Newbie to Linux here. I can see that conky_maia is being started in the the i3 config file, but I can’t find anything about conky1.10_shortcuts_maia. What is causing it to run on startup?
Welcome to the Forum!
In the i3 config file an executable called start_conky_maia
is executed at startup:
This is a file that can be found in the /usr/bin/
directory and its contents are:
#!/bin/bash
conky -c /usr/share/conky/conky1.10_shortcuts_maia &&
conky -c /usr/share/conky/conky_maia &&
exit 0
As you can see, this executable calls two instances of Conky, one of them refers to the shortcuts you mentioned.
Thank you
Thank you for your thank you so I’ve marked the below answer as the solution to your question as it is by far the best answer you’ll get.
However, if you disagree with my choice, please feel free to take any other answer as the solution to your question or even remove the solution altogether: You are in control! (I just want to avoid even more subjective opinions being posted and confusing you even more)
P.S. In the future, please mark a solution like this:
