Always happy with Manjaro and not close to change, I am having a strange problem since the last update.
My Thinkpad T460 is placed on a docking station to which an external display is connected (VGA socket because old SyncMaster 2253 display).
Everything worked fine but since the last update, I had no internet speed (my wifi connects well, nothing has changed at this level). Eerything works when I remove the pc from the docking station.
While testing, the problem only occurs when the vga jack is plugged into the docking station and the external screen used.
So I have the choice between having internet, or having a second screen (necessary to work).
