@pobrn I was using 5.8.12-3
from GitLab
and touch pad is working with it. After updating to kernel 5.8.16-2
the touch pad stopped working. I tried with and without the polling enabled but nothing changed. With kernel 5.8.12-3
the touch pad is working fine. There is one thing with 5.8.12-3
that is strange though. Sometimes when I tap with two or three fingers the touch pad locks that tap and if you try to move the cursor it is scrolling constantly and I cannot click anything with one finger until I tap again with two or three fingers in order for the touch pad to release the tap lock.
Hi,
Using a huawei matebook d14 which has a ELAN2204:00 04F3:30F5 Touchpad.
Noted on kernels 5.8 , 5.9 and even kernels before that the touchpad would freeze after resume from suspend. Its not consistent , sometimes it does not happen. When it happens, the touchpad may work for 30s then freeze.
Reloading the i2c_hid module doesnāt help. Adding the polling option just makes the touchpad completely unusable from start.
Would like to help troubleshoot if i can, though need guidance.
Thank you.
Hi, iām searching for a beginner friendly way to get a working Touchoad on my Legion5. An ISO File would be great. I donāt want to try my luck with building a kernel.
Or can someone point me to a simple solution likeā¦ use this ISO and apply this patch?
