I3 on raspberry pi?
#1
Hi. I'm fairly new to Linux. How do I get Manjaro i3 edition on my Raspberry Pi? Can I just use Rufus the burn the iso on the sd card?
#2
Moved from #technical-issues-and-assistance:hardware to #manjaro-arm because it is about RPi support.
#3
RPI is based on a ARM v8 CPU. You will need a specialized build, which then can be burned to the RPI storage medium (sd card).
#4
We don't provide an image of i3 for the raspberry pi, but it is available to create an SD card from, with the manjaro-arm-installer that can be installed from the repo.
