Hi, I hope this is the correct section, here’s what happened:
fresh install of Manjaro with the i3 iso version and I notitced that the i3status bar displayed the wrong time.
I tried to change it but no luck the issue tho is that the status bar now is not showing and I cant get back to the original config file because I overwrote the one in /etc.
Can someone give me the default i3status config file for Manjaro?
Here’s the one I have now which is not working:
# i3status configuration file.
# see "man i3status" for documentation.
# It is important that this file is edited as UTF-8.
# The following line should contain a sharp s:
# ß
# If the above line is not correctly displayed, fix your editor first!
general {
colors = true
interval = 5
color_good = "#2AA198"
color_bad = "#586E75"
color_degraded = "#DC322F"
# order += "ipv6"
order += "cpu_usage"
order += "disk /"
# order += "disk /home"
order += "wireless _first_"
order += "ethernet _first_"
order += "battery all"
# order += "load"
order += "memory"
order += "tztime local"
cpu_usage {
format = " cpu %usage "
load { format = " load %1min " # max_threshold = 0.3 } disk "/" { # format = " hdd %avail " format = " ⛁ %avail " } ethernet _first_ { # if you use %speed, i3status requires root privileges format_up = " lan: %ip %speed " format_down = " no lan " } battery all {
# format = "%status %percentage %remaining %emptytime"
format = " %status %percentage"
format_down = "No battery"
last_full_capacity = true
integer_battery_capacity = true
# status_chr = ""
status_chr = "⚡"
# status_bat = "bat"
# status_bat = "☉"
status_bat = ""
# status_unk = "?"
status_unk = ""
# status_full = ""
status_full = "☻"
low_threshold = 15
threshold_type = time
memory {
format = "%used | %available"
threshold_degraded = "1G"
format_degraded = "MEMORY < %available"
tztime local {
# format = "%Y-%m-%d %H:%M:%S"
format = "%d.%m. %H:%M"
In the cache there is the whole package i3status.
Which contains the config file.
If you have it in cache, just open it and look inside.
If you don’t have it - which is not the case, since you just said you reinstalled it - you can just download it again: sudo pacman -Sw i3status
This will just fetch the whole package again and put it in the cache folder /var/cache/pacman/pkg
Also, if you reinstalled, as you said
the config file will not be magically overwritten - since you edited it.
In that case, the file will be put alongside your edited version - just with a .pacnew extension (or some other extension, I haven’t tested this)
The file is there - either in the package itself or in your /etc directory with some extension, to distinguish it from the file that you have worked on.
here is the easy way - this is the content of the original file:
# ß
general {
colors = true
interval = 5
order += "ipv6"
order += "disk /"
order += "load"
order += "memory"
wireless _first_ {
format_up = "W: (%quality at %essid) %ip"
format_down = "W: down"
ethernet _first_ {
format_up = "E: %ip (%speed)"
format_down = "E: down"
battery all {
format = "%status %percentage %remaining"
disk "/" {
format = "%avail"
load {
format = "%1min"
memory {
tztime local {
and this is what you likely intended to do
(I put in separators #-------
to make it more clear):
# ß
general {
colors = true
interval = 5
# order += "ipv6"
order += "disk /"
# order += "load"
order += "memory"
cpu_usage {
load {
disk "/" {
# format = " ⛁ %avail "
ethernet _first_ {
battery all {
# status_chr = ""
status_chr = "⚡"
# status_bat = "☉"
status_bat = ""
# status_unk = "?"
status_unk = ""
# status_full = ""
status_full = "☻"
low_threshold = 15
memory {
tztime local {
