When trying to pacman build ncurses5-compat-libs
I get the following error message, which seems to be related to gpg but likely isn’t?
==> Making package: ncurses5-compat-libs 6.2-1 (Di 16 Nov 2021 15:51:06)
==> Retrieving sources...
-> Downloading ncurses-6.2.tar.gz...
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
100 3345k 100 3345k 0 0 2497k 0 0:00:01 0:00:01 --:--:-- 2496k
-> Downloading ncurses-6.2.tar.gz.sig...
100 95 100 95 0 0 238 0 --:--:-- --:--:-- --:--:-- 238
ncurses-6.2.tar.gz ... Passed
ncurses-6.2.tar.gz.sig ... Skipped
==> Verifying source file signatures with gpg...
ncurses-6.2.tar.gz ... cat: write error: Broken pipe
FAILED
==> ERROR: One or more PGP signatures could not be verified!
Finished with result: exit-code
Main processes terminated with: code=exited/status=1
Service runtime: 3.494s
CPU time consumed: 2.047s
Error: Failed to build ncurses5-compat-libs
For context, I’m actually trying to get darktable to run with opencl on my amd gpu using the proprietary amd driver as the open source driver doesn’t provide “Image support”. In this context the opencl-amd AUR package requires ncurses5-compat-libs which I’m unable to build due to the error above. Please do let me know if I’m going down the wrong rabbit hole.
