[i3-wm] Theme Collection
#29
Hey man, that’s actually really really odd.
If you could please check your current ~/.i3/config, ~/.Xresources, ~/.extend.Xresources and lastly ~/.config/polybar/config and paste-bin them if you could so I can take a look on them.
#30
It’s been almost a year since this project started, so today I fully reworked everything on the project. See here for more Information:
#31
Hi,
Please help me, newbie here (arch base linux)
[linus@ASUS-550kl i3wm-themer]$ sudo pip install -r requirements.txt
sudo: pip: command not found
[linus@ASUS-550kl i3wm-themer]$ sudo pacman -Ss pip
core/libpipeline 1.5.0-1 [installed]
    a C library for manipulating pipelines of subprocesses in a flexible and convenient way
extra/epiphany 3.28.1-1 (gnome)
    A GNOME web browser based on the WebKit rendering engine
extra/gnu-netcat 0.7.1-6
    GNU rewrite of netcat, the network piping application
extra/pipewire 0.1.9-1
    Server and user space API to deal with multimedia pipelines
extra/python-pip 9.0.1-3
    The PyPA recommended tool for installing Python packages
extra/python2-pip 9.0.1-3
community/aeolus 0.9.5-3
    Synthesised pipe organ emulator
community/haskell-pipes 4.3.9-2
    Compositional pipelines
community/haskell-pipes-http 1.0.5-120
    HTTP client with pipes interface
community/lesspipe 1.83-1
    an input filter for the pager less
community/obmenu-generator 0.84-1
    A fast pipe/static menu generator for the Openbox Window Manager (with icons support).
community/percol 0.2.1-2
    Adds flavor of interactive filtering to the traditional pipe concept of UNIX shell
community/perl-io-pipely 0.005-2
    Portably create pipe() or pipe-like handles, one way or another.
community/perl-ipc-run 0.99-1
    IPC::Run - system() and background procs w/ piping, redirs, ptys
community/pipesocks 2.3-2
    A pipe-like SOCKS5 tunnel system
community/pv 1.6.6-1
    A terminal-based tool for monitoring the progress of data through a pipeline.
community/python-apipkg 1.4-3
    Namespace control and lazy-import mechanism
community/python-pipenv 11.10.0-1
    Sacred Marriage of Pipfile, Pip, & Virtualenv.
community/python2-apipkg 1.4-3
community/python2-pipenv 11.10.0-1
community/sugar-activity-pippy 71-1 (sugar-fructose)
    Sugar activity to learn and develop in Python programming language
Collecting pyyaml==3.12 (from -r requirements.txt (line 1))
  Downloading PyYAML-3.12.tar.gz (253kB)
    100% |β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ| 256kB 296kB/s
Installing collected packages: pyyaml
  Running setup.py install for pyyaml ... done
Successfully installed pyyaml-3.12
You are using pip version 9.0.1, however version 10.0.0 is available.
You should consider upgrading via the 'pip install --upgrade pip' command.
[linus@ASUS-550kl i3wm-themer]$ pip install --upgrade pip
Collecting pip
  Downloading pip-10.0.0-py2.py3-none-any.whl (1.3MB)
    100% |β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ| 1.3MB 175kB/s
Installing collected packages: pip
  Found existing installation: pip 9.0.1
    Uninstalling pip-9.0.1:
Exception:
  File "/usr/lib/python3.6/shutil.py", line 544, in move
    os.rename(src, real_dst)
OSError: [Errno 18] Invalid cross-device link: '/usr/bin/pip' -> '/tmp/pip-wepxalx0-uninstall/usr/bin/pip'
During handling of the above exception, another exception occurred:
  File "/usr/lib/python3.6/site-packages/pip/basecommand.py", line 215, in main
    status = self.run(options, args)
  File "/usr/lib/python3.6/site-packages/pip/commands/install.py", line 342, in run
    prefix=options.prefix_path,
  File "/usr/lib/python3.6/site-packages/pip/req/req_set.py", line 778, in install
    requirement.uninstall(auto_confirm=True)
  File "/usr/lib/python3.6/site-packages/pip/req/req_install.py", line 754, in uninstall
    paths_to_remove.remove(auto_confirm)
  File "/usr/lib/python3.6/site-packages/pip/req/req_uninstall.py", line 115, in remove
    renames(path, new_path)
  File "/usr/lib/python3.6/site-packages/pip/utils/__init__.py", line 267, in renames
    shutil.move(old, new)
  File "/usr/lib/python3.6/shutil.py", line 559, in move
    os.unlink(src)
PermissionError: [Errno 13] Permission denied: '/usr/bin/pip'
[linus@ASUS-550kl i3wm-themer]$ sudo pip install --upgrade pip
Collecting pip
    100% |β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ| 1.3MB 172kB/s
      Successfully uninstalled pip-9.0.1
Successfully installed pip-10.0.0
[linus@ASUS-550kl i3wm-themer]$ ./install_requirements_arch.sh
:: Some packages should be upgraded first...
resolving dependencies...
Packages (1) archlinux-keyring-20180404-1
Total Download Size:    0.65 MiB
Total Installed Size:   0.90 MiB
Net Upgrade Size:      -0.01 MiB
:: Proceed with installation? [Y/n] y
:: Retrieving packages...
 archlinux-keyring-20180404-1-any                                 668.2 KiB   124K/s 00:05 [#####################################################] 100%
(1/1) checking keys in keyring                                                             [#####################################################] 100%
(1/1) checking package integrity                                                           [#####################################################] 100%
(1/1) loading package files        [#####################################################] 100%
(1/1) checking for file conflicts                                                          [#####################################################] 100%
(1/1) checking available disk space                                                        [#####################################################] 100%
(1/1) upgrading archlinux-keyring                                                          [#####################################################] 100%
==> Appending keys from archlinux.gpg...
==> Locally signing trusted keys in keyring...
  -> Locally signing key DDB867B92AA789C165EEFA799B729B06A680C281...
  -> Locally signing key 684148BB25B49E986A4944C55184252D824B18E8...
  -> Locally signing key 91FFE0700E80619CEB73235CA88E23E377514E00...
  -> Locally signing key AB19265E5D7D20687D303246BA1DFB64FFF979E7...
  -> Locally signing key 0E8B644079F599DFC1DDC3973348882F6AC6A4C2...
==> Importing owner trust values...
==> Disabling revoked keys in keyring...
  -> Disabling key 7FA647CD89891DEDC060287BB9113D1ED21E1A55...
  -> Disabling key D4DE5ABDE2A7287644EAC7E36D1A9E70E19DAA50...
  -> Disabling key 40440DC037C05620984379A6761FAD69BA06C6A9...
  -> Disabling key B1F2C889CB2CCB2ADA36D963097D629E437520BD...
  -> Disabling key BC1FBE4D2826A0B51E47ED62E2539214C6C11350...
  -> Disabling key 63F395DE2D6398BBE458F281F2DBB4931985A992...
  -> Disabling key 8F76BEEA0289F9E1D3E229C05F946DED983D4366...
  -> Disabling key 4FCF887689C41B09506BE8D5F3E1D5C5D30DB0AD...
  -> Disabling key 81D7F8241DB38BC759C80FCE3A726C6170E80477...
  -> Disabling key 5E7585ADFF106BFFBBA319DC654B877A0864983E...
  -> Disabling key E7210A59715F6940CF9A4E36A001876699AD6E84...
  -> Disabling key F5A361A3A13554B85E57DDDAAF7EF7873CFD4BB6...
  -> Disabling key 8CF934E339CAD8ABF342E822E711306E3C4F88BC...
  -> Disabling key 5696C003B0854206450C8E5BE613C09CB4440678...
  -> Disabling key 9515D8A8EAB88E49BB65EDBCE6B456CAF15447D5...
  -> Disabling key 4A8B17E20B88ACA61860009B5CED81B7C2E5C0D2...
  -> Disabling key 0B20CA1931F5DA3A70D0F8D2EA6836E1AB441196...
  -> Disabling key 34C5D94FE7E7913E86DC427E7FB1A3800C84C0A5...
  -> Disabling key 39F880E50E49A4D11341E8F939E4F17F295AFBF4...
  -> Disabling key 66BD74A036D522F51DD70A3C7F2A16726521E06D...
  -> Disabling key DBE7D3DD8C81D58D0A13D0E76BC26A17B9B7018A...
  -> Disabling key 07DFD3A0BC213FA12EDC217559B3122E2FA915EC...
  -> Disabling key 44D4A033AC140143927397D47EFD567D4C7EA887...
  -> Disabling key 27FFC4769E19F096D41D9265A04F9397CDFD6BB0...
  -> Disabling key 8840BD07FC24CB7CE394A07CCF7037A4F27FB7DA...
==> Updating trust database...
gpg: next trustdb check due at 2018-06-01
(1/1) Arming ConditionNeedsUpdate...
warning: yaourt-1.9-1 is up to date -- reinstalling
warning: nitrogen-1.6.1-1 is up to date -- reinstalling
warning: python-pip-9.0.1-3 is up to date -- reinstalling
Packages (9) perl-mailtools-2.20-1  perl-timedate-2.30-4  adobe-source-code-pro-fonts-2.030ro+1.050it-4  git-2.17.0-1  nitrogen-1.6.1-1
             python-pip-9.0.1-3  rofi-1.5.1-1  ttf-font-awesome-5.0.10-1  yaourt-1.9-1
Total Download Size:    6.96 MiB
Total Installed Size:  46.53 MiB
Net Upgrade Size:       4.05 MiB
 perl-timedate-2.30-4-any                                          32.9 KiB  88.1K/s 00:00 [#####################################################] 100%
 perl-mailtools-2.20-1-any                                         61.4 KiB  57.7K/s 00:01 [#####################################################] 100%
 git-2.17.0-1-x86_64                                                5.6 MiB   285K/s 00:20 [#####################################################] 100%
 yaourt-1.9-1-any                                                 111.3 KiB   417K/s 00:00 [#####################################################] 100%
 nitrogen-1.6.1-1-x86_64                                          150.9 KiB  1161K/s 00:00 [#####################################################] 100%
 adobe-source-code-pro-fonts-2.030ro+1.050it-4-any                753.9 KiB   367K/s 00:02 [#####################################################] 100%
 rofi-1.5.1-1-x86_64                                              164.2 KiB  1173K/s 00:00 [#####################################################] 100%
 ttf-font-awesome-5.0.10-1-any                                    118.6 KiB  1222K/s 00:00 [#####################################################] 100%
(9/9) checking keys in keyring                                                             [#####################################################] 100%
(9/9) checking package integrity                                                           [#####################################################] 100%
(9/9) loading package files        [#####################################################] 100%
(9/9) checking for file conflicts                                                          [#####################################################] 100%
(9/9) checking available disk space                                                        [#####################################################] 100%
warning: could not get file information for usr/lib/python3.6/site-packages/pip-9.0.1-py3.6.egg-info/
warning: could not get file information for usr/lib/python3.6/site-packages/pip-9.0.1-py3.6.egg-info/PKG-INFO
warning: could not get file information for usr/lib/python3.6/site-packages/pip-9.0.1-py3.6.egg-info/SOURCES.txt
warning: could not get file information for usr/lib/python3.6/site-packages/pip-9.0.1-py3.6.egg-info/dependency_links.txt
warning: could not get file information for usr/lib/python3.6/site-packages/pip-9.0.1-py3.6.egg-info/entry_points.txt
warning: could not get file information for usr/lib/python3.6/site-packages/pip-9.0.1-py3.6.egg-info/not-zip-safe
warning: could not get file information for usr/lib/python3.6/site-packages/pip-9.0.1-py3.6.egg-info/requires.txt
warning: could not get file information for usr/lib/python3.6/site-packages/pip-9.0.1-py3.6.egg-info/top_level.txt
warning: could not get file information for usr/lib/python3.6/site-packages/pip/__pycache__/basecommand.cpython-36.pyc
warning: could not get file information for usr/lib/python3.6/site-packages/pip/__pycache__/baseparser.cpython-36.pyc
warning: could not get file information for usr/lib/python3.6/site-packages/pip/__pycache__/cmdoptions.cpython-36.pyc
warning: could not get file information for usr/lib/python3.6/site-packages/pip/__pycache__/download.cpython-36.pyc
warning: could not get file information for usr/lib/python3.6/site-packages/pip/__pycache__/exceptions.cpython-36.pyc
warning: could not get file information for usr/lib/python3.6/site-packages/pip/__pycache__/index.cpython-36.pyc
warning: could not get file information for usr/lib/python3.6/site-packages/pip/__pycache__/locations.cpython-36.pyc
warning: could not get file information for usr/lib/python3.6/site-packages/pip/__pycache__/pep425tags.cpython-36.pyc
warning: could not get file information for usr/lib/python3.6/site-packages/pip/__pycache__/status_codes.cpython-36.pyc
warning: could not get file information for usr/lib/python3.6/site-packages/pip/__pycache__/wheel.cpython-36.pyc
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/__pycache__/ordereddict.cpython-36.pyc
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/__pycache__/re-vendor.cpython-36.pyc
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/ordereddict.py
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/re-vendor.py
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/cacert.pem
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/__init__.py
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/__pycache__/
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/__pycache__/__init__.cpython-36.pyc
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/chardet/
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/chardet/__init__.py
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/chardet/__pycache__/
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/chardet/__pycache__/__init__.cpython-36.pyc
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/chardet/__pycache__/big5freq.cpython-36.pyc
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/chardet/__pycache__/big5prober.cpython-36.pyc
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/chardet/__pycache__/chardetect.cpython-36.pyc
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/chardet/__pycache__/chardistribution.cpython-36.pyc
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/chardet/__pycache__/charsetgroupprober.cpython-36.pyc
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/chardet/__pycache__/charsetprober.cpython-36.pyc
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/chardet/__pycache__/codingstatemachine.cpython-36.pyc
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/chardet/__pycache__/compat.cpython-36.pyc
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/chardet/__pycache__/constants.cpython-36.pyc
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/chardet/__pycache__/cp949prober.cpython-36.pyc
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/chardet/__pycache__/escprober.cpython-36.pyc
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/chardet/__pycache__/escsm.cpython-36.pyc
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/chardet/__pycache__/eucjpprober.cpython-36.pyc
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/chardet/__pycache__/euckrfreq.cpython-36.pyc
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/chardet/__pycache__/euckrprober.cpython-36.pyc
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/chardet/__pycache__/euctwfreq.cpython-36.pyc
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/chardet/__pycache__/euctwprober.cpython-36.pyc
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/chardet/__pycache__/gb2312freq.cpython-36.pyc
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/chardet/__pycache__/gb2312prober.cpython-36.pyc
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/chardet/__pycache__/hebrewprober.cpython-36.pyc
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/chardet/__pycache__/jisfreq.cpython-36.pyc
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/chardet/__pycache__/jpcntx.cpython-36.pyc
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/chardet/__pycache__/langbulgarianmodel.cpython-36.pyc
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/chardet/__pycache__/langcyrillicmodel.cpython-36.pyc
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/chardet/__pycache__/langgreekmodel.cpython-36.pyc
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/chardet/__pycache__/langhebrewmodel.cpython-36.pyc
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/chardet/__pycache__/langhungarianmodel.cpython-36.pyc
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/chardet/__pycache__/langthaimodel.cpython-36.pyc
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/chardet/__pycache__/latin1prober.cpython-36.pyc
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/chardet/__pycache__/mbcharsetprober.cpython-36.pyc
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/chardet/__pycache__/mbcsgroupprober.cpython-36.pyc
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/chardet/__pycache__/mbcssm.cpython-36.pyc
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/chardet/__pycache__/sbcharsetprober.cpython-36.pyc
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/chardet/__pycache__/sbcsgroupprober.cpython-36.pyc
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/chardet/__pycache__/sjisprober.cpython-36.pyc
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/chardet/__pycache__/universaldetector.cpython-36.pyc
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/chardet/__pycache__/utf8prober.cpython-36.pyc
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/chardet/big5freq.py
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/chardet/big5prober.py
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/chardet/chardetect.py
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/chardet/chardistribution.py
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/chardet/charsetgroupprober.py
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/chardet/charsetprober.py
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/chardet/codingstatemachine.py
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/chardet/compat.py
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/chardet/constants.py
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/chardet/cp949prober.py
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/chardet/escprober.py
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/chardet/escsm.py
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/chardet/eucjpprober.py
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/chardet/euckrfreq.py
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/chardet/euckrprober.py
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/chardet/euctwfreq.py
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/chardet/euctwprober.py
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/chardet/gb2312freq.py
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/chardet/gb2312prober.py
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/chardet/hebrewprober.py
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/chardet/jisfreq.py
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/chardet/jpcntx.py
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/chardet/langbulgarianmodel.py
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/chardet/langcyrillicmodel.py
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/chardet/langgreekmodel.py
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/chardet/langhebrewmodel.py
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/chardet/langhungarianmodel.py
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/chardet/langthaimodel.py
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/chardet/latin1prober.py
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/chardet/mbcharsetprober.py
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/chardet/mbcsgroupprober.py
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/chardet/mbcssm.py
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/chardet/sbcharsetprober.py
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/chardet/sbcsgroupprober.py
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/chardet/sjisprober.py
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/chardet/universaldetector.py
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/chardet/utf8prober.py
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/urllib3/
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/urllib3/__init__.py
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/urllib3/__pycache__/
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/urllib3/__pycache__/__init__.cpython-36.pyc
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/urllib3/__pycache__/_collections.cpython-36.pyc
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/urllib3/__pycache__/connection.cpython-36.pyc
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/urllib3/__pycache__/connectionpool.cpython-36.pyc
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/urllib3/__pycache__/exceptions.cpython-36.pyc
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/urllib3/__pycache__/fields.cpython-36.pyc
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/urllib3/__pycache__/filepost.cpython-36.pyc
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/urllib3/__pycache__/poolmanager.cpython-36.pyc
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/urllib3/__pycache__/request.cpython-36.pyc
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/urllib3/__pycache__/response.cpython-36.pyc
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/urllib3/_collections.py
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/urllib3/connection.py
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/urllib3/connectionpool.py
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/urllib3/contrib/
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/urllib3/contrib/__init__.py
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/urllib3/contrib/__pycache__/
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/urllib3/contrib/__pycache__/__init__.cpython-36.pyc
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/urllib3/contrib/__pycache__/appengine.cpython-36.pyc
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/urllib3/contrib/__pycache__/ntlmpool.cpython-36.pyc
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/urllib3/contrib/__pycache__/pyopenssl.cpython-36.pyc
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/urllib3/contrib/__pycache__/socks.cpython-36.pyc
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/urllib3/contrib/appengine.py
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/urllib3/contrib/ntlmpool.py
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/urllib3/contrib/pyopenssl.py
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/urllib3/contrib/socks.py
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/urllib3/exceptions.py
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/urllib3/fields.py
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/urllib3/filepost.py
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/urllib3/packages/
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/urllib3/packages/__init__.py
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/urllib3/packages/__pycache__/
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/urllib3/packages/__pycache__/__init__.cpython-36.pyc
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/urllib3/packages/__pycache__/ordered_dict.cpython-36.pyc
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/urllib3/packages/__pycache__/six.cpython-36.pyc
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/urllib3/packages/ordered_dict.py
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/urllib3/packages/six.py
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/urllib3/packages/ssl_match_hostname/
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/urllib3/packages/ssl_match_hostname/__init__.py
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/urllib3/packages/ssl_match_hostname/__pycache__/
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/urllib3/packages/ssl_match_hostname/__pycache__/__init__.cpython-36.pyc
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/urllib3/packages/ssl_match_hostname/__pycache__/_implementation.cpython-36.pyc
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/urllib3/packages/ssl_match_hostname/_implementation.py
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/urllib3/poolmanager.py
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/urllib3/request.py
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/urllib3/response.py
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/urllib3/util/
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/urllib3/util/__init__.py
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/urllib3/util/__pycache__/
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/urllib3/util/__pycache__/__init__.cpython-36.pyc
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/urllib3/util/__pycache__/connection.cpython-36.pyc
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/urllib3/util/__pycache__/request.cpython-36.pyc
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/urllib3/util/__pycache__/response.cpython-36.pyc
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/urllib3/util/__pycache__/retry.cpython-36.pyc
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/urllib3/util/__pycache__/ssl_.cpython-36.pyc
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/urllib3/util/__pycache__/timeout.cpython-36.pyc
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/urllib3/util/__pycache__/url.cpython-36.pyc
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/urllib3/util/connection.py
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/urllib3/util/request.py
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/urllib3/util/response.py
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/urllib3/util/retry.py
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/urllib3/util/ssl_.py
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/urllib3/util/timeout.py
warning: could not get file information for usr/lib/python3.6/site-packages/pip/_vendor/requests/packages/urllib3/util/url.py
warning: could not get file information for usr/lib/python3.6/site-packages/pip/basecommand.py
warning: could not get file information for usr/lib/python3.6/site-packages/pip/baseparser.py
warning: could not get file information for usr/lib/python3.6/site-packages/pip/cmdoptions.py
warning: could not get file information for usr/lib/python3.6/site-packages/pip/commands/
warning: could not get file information for usr/lib/python3.6/site-packages/pip/commands/__init__.py
warning: could not get file information for usr/lib/python3.6/site-packages/pip/commands/__pycache__/
warning: could not get file information for usr/lib/python3.6/site-packages/pip/commands/__pycache__/__init__.cpython-36.pyc
warning: could not get file information for usr/lib/python3.6/site-packages/pip/commands/__pycache__/check.cpython-36.pyc
warning: could not get file information for usr/lib/python3.6/site-packages/pip/commands/__pycache__/completion.cpython-36.pyc
warning: could not get file information for usr/lib/python3.6/site-packages/pip/commands/__pycache__/download.cpython-36.pyc
warning: could not get file information for usr/lib/python3.6/site-packages/pip/commands/__pycache__/freeze.cpython-36.pyc
warning: could not get file information for usr/lib/python3.6/site-packages/pip/commands/__pycache__/hash.cpython-36.pyc
warning: could not get file information for usr/lib/python3.6/site-packages/pip/commands/__pycache__/help.cpython-36.pyc
warning: could not get file information for usr/lib/python3.6/site-packages/pip/commands/__pycache__/install.cpython-36.pyc
warning: could not get file information for usr/lib/python3.6/site-packages/pip/commands/__pycache__/list.cpython-36.pyc
warning: could not get file information for usr/lib/python3.6/site-packages/pip/commands/__pycache__/search.cpython-36.pyc
warning: could not get file information for usr/lib/python3.6/site-packages/pip/commands/__pycache__/show.cpython-36.pyc
warning: could not get file information for usr/lib/python3.6/site-packages/pip/commands/__pycache__/uninstall.cpython-36.pyc
warning: could not get file information for usr/lib/python3.6/site-packages/pip/commands/__pycache__/wheel.cpython-36.pyc
warning: could not get file information for usr/lib/python3.6/site-packages/pip/commands/check.py
warning: could not get file information for usr/lib/python3.6/site-packages/pip/commands/completion.py
warning: could not get file information for usr/lib/python3.6/site-packages/pip/commands/download.py
warning: could not get file information for usr/lib/python3.6/site-packages/pip/commands/freeze.py
warning: could not get file information for usr/lib/python3.6/site-packages/pip/commands/hash.py
warning: could not get file information for usr/lib/python3.6/site-packages/pip/commands/help.py
warning: could not get file information for usr/lib/python3.6/site-packages/pip/commands/install.py
warning: could not get file information for usr/lib/python3.6/site-packages/pip/commands/list.py
warning: could not get file information for usr/lib/python3.6/site-packages/pip/commands/search.py
warning: could not get file information for usr/lib/python3.6/site-packages/pip/commands/show.py
warning: could not get file information for usr/lib/python3.6/site-packages/pip/commands/uninstall.py
warning: could not get file information for usr/lib/python3.6/site-packages/pip/commands/wheel.py
warning: could not get file information for usr/lib/python3.6/site-packages/pip/compat/
warning: could not get file information for usr/lib/python3.6/site-packages/pip/compat/__init__.py
warning: could not get file information for usr/lib/python3.6/site-packages/pip/compat/__pycache__/
warning: could not get file information for usr/lib/python3.6/site-packages/pip/compat/__pycache__/__init__.cpython-36.pyc
warning: could not get file information for usr/lib/python3.6/site-packages/pip/compat/__pycache__/dictconfig.cpython-36.pyc
warning: could not get file information for usr/lib/python3.6/site-packages/pip/compat/dictconfig.py
warning: could not get file information for usr/lib/python3.6/site-packages/pip/download.py
warning: could not get file information for usr/lib/python3.6/site-packages/pip/exceptions.py
warning: could not get file information for usr/lib/python3.6/site-packages/pip/index.py
warning: could not get file information for usr/lib/python3.6/site-packages/pip/locations.py
warning: could not get file information for usr/lib/python3.6/site-packages/pip/models/
warning: could not get file information for usr/lib/python3.6/site-packages/pip/models/__init__.py
warning: could not get file information for usr/lib/python3.6/site-packages/pip/models/__pycache__/
warning: could not get file information for usr/lib/python3.6/site-packages/pip/models/__pycache__/__init__.cpython-36.pyc
warning: could not get file information for usr/lib/python3.6/site-packages/pip/models/__pycache__/index.cpython-36.pyc
warning: could not get file information for usr/lib/python3.6/site-packages/pip/models/index.py
warning: could not get file information for usr/lib/python3.6/site-packages/pip/operations/
warning: could not get file information for usr/lib/python3.6/site-packages/pip/operations/__init__.py
warning: could not get file information for usr/lib/python3.6/site-packages/pip/operations/__pycache__/
warning: could not get file information for usr/lib/python3.6/site-packages/pip/operations/__pycache__/__init__.cpython-36.pyc
warning: could not get file information for usr/lib/python3.6/site-packages/pip/operations/__pycache__/check.cpython-36.pyc
warning: could not get file information for usr/lib/python3.6/site-packages/pip/operations/__pycache__/freeze.cpython-36.pyc
warning: could not get file information for usr/lib/python3.6/site-packages/pip/operations/check.py
warning: could not get file information for usr/lib/python3.6/site-packages/pip/operations/freeze.py
warning: could not get file information for usr/lib/python3.6/site-packages/pip/pep425tags.py
warning: could not get file information for usr/lib/python3.6/site-packages/pip/req/
warning: could not get file information for usr/lib/python3.6/site-packages/pip/req/__init__.py
warning: could not get file information for usr/lib/python3.6/site-packages/pip/req/__pycache__/
warning: could not get file information for usr/lib/python3.6/site-packages/pip/req/__pycache__/__init__.cpython-36.pyc
warning: could not get file information for usr/lib/python3.6/site-packages/pip/req/__pycache__/req_file.cpython-36.pyc
warning: could not get file information for usr/lib/python3.6/site-packages/pip/req/__pycache__/req_install.cpython-36.pyc
warning: could not get file information for usr/lib/python3.6/site-packages/pip/req/__pycache__/req_set.cpython-36.pyc
warning: could not get file information for usr/lib/python3.6/site-packages/pip/req/__pycache__/req_uninstall.cpython-36.pyc
warning: could not get file information for usr/lib/python3.6/site-packages/pip/req/req_file.py
warning: could not get file information for usr/lib/python3.6/site-packages/pip/req/req_install.py
warning: could not get file information for usr/lib/python3.6/site-packages/pip/req/req_set.py
warning: could not get file information for usr/lib/python3.6/site-packages/pip/req/req_uninstall.py
warning: could not get file information for usr/lib/python3.6/site-packages/pip/status_codes.py
warning: could not get file information for usr/lib/python3.6/site-packages/pip/utils/
warning: could not get file information for usr/lib/python3.6/site-packages/pip/utils/__init__.py
warning: could not get file information for usr/lib/python3.6/site-packages/pip/utils/__pycache__/
warning: could not get file information for usr/lib/python3.6/site-packages/pip/utils/__pycache__/__init__.cpython-36.pyc
warning: could not get file information for usr/lib/python3.6/site-packages/pip/utils/__pycache__/appdirs.cpython-36.pyc
warning: could not get file information for usr/lib/python3.6/site-packages/pip/utils/__pycache__/build.cpython-36.pyc
warning: could not get file information for usr/lib/python3.6/site-packages/pip/utils/__pycache__/deprecation.cpython-36.pyc
warning: could not get file information for usr/lib/python3.6/site-packages/pip/utils/__pycache__/encoding.cpython-36.pyc
warning: could not get file information for usr/lib/python3.6/site-packages/pip/utils/__pycache__/filesystem.cpython-36.pyc
warning: could not get file information for usr/lib/python3.6/site-packages/pip/utils/__pycache__/glibc.cpython-36.pyc
warning: could not get file information for usr/lib/python3.6/site-packages/pip/utils/__pycache__/hashes.cpython-36.pyc
warning: could not get file information for usr/lib/python3.6/site-packages/pip/utils/__pycache__/logging.cpython-36.pyc
warning: could not get file information for usr/lib/python3.6/site-packages/pip/utils/__pycache__/outdated.cpython-36.pyc
warning: could not get file information for usr/lib/python3.6/site-packages/pip/utils/__pycache__/packaging.cpython-36.pyc
warning: could not get file information for usr/lib/python3.6/site-packages/pip/utils/__pycache__/setuptools_build.cpython-36.pyc
warning: could not get file information for usr/lib/python3.6/site-packages/pip/utils/__pycache__/ui.cpython-36.pyc
warning: could not get file information for usr/lib/python3.6/site-packages/pip/utils/appdirs.py
warning: could not get file information for usr/lib/python3.6/site-packages/pip/utils/build.py
warning: could not get file information for usr/lib/python3.6/site-packages/pip/utils/deprecation.py
warning: could not get file information for usr/lib/python3.6/site-packages/pip/utils/encoding.py
warning: could not get file information for usr/lib/python3.6/site-packages/pip/utils/filesystem.py
warning: could not get file information for usr/lib/python3.6/site-packages/pip/utils/glibc.py
warning: could not get file information for usr/lib/python3.6/site-packages/pip/utils/hashes.py
warning: could not get file information for usr/lib/python3.6/site-packages/pip/utils/logging.py
warning: could not get file information for usr/lib/python3.6/site-packages/pip/utils/outdated.py
warning: could not get file information for usr/lib/python3.6/site-packages/pip/utils/packaging.py
warning: could not get file information for usr/lib/python3.6/site-packages/pip/utils/setuptools_build.py
warning: could not get file information for usr/lib/python3.6/site-packages/pip/utils/ui.py
warning: could not get file information for usr/lib/python3.6/site-packages/pip/vcs/
warning: could not get file information for usr/lib/python3.6/site-packages/pip/vcs/__init__.py
warning: could not get file information for usr/lib/python3.6/site-packages/pip/vcs/__pycache__/
warning: could not get file information for usr/lib/python3.6/site-packages/pip/vcs/__pycache__/__init__.cpython-36.pyc
warning: could not get file information for usr/lib/python3.6/site-packages/pip/vcs/__pycache__/bazaar.cpython-36.pyc
warning: could not get file information for usr/lib/python3.6/site-packages/pip/vcs/__pycache__/git.cpython-36.pyc
warning: could not get file information for usr/lib/python3.6/site-packages/pip/vcs/__pycache__/mercurial.cpython-36.pyc
warning: could not get file information for usr/lib/python3.6/site-packages/pip/vcs/__pycache__/subversion.cpython-36.pyc
warning: could not get file information for usr/lib/python3.6/site-packages/pip/vcs/bazaar.py
warning: could not get file information for usr/lib/python3.6/site-packages/pip/vcs/git.py
warning: could not get file information for usr/lib/python3.6/site-packages/pip/vcs/mercurial.py
warning: could not get file information for usr/lib/python3.6/site-packages/pip/vcs/subversion.py
warning: could not get file information for usr/lib/python3.6/site-packages/pip/wheel.py
(1/9) installing perl-timedate                                                             [#####################################################] 100%
(2/9) installing perl-mailtools                                                            [#####################################################] 100%
(3/9) upgrading git        [#####################################################] 100%
(4/9) reinstalling yaourt        [#####################################################] 100%
(5/9) reinstalling nitrogen        [#####################################################] 100%
(6/9) installing rofi        [#####################################################] 100%
Optional dependencies for rofi
    i3-wm: use as a window switcher [installed]
(7/9) reinstalling python-pip                                                              [#####################################################]
#32
cont
100%
(8/9) installing ttf-font-awesome                                                          [#####################################################] 100%
(9/9) installing adobe-source-code-pro-fonts                                               [#####################################################] 100%
(1/8) Warn about old perl modules
(2/8) Updating fontconfig cache...
Fontconfig warning: "/etc/fonts/conf.d/70-no-bitmaps.conf", line 4: unknown element "its:rules"
Fontconfig warning: "/etc/fonts/conf.d/70-no-bitmaps.conf", line 5: unknown element "its:translateRule"
Fontconfig error: "/etc/fonts/conf.d/70-no-bitmaps.conf", line 5: invalid attribute 'translate'
Fontconfig error: "/etc/fonts/conf.d/70-no-bitmaps.conf", line 5: invalid attribute 'selector'
Fontconfig error: "/etc/fonts/conf.d/70-no-bitmaps.conf", line 6: invalid attribute 'xmlns:its'
Fontconfig error: "/etc/fonts/conf.d/70-no-bitmaps.conf", line 6: invalid attribute 'version'
Fontconfig warning: "/etc/fonts/conf.d/70-no-bitmaps.conf", line 8: unknown element "description"
(3/8) Updating icon theme caches...
(4/8) Reloading system manager configuration...
(5/8) Creating system user accounts...
(6/8) Arming ConditionNeedsUpdate...
(7/8) Updating the desktop file MIME type cache...
(8/8) Updating X fontdir indices...
==> Downloading nerd-fonts-complete PKGBUILD from AUR...
x .SRCINFO
x PKGBUILD
x nerd-fonts-complete.install
raith commented on 2018-01-24 12:15
Terence commented on 2018-01-24 16:03
glider commented on 2018-03-21 01:49
mchwalisz commented on 2018-03-21 07:29
02m commented on 2018-04-08 06:35
nerd-fonts-complete 1.2.0-3  (2018-01-24 21:05)
( Unsupported package: Potentially dangerous ! )
==> nerd-fonts-complete dependencies:
 - fontconfig (already installed)
 - xorg-font-utils (already installed)
==> Continue building nerd-fonts-complete ? [Y/n]
==> Building and installing package
==> Making package: nerd-fonts-complete 1.2.0-3 (Mon Apr 16 15:04:06 +08 2018)
==> Retrieving sources...
  -> Downloading nerd-fonts-complete-1.2.0.tar.gz...
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
100   128    0   128    0     0     24      0 --:--:--  0:00:05 --:--:--    34
100  318M  100  318M    0     0   325k      0  0:16:42  0:16:42 --:--:--  359k
    nerd-fonts-complete-1.2.0.tar.gz ... Passed
==> Extracting sources...
  -> Extracting nerd-fonts-complete-1.2.0.tar.gz with bsdtar
nerd-fonts-1.2.0/patched-fonts/SourceCodePro/Black/complete/Sauce Code Pro Black Nerd Font Complete Windows Compatible.ttf: Write failed
nerd-fonts-1.2.0/patched-fonts/SourceCodePro/Black/complete/Sauce Code Pro Black Nerd Font Complete.ttf: Write failed
nerd-fonts-1.2.0/patched-fonts/SourceCodePro/Black/font-info.md: Write failed
nerd-fonts-1.2.0/patched-fonts/SourceCodePro/Black/readme.md: Write failed
nerd-fonts-1.2.0/patched-fonts/SourceCodePro/Bold/complete/Sauce Code Pro Bold Nerd Font Complete Mono Windows Compatible.ttf: Write failed
nerd-fonts-1.2.0/patched-fonts/SourceCodePro/Bold/complete/Sauce Code Pro Bold Nerd Font Complete Mono.ttf: Write failed
nerd-fonts-1.2.0/patched-fonts/SourceCodePro/Bold/complete/Sauce Code Pro Bold Nerd Font Complete Windows Compatible.ttf: Write failed
nerd-fonts-1.2.0/patched-fonts/SourceCodePro/Bold/complete/Sauce Code Pro Bold Nerd Font Complete.ttf: Write failed
nerd-fonts-1.2.0/patched-fonts/SourceCodePro/Bold/font-info.md: Write failed
nerd-fonts-1.2.0/patched-fonts/SourceCodePro/Bold/readme.md: Write failed
nerd-fonts-1.2.0/patched-fonts/SourceCodePro/Extra-Light/complete/Sauce Code Pro ExtraLight Nerd Font Complete Mono Windows Compatible.ttf: Write failed
nerd-fonts-1.2.0/patched-fonts/SourceCodePro/Extra-Light/complete/Sauce Code Pro ExtraLight Nerd Font Complete Mono.ttf: Write failed
nerd-fonts-1.2.0/patched-fonts/SourceCodePro/Extra-Light/complete/Sauce Code Pro ExtraLight Nerd Font Complete Windows Compatible.ttf: Write failed
nerd-fonts-1.2.0/patched-fonts/SourceCodePro/Extra-Light/complete/Sauce Code Pro ExtraLight Nerd Font Complete.ttf: Write failed
nerd-fonts-1.2.0/patched-fonts/SourceCodePro/Extra-Light/font-info.md: Write failed
nerd-fonts-1.2.0/patched-fonts/SourceCodePro/Extra-Light/readme.md: Write failed
nerd-fonts-1.2.0/patched-fonts/SourceCodePro/Light/complete/Sauce Code Pro Light Nerd Font Complete Mono Windows Compatible.ttf: Write failed
nerd-fonts-1.2.0/patched-fonts/SourceCodePro/Light/complete/Sauce Code Pro Light Nerd Font Complete Mono.ttf: Write failed
nerd-fonts-1.2.0/patched-fonts/SourceCodePro/Light/complete/Sauce Code Pro Light Nerd Font Complete Windows Compatible.ttf: Write failed
nerd-fonts-1.2.0/patched-fonts/SourceCodePro/Light/complete/Sauce Code Pro Light Nerd Font Complete.ttf: Write failed
nerd-fonts-1.2.0/patched-fonts/SourceCodePro/Light/font-info.md: Write failed
nerd-fonts-1.2.0/patched-fonts/SourceCodePro/Light/readme.md: Write failed
nerd-fonts-1.2.0/patched-fonts/SourceCodePro/Medium/complete/Sauce Code Pro Medium Nerd Font Complete Mono Windows Compatible.ttf: Write failed
nerd-fonts-1.2.0/patched-fonts/SourceCodePro/Medium/complete/Sauce Code Pro Medium Nerd Font Complete Mono.ttf: Write failed
nerd-fonts-1.2.0/patched-fonts/SourceCodePro/Medium/complete/Sauce Code Pro Medium Nerd Font Complete Windows Compatible.ttf: Write failed
nerd-fonts-1.2.0/patched-fonts/SourceCodePro/Medium/complete/Sauce Code Pro Medium Nerd Font Complete.ttf: Write failed
nerd-fonts-1.2.0/patched-fonts/SourceCodePro/Medium/font-info.md: Write failed
nerd-fonts-1.2.0/patched-fonts/SourceCodePro/Medium/readme.md: Write failed
nerd-fonts-1.2.0/patched-fonts/SourceCodePro/Regular/complete/Sauce Code Pro Nerd Font Complete Mono Windows Compatible.ttf: Write failed
nerd-fonts-1.2.0/patched-fonts/SourceCodePro/Regular/complete/Sauce Code Pro Nerd Font Complete Mono.ttf: Write failed
nerd-fonts-1.2.0/patched-fonts/SourceCodePro/Regular/complete/Sauce Code Pro Nerd Font Complete Windows Compatible.ttf: Write failed
nerd-fonts-1.2.0/patched-fonts/SourceCodePro/Regular/complete/Sauce Code Pro Nerd Font Complete.ttf: Write failed
nerd-fonts-1.2.0/patched-fonts/SourceCodePro/Regular/font-info.md: Write failed
nerd-fonts-1.2.0/patched-fonts/SourceCodePro/Regular/readme.md: Write failed
nerd-fonts-1.2.0/patched-fonts/SourceCodePro/Semibold/complete/Sauce Code Pro Semibold Nerd Font Complete Mono Windows Compatible.ttf: Write failed
nerd-fonts-1.2.0/patched-fonts/SourceCodePro/Semibold/complete/Sauce Code Pro Semibold Nerd Font Complete Mono.ttf: Write failed
nerd-fonts-1.2.0/patched-fonts/SourceCodePro/Semibold/complete/Sauce Code Pro Semibold Nerd Font Complete Windows Compatible.ttf: Write failed
nerd-fonts-1.2.0/patched-fonts/SourceCodePro/Semibold/complete/Sauce Code Pro Semibold Nerd Font Complete.ttf: Write failed
nerd-fonts-1.2.0/patched-fonts/SourceCodePro/Semibold/font-info.md: Write failed
nerd-fonts-1.2.0/patched-fonts/SourceCodePro/Semibold/readme.md: Write failed
nerd-fonts-1.2.0/patched-fonts/SourceCodePro/font-info.md: Write failed
nerd-fonts-1.2.0/patched-fonts/SourceCodePro/readme.md: Write failed
nerd-fonts-1.2.0/patched-fonts/SpaceMono/complete/Space Mono Bold Italic Nerd Font Complete Mono Windows Compatible.ttf: Write failed
nerd-fonts-1.2.0/patched-fonts/SpaceMono/complete/Space Mono Bold Italic Nerd Font Complete Mono.ttf: Write failed
nerd-fonts-1.2.0/patched-fonts/SpaceMono/complete/Space Mono Bold Italic Nerd Font Complete Windows Compatible.ttf: Write failed
nerd-fonts-1.2.0/patched-fonts/SpaceMono/complete/Space Mono Bold Italic Nerd Font Complete.ttf: Write failed
nerd-fonts-1.2.0/patched-fonts/SpaceMono/complete/Space Mono Bold Nerd Font Complete Mono Windows Compatible.ttf: Write failed
nerd-fonts-1.2.0/patched-fonts/SpaceMono/complete/Space Mono Bold Nerd Font Complete Mono.ttf: Write failed
nerd-fonts-1.2.0/patched-fonts/SpaceMono/complete/Space Mono Bold Nerd Font Complete Windows Compatible.ttf: Write failed
nerd-fonts-1.2.0/patched-fonts/SpaceMono/complete/Space Mono Bold Nerd Font Complete.ttf: Write failed
nerd-fonts-1.2.0/patched-fonts/SpaceMono/complete/Space Mono Italic Nerd Font Complete Mono Windows Compatible.ttf: Write failed
nerd-fonts-1.2.0/patched-fonts/SpaceMono/complete/Space Mono Italic Nerd Font Complete Mono.ttf: Write failed
nerd-fonts-1.2.0/patched-fonts/SpaceMono/complete/Space Mono Italic Nerd Font Complete Windows Compatible.ttf: Write failed
nerd-fonts-1.2.0/patched-fonts/SpaceMono/complete/Space Mono Italic Nerd Font Complete.ttf: Write failed
nerd-fonts-1.2.0/patched-fonts/SpaceMono/complete/Space Mono Nerd Font Complete Mono Windows Compatible.ttf: Write failed
nerd-fonts-1.2.0/patched-fonts/SpaceMono/complete/Space Mono Nerd Font Complete Mono.ttf: Write failed
nerd-fonts-1.2.0/patched-fonts/SpaceMono/complete/Space Mono Nerd Font Complete Windows Compatible.ttf: Write failed
nerd-fonts-1.2.0/patched-fonts/SpaceMono/complete/Space Mono Nerd Font Complete.ttf: Write failed
nerd-fonts-1.2.0/patched-fonts/SpaceMono/font-info.md: Write failed
nerd-fonts-1.2.0/patched-fonts/SpaceMono/readme.md: Write failed
nerd-fonts-1.2.0/patched-fonts/Terminus/BDF/font-info.md: Write failed
nerd-fonts-1.2.0/patched-fonts/Terminus/PCF/font-info.md: Write failed
nerd-fonts-1.2.0/patched-fonts/Terminus/PSF/font-info.md: Write failed
nerd-fonts-1.2.0/patched-fonts/Terminus/font-info.md: Write failed
nerd-fonts-1.2.0/patched-fonts/Terminus/terminus-ttf-4.40.1/Bold/complete/Terminess (TTF) Bold Nerd Font Complete Mono Windows Compatible.ttf: Write failed
nerd-fonts-1.2.0/patched-fonts/Terminus/terminus-ttf-4.40.1/Bold/complete/Terminess (TTF) Bold Nerd Font Complete Mono.ttf: Write failed
nerd-fonts-1.2.0/patched-fonts/Terminus/terminus-ttf-4.40.1/Bold/complete/Terminess (TTF) Bold Nerd Font Complete Windows Compatible.ttf: Write failed
nerd-fonts-1.2.0/patched-fonts/Terminus/terminus-ttf-4.40.1/Bold/complete/Terminess (TTF) Bold Nerd Font Complete.ttf: Write failed
nerd-fonts-1.2.0/patched-fonts/Terminus/terminus-ttf-4.40.1/Bold/font-info.md: Write failed
nerd-fonts-1.2.0/patched-fonts/Terminus/terminus-ttf-4.40.1/Bold/readme.md: Write failed
nerd-fonts-1.2.0/patched-fonts/Terminus/terminus-ttf-4.40.1/BoldItalic/complete/Terminess (TTF) Bold Italic Nerd Font Complete Mono Windows Compatible.ttf: Write failed
nerd-fonts-1.2.0/patched-fonts/Terminus/terminus-ttf-4.40.1/BoldItalic/complete/Terminess (TTF) Bold Italic Nerd Font Complete Mono.ttf: Write failed
nerd-fonts-1.2.0/patched-fonts/Terminus/terminus-ttf-4.40.1/BoldItalic/complete/Terminess (TTF) Bold Italic Nerd Font Complete Windows Compatible.ttf: Write failed
nerd-fonts-1.2.0/patched-fonts/Terminus/terminus-ttf-4.40.1/BoldItalic/complete/Terminess (TTF) Bold Italic Nerd Font Complete.ttf: Write failed
nerd-fonts-1.2.0/patched-fonts/Terminus/terminus-ttf-4.40.1/BoldItalic/font-info.md: Write failed
nerd-fonts-1.2.0/patched-fonts/Terminus/terminus-ttf-4.40.1/BoldItalic/readme.md: Write failed
nerd-fonts-1.2.0/patched-fonts/Terminus/terminus-ttf-4.40.1/Italic/complete/Terminess (TTF) Italic Nerd Font Complete Mono Windows Compatible.ttf: Write failed
nerd-fonts-1.2.0/patched-fonts/Terminus/terminus-ttf-4.40.1/Italic/complete/Terminess (TTF) Italic Nerd Font Complete Mono.ttf: Write failed
nerd-fonts-1.2.0/patched-fonts/Terminus/terminus-ttf-4.40.1/Italic/complete/Terminess (TTF) Italic Nerd Font Complete Windows Compatible.ttf: Write failed
nerd-fonts-1.2.0/patched-fonts/Terminus/terminus-ttf-4.40.1/Italic/complete/Terminess (TTF) Italic Nerd Font Complete.ttf: Write failed
nerd-fonts-1.2.0/patched-fonts/Terminus/terminus-ttf-4.40.1/Italic/font-info.md: Write failed
nerd-fonts-1.2.0/patched-fonts/Terminus/terminus-ttf-4.40.1/Italic/readme.md: Write failed
nerd-fonts-1.2.0/patched-fonts/Terminus/terminus-ttf-4.40.1/Regular/complete/Terminess (TTF) Nerd Font Complete Mono Windows Compatible.ttf: Write failed
nerd-fonts-1.2.0/patched-fonts/Terminus/terminus-ttf-4.40.1/Regular/complete/Terminess (TTF) Nerd Font Complete Mono.ttf: Write failed
nerd-fonts-1.2.0/patched-fonts/Terminus/terminus-ttf-4.40.1/Regular/complete/Terminess (TTF) Nerd Font Complete Windows Compatible.ttf: Write failed
nerd-fonts-1.2.0/patched-fonts/Terminus/terminus-ttf-4.40.1/Regular/complete/Terminess (TTF) Nerd Font Complete.ttf: Write failed
nerd-fonts-1.2.0/patched-fonts/Terminus/terminus-ttf-4.40.1/Regular/font-info.md: Write failed
nerd-fonts-1.2.0/patched-fonts/Terminus/terminus-ttf-4.40.1/Regular/readme.md: Write failed
nerd-fonts-1.2.0/patched-fonts/Terminus/terminus-ttf-4.40.1/font-info.md: Write failed
nerd-fonts-1.2.0/patched-fonts/Terminus/terminus-ttf-4.40.1/readme.md: Write failed
nerd-fonts-1.2.0/patched-fonts/Tinos/complete/Tinos Bold Italic Nerd Font Complete Mono Windows Compatible.ttf: Write failed
nerd-fonts-1.2.0/patched-fonts/Tinos/complete/Tinos Bold Italic Nerd Font Complete Mono.ttf: Write failed
nerd-fonts-1.2.0/patched-fonts/Tinos/complete/Tinos Bold Italic Nerd Font Complete Windows Compatible.ttf: Write failed
nerd-fonts-1.2.0/patched-fonts/Tinos/complete/Tinos Bold Italic Nerd Font Complete.ttf: Write failed
nerd-fonts-1.2.0/patched-fonts/Tinos/complete/Tinos Bold Nerd Font Complete Mono Windows Compatible.ttf: Write failed
nerd-fonts-1.2.0/patched-fonts/Tinos/complete/Tinos Bold Nerd Font Complete Mono.ttf: Write failed
nerd-fonts-1.2.0/patched-fonts/Tinos/complete/Tinos Bold Nerd Font Complete Windows Compatible.ttf: Write failed
nerd-fonts-1.2.0/patched-fonts/Tinos/complete/Tinos Bold Nerd Font Complete.ttf: Write failed
nerd-fonts-1.2.0/patched-fonts/Tinos/complete/Tinos Italic Nerd Font Complete Mono Windows Compatible.ttf: Write failed
nerd-fonts-1.2.0/patched-fonts/Tinos/complete/Tinos Italic Nerd Font Complete Mono.ttf: Write failed
nerd-fonts-1.2.0/patched-fonts/Tinos/complete/Tinos Italic Nerd Font Complete Windows Compatible.ttf: Write failed
nerd-fonts-1.2.0/patched-fonts/Tinos/complete/Tinos Italic Nerd Font Complete.ttf: Write failed
nerd-fonts-1.2.0/patched-fonts/Tinos/complete/Tinos Nerd Font Complete Mono Windows Compatible.ttf: Write failed
nerd-fonts-1.2.0/patched-fonts/Tinos/complete/Tinos Nerd Font Complete Mono.ttf: Write failed
nerd-fonts-1.2.0/patched-fonts/Tinos/complete/Tinos Nerd Font Complete Windows Compatible.ttf: Write failed
nerd-fonts-1.2.0/patched-fonts/Tinos/complete/Tinos Nerd Font Complete.ttf: Write failed
nerd-fonts-1.2.0/patched-fonts/Tinos/font-info.md: Write failed
nerd-fonts-1.2.0/patched-fonts/Tinos/readme.md: Write failed
nerd-fonts-1.2.0/patched-fonts/Ubuntu/Bold-Italic/complete/Ubuntu Bold Italic Nerd Font Complete Mono Windows Compatible.ttf: Write failed
nerd-fonts-1.2.0/patched-fonts/Ubuntu/Bold-Italic/complete/Ubuntu Bold Italic Nerd Font Complete Mono.ttf: Write failed
nerd-fonts-1.2.0/patched-fonts/Ubuntu/Bold-Italic/complete/Ubuntu Bold Italic Nerd Font Complete Windows Compatible.ttf: Write failed
nerd-fonts-1.2.0/patched-fonts/Ubuntu/Bold-Italic/complete/Ubuntu Bold Italic Nerd Font Complete.ttf: Write failed
nerd-fonts-1.2.0/patched-fonts/Ubuntu/Bold-Italic/font-info.md: Write failed
nerd-fonts-1.2.0/patched-fonts/Ubuntu/Bold-Italic/readme.md: Write failed
nerd-fonts-1.2.0/patched-fonts/Ubuntu/Bold/complete/Ubuntu Bold Nerd Font Complete Mono Windows Compatible.ttf: Write failed
nerd-fonts-1.2.0/patched-fonts/Ubuntu/Bold/complete/Ubuntu Bold Nerd Font Complete Mono.ttf: Write failed
nerd-fonts-1.2.0/patched-fonts/Ubuntu/Bold/complete/Ubuntu Bold Nerd Font Complete Windows Compatible.ttf: Write failed
nerd-fonts-1.2.0/patched-fonts/Ubuntu/Bold/complete/Ubuntu Bold Nerd Font Complete.ttf: Write failed
nerd-fonts-1.2.0/patched-fonts/Ubuntu/Bold/font-info.md: Write failed
nerd-fonts-1.2.0/patched-fonts/Ubuntu/Bold/readme.md: Write failed
nerd-fonts-1.2.0/patched-fonts/Ubuntu/Condensed/complete/Ubuntu Condensed Nerd Font Complete Mono Windows Compatible.ttf: Write failed
nerd-fonts-1.2.0/patched-fonts/Ubuntu/Condensed/complete/Ubuntu Condensed Nerd Font Complete Mono.ttf: Write failed
nerd-fonts-1.2.0/patched-fonts/Ubuntu/Condensed/complete/Ubuntu Condensed Nerd Font Complete Windows Compatible.ttf: Write failed
nerd-fonts-1.2.0/patched-fonts/Ubuntu/Condensed/complete/Ubuntu Condensed Nerd Font Complete.ttf: Write failed
nerd-fonts-1.2.0/patched-fonts/Ubuntu/Condensed/font-info.md: Write failed
nerd-fonts-1.2.0/patched-fonts/Ubuntu/Condensed/readme.md: Write failed
nerd-fonts-1.2.0/patched-fonts/Ubuntu/Light-Italic/complete/Ubuntu Light Italic Nerd Font Complete Mono Windows Compatible.ttf: Write failed
nerd-fonts-1.2.0/patched-fonts/Ubuntu/Light-Italic/complete/Ubuntu Light Italic Nerd Font Complete Mono.ttf: Write failed
nerd-fonts-1.2.0/patched-fonts/Ubuntu/Light-Italic/complete/Ubuntu Light Italic Nerd Font Complete Windows Compatible.ttf: Write failed
nerd-fonts-1.2.0/patched-fonts/Ubuntu/Light-Italic/complete/Ubuntu Light Italic Nerd Font Complete.ttf: Write failed
nerd-fonts-1.2.0/patched-fonts/Ubuntu/Light-Italic/font-info.md: Write failed
nerd-fonts-1.2.0/patched-fonts/Ubuntu/Light-Italic/readme.md: Write failed
nerd-fonts-1.2.0/patched-fonts/Ubuntu/Light/complete/Ubuntu Light Nerd Font Complete Mono Windows Compatible.ttf: Write failed
nerd-fonts-1.2.0/patched-fonts/Ubuntu/Light/complete/Ubuntu Light Nerd Font Complete Mono.ttf: Write failed
nerd-fonts-1.2.0/patched-fonts/Ubuntu/Light/complete/Ubuntu Light Nerd Font Complete Windows Compatible.ttf: Write failed
nerd-fonts-1.2.0/patched-fonts/Ubuntu/Light/complete/Ubuntu Light Nerd Font Complete.ttf: Write failed
nerd-fonts-1.2.0/patched-fonts/Ubuntu/Light/font-info.md: Write failed
nerd-fonts-1.2.0/patched-fonts/Ubuntu/Light/readme.md: Write failed
nerd-fonts-1.2.0/patched-fonts/Ubuntu/Medium-Italic/complete/Ubuntu Medium Italic Nerd Font Complete Mono Windows Compatible.ttf: Write failed
nerd-fonts-1.2.0/patched-fonts/Ubuntu/Medium-Italic/complete/Ubuntu Medium Italic Nerd Font Complete Mono.ttf: Write failed
nerd-fonts-1.2.0/patched-fonts/Ubuntu/Medium-Italic/complete/Ubuntu Medium Italic Nerd Font Complete Windows Compatible.ttf: Write failed
nerd-fonts-1.2.0/patched-fonts/Ubuntu/Medium-Italic/complete/Ubuntu Medium Italic Nerd Font Complete.ttf: Write failed
nerd-fonts-1.2.0/patched-fonts/Ubuntu/Medium-Italic/font-info.md: Write failed
nerd-fonts-1.2.0/patched-fonts/Ubuntu/Medium-Italic/readme.md: Write failed
nerd-fonts-1.2.0/patched-fonts/Ubuntu/Medium/complete/Ubuntu Medium Nerd Font Complete Mono Windows Compatible.ttf: Write failed
nerd-fonts-1.2.0/patched-fonts/Ubuntu/Medium/complete/Ubuntu Medium Nerd Font Complete Mono.ttf: Write failed
nerd-fonts-1.2.0/patched-fonts/Ubuntu/Medium/complete/Ubuntu Medium Nerd Font Complete Windows Compatible.ttf: Write failed
nerd-fonts-1.2.0/patched-fonts/Ubuntu/Medium/complete/Ubuntu Medium Nerd Font Complete.ttf: Write failed
nerd-fonts-1.2.0/patched-fonts/Ubuntu/Medium/font-info.md: Write failed
nerd-fonts-1.2.0/patched-fonts/Ubuntu/Medium/readme.md: Write failed
nerd-fonts-1.2.0/patched-fonts/Ubuntu/Regular-Italic/complete/Ubuntu Italic Nerd Font Complete Mono Windows Compatible.ttf: Write failed
nerd-fonts-1.2.0/patched-fonts/Ubuntu/Regular-Italic/complete/Ubuntu Italic Nerd Font Complete Mono.ttf: Write failed
nerd-fonts-1.2.0/patched-fonts/Ubuntu/Regular-Italic/complete/Ubuntu Italic Nerd Font Complete Windows Compatible.ttf: Write failed
nerd-fonts-1.2.0/patched-fonts/Ubuntu/Regular-Italic/complete/Ubuntu Italic Nerd Font Complete.ttf: Write failed
nerd-fonts-1.2.0/patched-fonts/Ubuntu/Regular-Italic/font-info.md: Write failed
nerd-fonts-1.2.0/patched-fonts/Ubuntu/Regular-Italic/readme.md: Write failed
nerd-fonts-1.2.0/patched-fonts/Ubuntu/Regular/complete/Ubuntu Nerd Font Complete Mono Windows Compatible.ttf: Write failed
nerd-fonts-1.2.0/patched-fonts/Ubuntu/Regular/complete/Ubuntu Nerd Font Complete Mono.ttf: Write failed
nerd-fonts-1.2.0/patched-fonts/Ubuntu/Regular/complete/Ubuntu Nerd Font Complete Windows Compatible.ttf: Write failed
nerd-fonts-1.2.0/patched-fonts/Ubuntu/Regular/complete/Ubuntu Nerd Font Complete.ttf: Write failed
nerd-fonts-1.2.0/patched-fonts/Ubuntu/Regular/font-info.md: Write failed
nerd-fonts-1.2.0/patched-fonts/Ubuntu/Regular/readme.md: Write failed
nerd-fonts-1.2.0/patched-fonts/Ubuntu/font-info.md: Write failed
nerd-fonts-1.2.0/patched-fonts/Ubuntu/readme.md: Write failed
nerd-fonts-1.2.0/patched-fonts/UbuntuMono/Bold-Italic/complete/Ubuntu Mono Bold Italic Nerd Font Complete Mono Windows Compatible.ttf: Write failed
nerd-fonts-1.2.0/patched-fonts/UbuntuMono/Bold-Italic/complete/Ubuntu Mono Bold Italic Nerd Font Complete Mono.ttf: Write failed
nerd-fonts-1.2.0/patched-fonts/UbuntuMono/Bold-Italic/complete/Ubuntu Mono Bold Italic Nerd Font Complete Windows Compatible.ttf: Write failed
nerd-fonts-1.2.0/patched-fonts/UbuntuMono/Bold-Italic/complete/Ubuntu Mono Bold Italic Nerd Font Complete.ttf: Write failed
nerd-fonts-1.2.0/patched-fonts/UbuntuMono/Bold-Italic/font-info.md: Write failed
nerd-fonts-1.2.0/patched-fonts/UbuntuMono/Bold-Italic/readme.md: Write failed
nerd-fonts-1.2.0/patched-fonts/UbuntuMono/Bold/complete/Ubuntu Mono Bold Nerd Font Complete Mono Windows Compatible.ttf: Write failed
nerd-fonts-1.2.0/patched-fonts/UbuntuMono/Bold/complete/Ubuntu Mono Bold Nerd Font Complete Mono.ttf: Write failed
nerd-fonts-1.2.0/patched-fonts/UbuntuMono/Bold/complete/Ubuntu Mono Bold Nerd Font Complete Windows Compatible.ttf: Write failed
nerd-fonts-1.2.0/patched-fonts/UbuntuMono/Bold/complete/Ubuntu Mono Bold Nerd Font Complete.ttf: Write failed
nerd-fonts-1.2.0/patched-fonts/UbuntuMono/Bold/font-info.md: Write failed
nerd-fonts-1.2.0/patched-fonts/UbuntuMono/Bold/readme.md: Write failed
nerd-fonts-1.2.0/patched-fonts/UbuntuMono/Regular-Italic/complete/Ubuntu Mono Italic Nerd Font Complete Mono Windows Compatible.ttf: Write failed
nerd-fonts-1.2.0/patched-fonts/UbuntuMono/Regular-Italic/complete/Ubuntu Mono Italic Nerd Font Complete Mono.ttf: Write failed
nerd-fonts-1.2.0/patched-fonts/UbuntuMono/Regular-Italic/complete/Ubuntu Mono Italic Nerd Font Complete Windows Compatible.ttf: Write failed
nerd-fonts-1.2.0/patched-fonts/UbuntuMono/Regular-Italic/complete/Ubuntu Mono Italic Nerd Font Complete.ttf: Write failed
nerd-fonts-1.2.0/patched-fonts/UbuntuMono/Regular-Italic/font-info.md: Write failed
nerd-fonts-1.2.0/patched-fonts/UbuntuMono/Regular-Italic/readme.md: Write failed
nerd-fonts-1.2.0/patched-fonts/UbuntuMono/Regular/complete/Ubuntu Mono Nerd Font Complete Mono Windows Compatible.ttf: Write failed
nerd-fonts-1.2.0/patched-fonts/UbuntuMono/Regular/complete/Ubuntu Mono Nerd Font Complete Mono.ttf: Write failed
nerd-fonts-1.2.0/patched-fonts/UbuntuMono/Regular/complete/Ubuntu Mono Nerd Font Complete Windows Compatible.ttf: Write failed
nerd-fonts-1.2.0/patched-fonts/UbuntuMono/Regular/complete/Ubuntu Mono Nerd Font Complete.ttf: Write failed
nerd-fonts-1.2.0/patched-fonts/UbuntuMono/Regular/font-info.md: Write failed
nerd-fonts-1.2.0/patched-fonts/UbuntuMono/Regular/readme.md: Write failed
nerd-fonts-1.2.0/patched-fonts/UbuntuMono/font-info.md: Write failed
nerd-fonts-1.2.0/patched-fonts/UbuntuMono/readme.md: Write failed
nerd-fonts-1.2.0/readme.md: Write failed
nerd-fonts-1.2.0/readme_cn.md: Write failed
nerd-fonts-1.2.0/readme_ru.md: Write failed
nerd-fonts-1.2.0/src/glyphs/FontAwesome.otf: Write failed
nerd-fonts-1.2.0/src/glyphs/NerdFontsSymbols 1000 EM Nerd Font Complete Blank.sfd: Write failed
nerd-fonts-1.2.0/src/glyphs/NerdFontsSymbols 2048 EM Nerd Font Complete Blank.sfd: Write failed
nerd-fonts-1.2.0/src/glyphs/Pomicons.otf: Write failed
nerd-fonts-1.2.0/src/glyphs/PowerlineExtraSymbols.otf: Write failed
nerd-fonts-1.2.0/src/glyphs/PowerlineSymbols.otf: Write failed
nerd-fonts-1.2.0/src/glyphs/Symbols-1000-em Nerd Font Complete.ttf: Write failed
nerd-fonts-1.2.0/src/glyphs/Symbols-2048-em Nerd Font Complete.ttf: Write failed
nerd-fonts-1.2.0/src/glyphs/Unicode_IEC_symbol_font.otf: Write failed
nerd-fonts-1.2.0/src/glyphs/devicons.ttf: Write failed
nerd-fonts-1.2.0/src/glyphs/font-awesome-extension.ttf: Write failed
nerd-fonts-1.2.0/src/glyphs/font-linux.ttf: Write failed
nerd-fonts-1.2.0/src/glyphs/octicons.ttf: Write failed
nerd-fonts-1.2.0/src/glyphs/original-source.otf: Write failed
nerd-fonts-1.2.0/src/readme-per-directory-addendum.md: Write failed
nerd-fonts-1.2.0/src/readme-per-directory-variations.md: Write failed
nerd-fonts-1.2.0/src/readme-rfn-addendum.md: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/3270/LICENSE.txt: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/3270/Medium/3270Medium.afm: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/3270/Medium/3270Medium.otf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/3270/Medium/3270Medium.pfm: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/3270/Medium/3270Medium.ttf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/3270/Medium/3270Medium.woff: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/3270/Narrow/3270Narrow.afm: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/3270/Narrow/3270Narrow.g2n: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/3270/Narrow/3270Narrow.otf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/3270/Narrow/3270Narrow.pfm: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/3270/Narrow/3270Narrow.ttf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/3270/Narrow/3270Narrow.woff: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/AnonymousPro/Anonymice Powerline.ttf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/AnonymousPro/LICENSE.txt: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/AnonymousPro/README.rst: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/AnonymousPro/config.cfg: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Arimo/Bold-Italic/Arimo-BoldItalic.ttf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Arimo/Bold/Arimo-Bold.ttf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Arimo/Italic/Arimo-Italic.ttf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Arimo/LICENSE.txt: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Arimo/Regular/Arimo-Regular.ttf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/AurulentSansMono/AurulentSansMono-Regular.otf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/AurulentSansMono/SIL Open Font License.txt: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/BitstreamVeraSansMono/Bitstream Vera License.txt: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/BitstreamVeraSansMono/Bold-Italic/VeraMono-Bold-Italic.ttf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/BitstreamVeraSansMono/Bold/VeraMono-Bold.ttf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/BitstreamVeraSansMono/Italic/VeraMono-Italic.ttf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/BitstreamVeraSansMono/Regular/VeraMono.ttf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/CodeNewRoman/Code New Roman-Bold.otf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/CodeNewRoman/Code New Roman-Italic.otf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/CodeNewRoman/Code New Roman-Regular.otf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/CodeNewRoman/CodeNewRoman-BETA.otf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/CodeNewRoman/license.txt: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Cousine/Bold/Cousine-Bold.ttf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Cousine/BoldItalic/Cousine-BoldItalic.ttf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Cousine/Italic/Cousine-Italic.ttf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Cousine/LICENSE.txt: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Cousine/Regular/Cousine-Regular.ttf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/DejaVuSansMono/Bold-Italic/DejaVuSansMono-BoldOblique.ttf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/DejaVuSansMono/Bold/DejaVuSansMono-Bold.ttf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/DejaVuSansMono/Italic/DejaVuSansMono-Oblique.ttf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/DejaVuSansMono/LICENSE.txt: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/DejaVuSansMono/README.md: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/DejaVuSansMono/Regular/DejaVuSansMono.ttf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/DroidSansMono/Droid Sans Mono for Powerline.otf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/DroidSansMono/LICENSE.txt: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/DroidSansMono/README.rst: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/DroidSansMono/config.cfg: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/FantasqueSansMono/Bold-Italic/FantasqueSansMono-BoldItalic.ttf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/FantasqueSansMono/Bold/FantasqueSansMono-Bold.ttf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/FantasqueSansMono/Italic/FantasqueSansMono-Italic.ttf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/FantasqueSansMono/OFL.txt: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/FantasqueSansMono/README.md: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/FantasqueSansMono/Regular/FantasqueSansMono-Regular.ttf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/FantasqueSansMono/config.cfg: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/FiraCode/Bold/FiraCode-Bold.otf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/FiraCode/LICENSE.txt: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/FiraCode/Light/FiraCode-Light.otf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/FiraCode/Medium/FiraCode-Medium.otf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/FiraCode/README.rst: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/FiraCode/Regular/FiraCode-Regular.otf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/FiraCode/Retina/FiraCode-Retina.otf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/FiraCode/config.cfg: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/FiraMono/Bold/FuraMono-Bold Powerline.otf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/FiraMono/LICENSE.txt: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/FiraMono/Medium/FuraMono-Medium Powerline.otf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/FiraMono/README.rst: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/FiraMono/Regular/FuraMono-Regular Powerline.otf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/FiraMono/config.cfg: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/FiraMono/fonts.dir: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/FiraMono/fonts.scale: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Go-Mono/Go-Mono-Bold-Italic.ttf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Go-Mono/Go-Mono-Bold.ttf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Go-Mono/Go-Mono-Italic.ttf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Go-Mono/Go-Mono.ttf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Go-Mono/LICENSE.txt: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Go-Mono/README.rst: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Gohu/COPYING-LICENSE.txt: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Gohu/GohuFont-Bold.ttf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Gohu/GohuFont-Medium.ttf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Hack/Bold/Hack-Bold.ttf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Hack/BoldItalic/Hack-BoldItalic.ttf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Hack/Italic/Hack-Italic.ttf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Hack/LICENSE.md: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Hack/README.md: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Hack/Regular/Hack-Regular.ttf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Hack/config.cfg: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Hasklig/Black-Italic/Hasklig-BlackIt.otf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Hasklig/Black/Hasklig-Black.otf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Hasklig/Bold-Italic/Hasklig-BoldIt.otf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Hasklig/Bold/Hasklig-Bold.otf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Hasklig/Extra-Light-Italic/Hasklig-ExtraLightIt.otf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Hasklig/Extra-Light/Hasklig-ExtraLight.otf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Hasklig/Italic/Hasklig-It.otf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Hasklig/LICENSE.txt: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Hasklig/Light-Italic/Hasklig-LightIt.otf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Hasklig/Light/Hasklig-Light.otf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Hasklig/Medium-Italic/Hasklig-MediumIt.otf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Hasklig/Medium/Hasklig-Medium.otf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Hasklig/OFL.txt: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Hasklig/README.md: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Hasklig/Regular/Hasklig-Regular.otf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Hasklig/Semibold-Italic/Hasklig-SemiboldIt.otf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Hasklig/Semibold/Hasklig-Semibold.otf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Hasklig/config.cfg: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/HeavyData/Vic Fieger License.txt: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/HeavyData/heavy_data.ttf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Hermit/Bold/Hermit-bold.otf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Hermit/LICENSE: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Hermit/Light/Hermit-light.otf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Hermit/Medium/Hermit-medium.otf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Hermit/config.cfg: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Inconsolata/Inconsolata for Powerline.otf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Inconsolata/LICENSE.txt: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Inconsolata/README.rst: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Inconsolata/config.cfg: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Inconsolata/fonts.dir: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Inconsolata/fonts.scale: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/InconsolataGo/InconsolataGo-Bold.sfd: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/InconsolataGo/InconsolataGo-Bold.ttf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/InconsolataGo/InconsolataGo-Regular.sfd: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/InconsolataGo/InconsolataGo-Regular.ttf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/InconsolataGo/OFL.txt: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/InconsolataGo/README.md: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/InconsolataLGC/Inconsolata-LGC-Bold.ttf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/InconsolataLGC/Inconsolata-LGC-BoldItalic.ttf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/InconsolataLGC/Inconsolata-LGC-Italic.ttf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/InconsolataLGC/Inconsolata-LGC.ttf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/InconsolataLGC/LICENSE: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/InconsolataLGC/readme.txt: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Iosevka/Bold-Italic/iosevka-bolditalic.ttf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Iosevka/Bold-Oblique/iosevka-boldoblique.ttf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Iosevka/Bold/iosevka-bold.ttf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Iosevka/Extra-Light-Italic/iosevka-extralightitalic.ttf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Iosevka/Extra-Light-Oblique/iosevka-extralightoblique.ttf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Iosevka/Extra-Light/iosevka-extralight.ttf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Iosevka/Heavy-Italic/iosevka-heavyitalic.ttf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Iosevka/Heavy-Oblique/iosevka-heavyoblique.ttf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Iosevka/Heavy/iosevka-heavy.ttf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Iosevka/Italic/iosevka-italic.ttf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Iosevka/LICENSE: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Iosevka/Light-Italic/iosevka-lightitalic.ttf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Iosevka/Light-Oblique/iosevka-lightoblique.ttf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Iosevka/Light/iosevka-light.ttf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Iosevka/Medium-Italic/iosevka-mediumitalic.ttf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Iosevka/Medium-Oblique/iosevka-mediumoblique.ttf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Iosevka/Medium/iosevka-medium.ttf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Iosevka/Oblique/iosevka-oblique.ttf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Iosevka/Regular/iosevka-regular.ttf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Iosevka/Thin-Italic/iosevka-thinitalic.ttf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Iosevka/Thin-Oblique/iosevka-thinoblique.ttf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Iosevka/Thin/iosevka-thin.ttf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Iosevka/config.cfg: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Lekton/Bold/Lekton-Bold.ttf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Lekton/Italic/Lekton-Italic.ttf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Lekton/Regular/Lekton-Regular.ttf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Lekton/SIL Open Font License.txt: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/LiberationMono/LICENSE.txt: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/LiberationMono/Literation Mono Powerline.ttf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/LiberationMono/README.rst: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/LiberationMono/config.cfg: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/MPlus/Bold/mplus-1m-bold.ttf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/MPlus/Light/mplus-1m-light.ttf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/MPlus/M+ Fonts License.txt: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/MPlus/Medium/mplus-1m-medium.ttf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/MPlus/Regular/mplus-1m-regular.ttf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/MPlus/Thin/mplus-1m-thin.ttf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Meslo/L-DZ/Meslo LG L DZ Regular for Powerline.otf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Meslo/L/Meslo LG L Regular for Powerline.otf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Meslo/LICENSE.txt: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Meslo/M-DZ/Meslo LG M DZ Regular for Powerline.otf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Meslo/M/Meslo LG M Regular for Powerline.otf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Meslo/README.rst: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Meslo/S-DZ/Meslo LG S DZ Regular for Powerline.otf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Meslo/S/Meslo LG S Regular for Powerline.otf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Meslo/config.cfg: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Meslo/fonts.dir: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Meslo/fonts.scale: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Monofur/Bold/Monofur Bold for Powerline.ttf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Monofur/Italic/Monofur Italic for Powerline.ttf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Monofur/LICENSE.txt: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Monofur/Regular/Monofur for Powerline.ttf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Monofur/config.cfg: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Monoid/Monoid-Bold.ttf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Monoid/Monoid-Italic.ttf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Monoid/Monoid-Regular.ttf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Monoid/Monoid-Retina.ttf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Monoid/Readme+License.html: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Mononoki/LICENSE.txt: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Mononoki/mononoki-Bold.ttf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Mononoki/mononoki-BoldItalic.ttf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Mononoki/mononoki-Italic.ttf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Mononoki/mononoki-Regular.ttf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/ProFont/ProFontWinTweaked/Comments for ProFontWindows: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/ProFont/ProFontWinTweaked/LICENSE: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/ProFont/ProFontWinTweaked/ProFontWindows.ttf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/ProFont/ProFontWinTweaked/readme.txt: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/ProFont/profont-x11/LICENSE: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/ProFont/profont-x11/ProFont_r400-10.pcf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/ProFont/profont-x11/ProFont_r400-11.pcf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/ProFont/profont-x11/ProFont_r400-12.pcf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/ProFont/profont-x11/ProFont_r400-15.pcf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/ProFont/profont-x11/ProFont_r400-17.pcf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/ProFont/profont-x11/ProFont_r400-22.pcf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/ProFont/profont-x11/ProFont_r400-29.pcf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/ProFont/profont-x11/readme.txt: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/ProFont/profontiix/LICENSE: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/ProFont/profontiix/ProFontIIx.ttf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/ProggyClean/Latin2/ProggyCleanCE.ttf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/ProggyClean/Licence.txt: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/ProggyClean/Readme.txt: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/ProggyClean/Regular/ProggyClean.ttf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/ProggyClean/SlashedZero/ProggyCleanSZ.ttf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/RobotoMono/LICENSE.txt: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/RobotoMono/RobotoMono-Bold.ttf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/RobotoMono/RobotoMono-BoldItalic.ttf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/RobotoMono/RobotoMono-Italic.ttf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/RobotoMono/RobotoMono-Light.ttf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/RobotoMono/RobotoMono-LightItalic.ttf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/RobotoMono/RobotoMono-Medium.ttf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/RobotoMono/RobotoMono-MediumItalic.ttf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/RobotoMono/RobotoMono-Regular.ttf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/RobotoMono/RobotoMono-Thin.ttf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/RobotoMono/RobotoMono-ThinItalic.ttf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/ShareTechMono/OFL.txt: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/ShareTechMono/ShareTechMono-Regular.ttf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/ShareTechMono/config.cfg: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/SourceCodePro/Black/SourceCodePro-Black.ttf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/SourceCodePro/Bold/SourceCodePro-Bold.ttf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/SourceCodePro/Extra-Light/SourceCodePro-ExtraLight.ttf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/SourceCodePro/LICENSE.txt: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/SourceCodePro/Light/SourceCodePro-Light.ttf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/SourceCodePro/Medium/SourceCodePro-Medium.ttf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/SourceCodePro/OFL.txt: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/SourceCodePro/README.rst: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/SourceCodePro/Regular/SourceCodePro-Regular.ttf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/SourceCodePro/Semibold/SourceCodePro-Semibold.ttf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/SourceCodePro/config.cfg: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/SpaceMono/OFL.txt: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/SpaceMono/SpaceMono-Bold.ttf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/SpaceMono/SpaceMono-BoldItalic.ttf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/SpaceMono/SpaceMono-Italic.ttf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/SpaceMono/SpaceMono-Regular.ttf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Terminus/BDF/fonts.dir: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Terminus/BDF/ter-powerline-x12b.bdf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Terminus/BDF/ter-powerline-x12n.bdf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Terminus/BDF/ter-powerline-x14b.bdf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Terminus/BDF/ter-powerline-x14n.bdf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Terminus/BDF/ter-powerline-x16b.bdf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Terminus/BDF/ter-powerline-x16n.bdf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Terminus/BDF/ter-powerline-x18b.bdf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Terminus/BDF/ter-powerline-x18n.bdf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Terminus/BDF/ter-powerline-x20b.bdf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Terminus/BDF/ter-powerline-x20n.bdf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Terminus/BDF/ter-powerline-x22b.bdf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Terminus/BDF/ter-powerline-x22n.bdf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Terminus/BDF/ter-powerline-x24b.bdf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Terminus/BDF/ter-powerline-x24n.bdf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Terminus/BDF/ter-powerline-x28b.bdf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Terminus/BDF/ter-powerline-x28n.bdf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Terminus/BDF/ter-powerline-x32b.bdf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Terminus/BDF/ter-powerline-x32n.bdf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Terminus/LICENSE.txt: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Terminus/PCF/fonts.dir: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Terminus/PCF/ter-powerline-x12b.pcf.gz: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Terminus/PCF/ter-powerline-x12n.pcf.gz: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Terminus/PCF/ter-powerline-x14b.pcf.gz: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Terminus/PCF/ter-powerline-x14n.pcf.gz: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Terminus/PCF/ter-powerline-x16b.pcf.gz: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Terminus/PCF/ter-powerline-x16n.pcf.gz: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Terminus/PCF/ter-powerline-x18b.pcf.gz: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Terminus/PCF/ter-powerline-x18n.pcf.gz: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Terminus/PCF/ter-powerline-x20b.pcf.gz: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Terminus/PCF/ter-powerline-x20n.pcf.gz: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Terminus/PCF/ter-powerline-x22b.pcf.gz: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Terminus/PCF/ter-powerline-x22n.pcf.gz: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Terminus/PCF/ter-powerline-x24b.pcf.gz: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Terminus/PCF/ter-powerline-x24n.pcf.gz: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Terminus/PCF/ter-powerline-x28b.pcf.gz: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Terminus/PCF/ter-powerline-x28n.pcf.gz: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Terminus/PCF/ter-powerline-x32b.pcf.gz: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Terminus/PCF/ter-powerline-x32n.pcf.gz: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Terminus/PSF/README.markdown: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Terminus/PSF/ter-powerline-v12n.psf.gz: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Terminus/PSF/ter-powerline-v14b.psf.gz: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Terminus/PSF/ter-powerline-v14n.psf.gz: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Terminus/PSF/ter-powerline-v14v.psf.gz: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Terminus/PSF/ter-powerline-v16b.psf.gz: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Terminus/PSF/ter-powerline-v16n.psf.gz: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Terminus/PSF/ter-powerline-v16v.psf.gz: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Terminus/PSF/ter-powerline-v18b.psf.gz: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Terminus/PSF/ter-powerline-v18n.psf.gz: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Terminus/PSF/ter-powerline-v20b.psf.gz: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Terminus/PSF/ter-powerline-v20n.psf.gz: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Terminus/PSF/ter-powerline-v22b.psf.gz: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Terminus/PSF/ter-powerline-v22n.psf.gz: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Terminus/PSF/ter-powerline-v24b.psf.gz: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Terminus/PSF/ter-powerline-v24n.psf.gz: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Terminus/PSF/ter-powerline-v28b.psf.gz: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Terminus/PSF/ter-powerline-v28n.psf.gz: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Terminus/PSF/ter-powerline-v32b.psf.gz: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Terminus/PSF/ter-powerline-v32n.psf.gz: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Terminus/README.rst: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Terminus/config.cfg: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Terminus/terminus-ttf-4.40.1/Bold/TerminusTTF-Bold-4.40.1.ttf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Terminus/terminus-ttf-4.40.1/BoldItalic/TerminusTTF-Bold Italic-4.40.1.ttf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Terminus/terminus-ttf-4.40.1/COPYING: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Terminus/terminus-ttf-4.40.1/Italic/TerminusTTF-Italic-4.40.1.ttf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Terminus/terminus-ttf-4.40.1/Regular/TerminusTTF-4.40.1.ttf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Tinos/Apache License.txt: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Tinos/Tinos-Bold.ttf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Tinos/Tinos-BoldItalic.ttf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Tinos/Tinos-Italic.ttf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Tinos/Tinos-Regular.ttf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Tinos/readme.rst: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Ubuntu/Bold-Italic/Ubuntu-BI.ttf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Ubuntu/Bold/Ubuntu-B.ttf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Ubuntu/CONTRIBUTING.txt: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Ubuntu/Condensed/Ubuntu-C.ttf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Ubuntu/FONTLOG.txt: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Ubuntu/LICENCE-FAQ.txt: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Ubuntu/LICENCE.txt: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Ubuntu/Light-Italic/Ubuntu-LI.ttf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Ubuntu/Light/Ubuntu-L.ttf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Ubuntu/Medium-Italic/Ubuntu-MI.ttf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Ubuntu/Medium/Ubuntu-M.ttf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Ubuntu/README.txt: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Ubuntu/Regular-Italic/Ubuntu-RI.ttf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Ubuntu/Regular/Ubuntu-R.ttf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Ubuntu/TRADEMARKS.txt: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Ubuntu/config.cfg: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/Ubuntu/copyright.txt: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/UbuntuMono/Bold-Italic/UbuntuMono-BI.ttf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/UbuntuMono/Bold/UbuntuMono-B.ttf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/UbuntuMono/CONTRIBUTING.txt: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/UbuntuMono/FONTLOG.txt: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/UbuntuMono/LICENCE-FAQ.txt: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/UbuntuMono/LICENCE.txt: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/UbuntuMono/README.txt: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/UbuntuMono/Regular-Italic/UbuntuMono-RI.ttf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/UbuntuMono/Regular/UbuntuMono-R.ttf: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/UbuntuMono/TRADEMARKS.txt: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/UbuntuMono/config.cfg: Write failed
nerd-fonts-1.2.0/src/unpatched-fonts/UbuntuMono/copyright.txt: Write failed
bsdtar: Error exit delayed from previous errors.
==> ERROR: Failed to extract nerd-fonts-complete-1.2.0.tar.gz
    Aborting...
==> ERROR: Makepkg was unable to build nerd-fonts-complete.
==> Restart building nerd-fonts-complete ? [y/N]
==> [linus@ASUS-550kl i3wm-themer]$
#33
Hello sir,
First of all, dumping 1092 lines of terminal output is not really that helpful at all. Other than that, I just saw that β€˜nerd-fonts-complete’ got a recent updated which I was not aware of, so I would look for an answer there.
Generally did you try installing the requirements yourself? The packages that are needed are all mentioned in the README.md in the repos, so installing them manually is not really that impossible.
