I915 - Error Aromic update failure on pipe A
#1
Hey!
I am having following error (from dmesg):
[drm:intel_pipe_update_end [i915]] *ERROR* Atomic update failure on pipe A
Unfortunately, I cannot post output from inxi, since whenever I open web-browser system freezes. This error occurs on HP Envy 13 (2018), so probably something related to Intel graphics (i5-8250) and nvidia (GTX 150MX).
Sorry about vague description, I will be to happy post more details and hear your feedback!
#2
can you try this ?
#3
  1. cant do, because I dont have intel.conf
sudo cp /etc/X11/mhwd.d/intel.conf /etc/X11/mhwd.d/intel.conf.old
  1. Does not look like related issue
#4
Any other ideas? Problem does not go anywhere…
#5
I also have the same problem and I am trying to isolate its outcome. In my setup I have i7-8650H and GTX1060. It looks like whenever I see such kernel error, after several sleeps and wake-ups my laptops will freeze. Have you experienced the same issue?
#6
I think it is close to what I am experiencing, the outcome is definitely the same. In my case freeze could be caused by web-browser, or by connecting second display or just randomly after couples of hours programming.
#7
In the end I switch the windows manager to use intel integraded card and only use Nvidia with CUDA applications. The error atomic update warning is still there, but my laptop freezes no more.
closed #8
