The instructions on the wiki state to run pamac install manjaro-printer
but this results in “Error: target not found: manjaro-printer”.
Any suggestions?
Any suggestions?
I suggest you install cups and then try configuring it at localhost:631
I have CUPS installed: Manage Printing (cups) 2.3.3-3
However, on KDE when launching “Manage Printing (CUPS Web Interface)” I receive:
“Could not connect to host localhost: Connection refused”.
I do not have a firewall running (other than the out-of-the-box iptables configuration).
I am unable to reach localhost:631 in the browser.
ping localhost
succeeds.
curl localhost:631 -v
returns:
connect to 127.0.0.1 port 631 failed: Connection refused
systemctl —type=service
does not contain any CUPS entries. So, I don’t think there is anything running to respond to the “localhost:631” requests. Is there something I need to do with systemd commands perhaps?
What I was missing:
sudo systemctl enable —now org.cups.cupsd.service
I was then able to use localhost:631
to configure the printer connection.
