Calibre Qt WebEngine Render process crashed after run ebook-edit
these is the result when i try to run caliber-ebook-edit or viewer from terminal
>ebook-edit         INT ✘
The Qt WebEngine Render process crashed with termination type: 2 and exit code: 159
Restarting Qt WebEngine
The Qt WebEngine Render process crashed too often
qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 818, resource id: 11816507, major code: 40 (TranslateCoords), minor code: 0
this is the output of inxi command:
`System:
  Kernel: 5.17.0-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-5.17-x86_64
    root=UUID=f13b6869-6236-4de6-bbad-73b48f94195b rw rootflags=subvol=@ quiet
    udev.log_priority=3
  Desktop: Xfce v: 4.16.0 tk: Gtk v: 3.24.29 info: xfce4-panel wm: xfwm
    v: 4.16.1 vt: 7 dm: LightDM v: 1.30.0 Distro: Manjaro Linux base: Arch Linux
  Type: Desktop Mobo: ECS model: H61H2-MV v: 1.0 serial: <superuser required>
    BIOS: American Megatrends v: 4.6.5 date: 10/12/2012
  RAM: total: 5.65 GiB used: 2.7 GiB (47.8%)
  RAM Report:
  Info: model: Intel Core i3-3210 bits: 64 type: MT MCP arch: Ivy Bridge
    family: 6 model-id: 0x3A (58) stepping: 9 microcode: 0x21
    L3: 3 MiB desc: 1x3 MiB
  Speed (MHz): avg: 1596 high: 1597 min/max: 1600/3200 scaling:
    driver: intel_cpufreq governor: schedutil cores: 1: 1596 2: 1597 3: 1596
    4: 1596 bogomips: 25549
  Flags: acpi aperfmperf apic arat arch_perfmon avx bts clflush cmov
    constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept
    erms est f16c flexpriority flush_l1d fpu fsgsbase fxsr ht ibpb ibrs
    lahf_lm lm mca mce md_clear mmx monitor msr mtrr nonstop_tsc nopl nx pae
    pat pbe pcid pclmulqdq pdcm pebs pge pln pni popcnt pse pse36 pti pts
    rdtscp rep_good sep smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
    syscall tm tm2 tpr_shadow tsc tsc_deadline_timer vme vmx vnmi vpid xsave
    xsaveopt xtopology xtpr
  Type: l1tf
  Device-1: Intel Xeon E3-1200 v2/3rd Gen Core processor Graphics
    vendor: Elite Systems driver: i915 v: kernel ports: active: VGA-1
    empty: none bus-ID: 00:02.0 chip-ID: 8086:0152 class-ID: 0300
  Display: x11 server: X.Org v: 1.21.1.3 compositor: xfwm v: 4.16.1 driver:
    X: loaded: vesa gpu: i915 display-ID: :0.0 screens: 1
  Screen-1: 0 s-res: 1368x768 s-dpi: 84 s-size: 414x232mm (16.30x9.13")
    s-diag: 475mm (18.68") monitors: <missing: xrandr>
  Monitor-1: VGA-1 model: BenQ G922HDAL serial: <filter> built: 2011
    res: 1366x768 dpi: 85 gamma: 1.2 size: 410x230mm (16.14x9.06")
    diag: 470mm (18.5") ratio: 16:9 modes: max: 1366x768 min: 720x400
  Message: Unable to show GL data. Required tool glxinfo missing.
    vendor: Elite Systems driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
    chip-ID: 8086:1c20 class-ID: 0403
  Sound Server-1: ALSA v: k5.17.0-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.48 running: no
  Device-1: Realtek RTL810xE PCI Express Fast Ethernet vendor: Elite Systems
    driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e000
    bus-ID: 02:00.0 chip-ID: 10ec:8136 class-ID: 0200
  IF: enp2s0 state: up speed: 100 Mbps duplex: full mac: <filter>
    driver: btusb v: 0.8 bus-ID: 1-1.4:4 chip-ID: 0a12:0001 class-ID: e001
  Local Storage: total: 465.76 GiB used: 25.42 GiB (5.5%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Toshiba model: DT01ACA050
    size: 465.76 GiB block-size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s
    type: HDD rpm: 7200 serial: <filter> rev: A750 scheme: MBR
  ID-1: / raw-size: 200.42 GiB size: 200.42 GiB (100.00%)
    used: 25.42 GiB (12.7%) fs: btrfs dev: /dev/sda3 maj-min: 8:3 label: N/A
    uuid: f13b6869-6236-4de6-bbad-73b48f94195b
  ID-2: /home raw-size: 200.42 GiB size: 200.42 GiB (100.00%)
  ID-3: /var/cache raw-size: 200.42 GiB size: 200.42 GiB (100.00%)
  ID-4: /var/log raw-size: 200.42 GiB size: 200.42 GiB (100.00%)
  ID-1: /dev/sda1 maj-min: 8:1 size: 265.29 GiB fs: ntfs label: N/A
    uuid: 4E7C5D60346681C2
  ID-2: /dev/sda2 maj-min: 8:2 size: 50 MiB fs: ntfs
    label: R\xc3\xa9serv\xc3\xa9 au syst\xc3\xa8me uuid: B4389C54389C1786
  Hub-1: 1-0:1 info: Full speed or root hub ports: 2 rev: 2.0 speed: 480 Mb/s
  Hub-2: 1-1:2 info: Intel Integrated Rate Matching Hub ports: 4 rev: 2.0
    speed: 480 Mb/s chip-ID: 8087:0024 class-ID: 0900
  Device-1: 1-1.3:3 info: Primax HP PR1101U / PMX-KPR1101U Keyboard
    type: Keyboard,HID driver: hid-generic,usbhid interfaces: 2 rev: 1.1
    speed: 1.5 Mb/s power: 100mA chip-ID: 0461:0010 class-ID: 0300
  Device-2: 1-1.4:4
    info: Cambridge Silicon Radio Bluetooth Dongle (HCI mode) type: Bluetooth
    driver: btusb interfaces: 2 rev: 1.1 speed: 12 Mb/s power: 100mA
  Hub-3: 2-0:1 info: Full speed or root hub ports: 2 rev: 2.0
  Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0
  Device-1: 2-1.6:3 info: [Maxxter] Optical Gaming Mouse [Xtrem]
    type: Mouse,Keyboard driver: hid-generic,usbhid interfaces: 2 rev: 1.1
    speed: 1.5 Mb/s power: 100mA chip-ID: 18f8:0f97 class-ID: 0301
  System Temperatures: cpu: 29.8 C mobo: 27.8 C
  Processes: 207 Uptime: 7m wakeups: 0 Init: systemd v: 250 tool: systemctl
  Compilers: gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1194 lib: 344
  Shell: Zsh v: 5.8.1 running-in: tilix inxi: 3.3.14
Welcome to Manjaro! :smiling_face_with_three_hearts:
  1. Please read the information behind this link. It will help you to post necessary information. [HowTo] Provide System Information
  2. Please press the three dots below your post and then press the :pencil2:
  • If you give us information about your system, we can see what we’re talking about and make better suggestions.
  • You can do this by using inxi in a terminal or in console.
  • Personally identifiable information such as serial numbers and MAC addresses are filtered out by this command
  • Presenting the information in this way allows everyone to be familiar with the format and quickly find the items they need without missing anything.
  1. Copy the output from inxi (including the command) and paste it into your post.
  • To make it more readable, add 3 backticks ``` on an extra line before and after the pasted text.
Hi @the_beast48 ,
Please, consider to read the following post.
I cant install calibre - #6 by archisman
Maybe, you could run the terminal command suggested at the end of this post.
I wonder whether you have checked that the dependencies needed for the installation are present in your system:
calibre - Download for Linux
Regards,
