I recently switched from Manjaro XFCE to Manjaro i3.
I chose to replace i3status with i3status-rust for easier configuration.
On Manjaro XFCE I really liked to use multiload-ng, can this software be used on Majaro i3 in any way?
Are you talking about this package?
https://aur.archlinux.org/packages/multiload-ng-common
Install it and launch it and see it is visible in the system tray or not. If it is then you can add this line in your i3 config to start it automatically on each login:
exec --no-startup-id multiload-ng-common
I installed multiload-ng-common but cannot launch it.
I installed the standalone version and it works on it’s own windows but I want to put it on the status bar like I used to on XFCE.
