
picture-uri='file:///usr/share/backgrounds/black_leather_manjaro_linux_by_tefrem34.jpg'
show-desktop-icons=false
[org.gnome.desktop.interface]
cursor-theme='Simple-and-Soft'
documen-font-name='Sans 10'
enable-animations=true
font-name='Cantarell 10'
gtk-im-module='gtk-im-context-simple'
gtk-theme='Vertex-Maia-Dark'
icon-theme='Vertex-Maia'
monospace-font-name='Monospace 10'
[org.gnome.desktop.wm.preferences]
titlebar-uses-system-font=false
button-layout='appmenu:minimize,maximize,close'
[org.gnome.shell]
always-show-log-out=true
favorite-apps=['pamac-manager.desktop', 'firefox.desktop', 'empathy.desktop', 'org.gnome.Nautilus.desktop', 'gnome-terminal.desktop', 'org.gnome.gedit.desktop', 'hexchat.desktop', 'org.gnome.Screenshot.desktop', 'ca.desrt.dconf-editor.desktop']
enabled-extensions=['dash-to-dock@micxgx.gmail.com', 'gnomenu@panacier.gmail.com', 'mediaplayer@patapon.info', 'openweather-extension@jenslody.de', 'drive-menu@gnome-shell-extensions.gcampax.github.com', 'user-theme@gnome-shell-extensions.gcampax.github.com']
[org.gnome.shell.extensions.user-theme]
name="Vertex-Maia"
[org.gnome.nautilus.icon-view]
default-zoom-level='small'
[org.gnome.desktop.peripherals.touchpad]
natural-scroll=false
scroll-method='two-finger-scrolling'
tap-to-click=true
[org.gnome.shell.extensions.dash-to-dock]
background-opacity=0.90000000000000002220
custom-theme-running-dots=true
dash-max-icon-size=32
cursor-theme='Simple-and-Soft’
documen-font-name=‘Sans 10’
Looks like a typo. Should be “document”.
As you can see here:
"scroll-method" seems to be deprecated. Two finger scroll-method is default, so you probably just ignore it.
:sweat: ops tank you to point me to typo error
Well now the documen-font-name error is gone but now I have this weird problem. I am installing ibus-avro-git which is used for Bengali language input but I am getting Arabic. :neutral_face:
I don’t use ibus, so I can only guess. Have you set your locale? See archwiki
https://wiki.archlinux.org/index.php/IBus#GNOME
Yes I have looked there.
Doesn’t seem to solve the issue. :sweat:
And now I have discovered that when I choose Input source (ibus-avro) the layout is of another language(Malay).
same here ... even the avro bangla entry is not shown in the Language preference.
This is June 16 2020 and I'm using the latest Manjaro KDE. Avro is working. Even Bijoy (unijoy) is working. Some people prefer openbangla-keyboard instead of avro.
