I currently have a PC, Laptop and 2 RPI4’s.
At the moment I run i3wm on all of them.
I know that i3 is no longer maintained and seeing as I have four instances of
it, this bothers me a bit.
Up to now I still get all the BIG updates (and the little one’s) and everything
seems to run OK.
Question 1.
Am I right in thinking that it’s only the “i3 stuff” that is not updated ?
(If that’s the case then I will stay with i3 until; it breaks into a heap).
Question 2.
Is SWAY the “new” i3, I see it is supported in x86 and ARM ?
(I could move to SWAY, it seems i3’ish and I can prolly make it play nicely).
Also, I know that @bittin1 maintains “Awesome” so perhaps that could also work for me.
Any Thoughts ???
if your already use to i3, than it’s easy swapping over to sway.
sway is a lot more flexible then i3.
just add the keyboard shortcuts for firefox & file manager(default nautilus).
i’ve swapped out nautilus & gedit for pcmanfm-gtk3 & mousepad on mine.
everything else is easy to learn.
i’m currently on a rpi4 4gb.
Thanks for the info, I think I will try sway on my laptop and see how it goes.
I can iron out the wrinkles and figure a simple hopefully mainly automated way of reinstalling on my
MAIN pc.
Then the 2 RPI’s which are separate servers with different configs etc.
Hmm. Big job re-installing 4 machines. I’ll take my time and get it right hopefully.
Many thanks.
z0id
11 July 2021 06:26
5
Hello.
What do you mean by that? Not maintained by the developers anymore?
Regards,
z0id
