I want to control my laptop fan but sensors-detect only find "coretemp".
My laptop fan is working at 100% speed and i want to slow it down because my laptop is only at 55C. I tried checking for sensors with sensors-detect, adding "acpi_enforce_resources=lax" but nothing helped. My laptop is Toshiba Satellite L670.
  Host: marios-pc Kernel: 5.2.11-1-MANJARO x86_64 bits: 64 compiler: gcc v: 9.1.0
  Desktop: KDE Plasma 5.16.4 Distro: Manjaro Linux
  Type: Laptop System: TOSHIBA product: Satellite L670 v: PSK3EE-00500YG5
  serial: <filter>
  Mobo: TOSHIBA model: NALAA v: 1.00 serial: <filter> UEFI [Legacy]: TOSHIBA v: 2.30
  date: 08/02/11
  Device-1: hidpp_battery_0 model: Logitech Wireless Mouse M185
  charge: 55% (should be ignored) status: Discharging
  Topology: Dual Core model: Intel Core i5 M 430 bits: 64 type: MT MCP arch: Nehalem
  rev: 2 L2 cache: 3072 KiB
  flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 18096
  Speed: 2527 MHz min/max: 1199/2267 MHz Core speeds (MHz): 1: 1694 2: 1645 3: 2503
  4: 1625
  Device-1: AMD Madison [Mobility Radeon HD 5650/5750 / 6530M/6550M]
  vendor: Toshiba America Info Systems driver: radeon v: kernel bus ID: 01:00.0
  Display: x11 server: X.Org 1.20.5 driver: radeon FAILED: ati unloaded: modesetting
  resolution: 1600x900~60Hz
  OpenGL: renderer: AMD REDWOOD (DRM 2.50.0 / 5.2.11-1-MANJARO LLVM 8.0.1)
  v: 3.3 Mesa 19.1.5 direct render: Yes
  Device-1: Intel 5 Series/3400 Series High Definition Audio
  vendor: Toshiba America Info Systems driver: snd_hda_intel v: kernel bus ID: 00:1b.0
  Device-2: AMD Redwood HDMI Audio [Radeon HD 5000 Series]
  vendor: Toshiba America Info Systems driver: snd_hda_intel v: kernel bus ID: 01:00.1
  Sound Server: ALSA v: k5.2.11-1-MANJARO
  Device-1: Realtek RTL810xE PCI Express Fast Ethernet
  vendor: Toshiba America Info Systems driver: r8169 v: kernel port: 3000
  bus ID: 02:00.0
  Device-2: Broadcom and subsidiaries BCM4313 802.11bgn Wireless Network Adapter
  vendor: Askey driver: wl v: kernel port: 3000 bus ID: 07:00.0
  IF: wlp7s0 state: up mac: <filter>
  Local Storage: total: 232.89 GiB used: 12.10 GiB (5.2%)
  ID-1: /dev/sda vendor: Samsung model: SSD 850 EVO 250GB size: 232.89 GiB
  ID-1: / size: 220.18 GiB used: 12.10 GiB (5.5%) fs: ext4 dev: /dev/sda1
  ID-2: swap-1 size: 8.17 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/sda2
  Message: No sensors data was found. Is sensors configured?
  Processes: 208 Uptime: 39m Memory: 3.71 GiB used: 1.81 GiB (48.8%) Init: systemd
  Compilers: gcc: 9.1.0 Shell: bash v: 5.0.9 inxi: 3.0.36
When i use sensors-detect command it shows me this:
# sensors-detect revision $Revision$
# System: TOSHIBA Satellite L670 [PSK3EE-00500YG5] (laptop)
# Board: TOSHIBA NALAA
# Kernel: 5.2.11-1-MANJARO x86_64
# Processor: Intel(R) Core(TM) i5 CPU M 430 @ 2.27GHz (6/37/2)
This program will help you determine which kernel modules you need
to load to use lm_sensors most effectively. It is generally safe
and recommended to accept the default answers to all questions,
unless you know what you're doing.
Some south bridges, CPUs or memory controllers contain embedded sensors.
Do you want to scan for them? This is totally safe. (YES/no): y
Module cpuid loaded successfully.
Silicon Integrated Systems SIS5595...                       No
VIA VT82C686 Integrated Sensors...                          No
VIA VT8231 Integrated Sensors...                            No
AMD K8 thermal sensors...                                   No
AMD Family 10h thermal sensors...                           No
AMD Family 11h thermal sensors...                           No
AMD Family 12h and 14h thermal sensors...                   No
AMD Family 15h thermal sensors...                           No
AMD Family 16h thermal sensors...                           No
AMD Family 17h thermal sensors...                           No
AMD Family 15h power sensors...                             No
AMD Family 16h power sensors...                             No
Intel digital thermal sensor...                             Success!
    (driver `coretemp')
Intel AMB FB-DIMM thermal sensor...                         No
Intel 5500/5520/X58 thermal sensor...                       No
VIA C7 thermal sensor...                                    No
VIA Nano thermal sensor...                                  No
Some Super I/O chips contain embedded sensors. We have to write to
standard I/O ports to probe them. This is usually safe.
Do you want to scan for Super I/O sensors? (YES/no): y
Probing for Super-I/O at 0x2e/0x2f
Trying family `National Semiconductor/ITE'...               No
Trying family `SMSC'...                                     No
Trying family `VIA/Winbond/Nuvoton/Fintek'...               No
Trying family `ITE'...                                      No
Probing for Super-I/O at 0x4e/0x4f
Some hardware monitoring chips are accessible through the ISA I/O ports.
We have to write to arbitrary I/O ports to probe them. This is usually
safe though. Yes, you do have ISA I/O ports even if you do not have any
ISA slots! Do you want to scan the ISA I/O ports? (YES/no): y
Probing for `National Semiconductor LM78' at 0x290...       No
Probing for `National Semiconductor LM79' at 0x290...       No
Probing for `Winbond W83781D' at 0x290...                   No
Probing for `Winbond W83782D' at 0x290...                   No
Lastly, we can probe the I2C/SMBus adapters for connected hardware
monitoring devices. This is the most risky part, and while it works
reasonably well on most systems, it has been reported to cause trouble
on some systems.
Do you want to probe the I2C/SMBus adapters now? (YES/no): yy
Using driver `i2c-i801' for device 0000:00:1f.3: Intel 3400/5 Series (PCH)
Next adapter: SMBus I801 adapter at efa0 (i2c-0)
Do you want to scan it? (YES/no/selectively): y
Next adapter: Radeon i2c bit bus 0x90 (i2c-1)
Do you want to scan it? (yes/NO/selectively): y
Next adapter: Radeon i2c bit bus 0x91 (i2c-2)
Next adapter: Radeon i2c bit bus 0x92 (i2c-3)
Do you want to scan it? (yes/NO/selectively): y.
Next adapter: Radeon i2c bit bus 0x93 (i2c-4)
Next adapter: Radeon i2c bit bus 0x94 (i2c-5)
Next adapter: Radeon i2c bit bus 0x95 (i2c-6)
Client found at address 0x18
Probing for `Analog Devices ADM1021'...                     No
Probing for `Analog Devices ADM1021A/ADM1023'...            No
Probing for `Maxim MAX1617'...                              No
Probing for `Maxim MAX1617A'...                             No
Probing for `Maxim MAX1668'...                              No
Probing for `Maxim MAX1805'...                              No
Probing for `Maxim MAX1989'...                              No
Probing for `Maxim MAX6655/MAX6656'...                      No
Probing for `TI THMC10'...                                  No
Probing for `National Semiconductor LM84'...                No
Probing for `Genesys Logic GL523SM'...                      No
Probing for `Onsemi MC1066'...                              No
Probing for `Maxim MAX1618'...                              No
Probing for `Maxim MAX1619'...                              No
Probing for `National Semiconductor LM82/LM83'...           No
Probing for `Maxim MAX6654'...                              No
Probing for `Maxim MAX6690'...                              No
Probing for `Maxim MAX6680/MAX6681'...                      No
Probing for `Maxim MAX6695/MAX6696'...                      No
Probing for `Texas Instruments TMP400'...                   No
Probing for `Texas Instruments AMC6821'...                  No
Probing for `National Semiconductor LM95233'...             No
Probing for `National Semiconductor LM95234'...             No
Probing for `National Semiconductor LM95235'...             No
Probing for `National Semiconductor LM95245'...             No
Probing for `National Semiconductor LM64'...                No
Probing for `SMSC EMC1047'...                               No
Probing for `SMSC EMC1402'...                               No
Probing for `SMSC EMC1403'...                               No
Probing for `SMSC EMC1404'...                               No
Probing for `ST STTS424'...                                 No
Probing for `ST STTS424E'...                                No
Probing for `ST STTS2002'...                                No
Probing for `ST STTS3000'...                                No
Probing for `NXP SE97/SE97B'...                             No
Probing for `NXP SE98'...                                   No
Probing for `Analog Devices ADT7408'...                     No
Probing for `IDT TS3000/TSE2002'...                         No
Probing for `IDT TSE2004'...                                No
Probing for `IDT TS3001'...                                 No
Probing for `Maxim MAX6604'...                              No
Probing for `Microchip MCP9804'...                          No
Probing for `Microchip MCP9808'...                          No
Probing for `Microchip MCP98242'...                         No
Probing for `Microchip MCP98243'...                         No
Probing for `Microchip MCP98244'...                         No
Probing for `Microchip MCP9843'...                          No
Probing for `ON CAT6095/CAT34TS02'...                       No
Probing for `ON CAT34TS02C'...                              No
Probing for `ON CAT34TS04'...                               No
Probing for `Atmel AT30TS00'...                             No
Probing for `Giantec GT30TS00'...                           No
Client found at address 0x19
Probing for `National Semiconductor LM95231'...             No
Probing for `National Semiconductor LM95241'...             No
Client found at address 0x1a
Client found at address 0x1b
Client found at address 0x1c
Probing for `Texas Instruments TMP421'...                   No
Probing for `Texas Instruments TMP441'...                   No
Probing for `SMSC EMC1072'...                               No
Probing for `SMSC EMC1073'...                               No
Probing for `SMSC EMC1074'...                               No
Client found at address 0x1d
Probing for `TI / National Semiconductor ADC128D818'...     No
Client found at address 0x1e
Client found at address 0x1f
Client found at address 0x28
Probing for `National Semiconductor LM78'...                No
Probing for `National Semiconductor LM79'...                No
Probing for `National Semiconductor LM80'...                No
Probing for `National Semiconductor LM96080'...             No
Probing for `Winbond W83781D'...                            No
Probing for `Winbond W83782D'...                            No
Probing for `Nuvoton NCT7802Y'...                           No
Probing for `Winbond W83627HF'...                           No
Probing for `Winbond W83627EHF'...                          No
Probing for `Winbond W83627DHG/W83667HG/W83677HG'...        No
Probing for `Asus AS99127F (rev.1)'...                      No
Probing for `Asus AS99127F (rev.2)'...                      No
Probing for `Asus ASB100 Bach'...                           No
Probing for `Analog Devices ADM1029'...                     No
Probing for `ITE IT8712F'...                                No
Client found at address 0x29
Client found at address 0x2a
Client found at address 0x2b
Client found at address 0x2c
Probing for `Myson MTP008'...                               No
Probing for `National Semiconductor LM85'...                No
Probing for `National Semiconductor LM96000 or PC8374L'...  No
Probing for `Analog Devices ADM1027'...                     No
Probing for `Analog Devices ADT7460 or ADT7463'...          No
Probing for `SMSC EMC6D100 or EMC6D101'...                  No
Probing for `SMSC EMC6D102'...                              No
Probing for `SMSC EMC6D103'...                              No
Probing for `SMSC EMC6D103S or EMC2300'...                  No
Probing for `SMSC EMC6W201'...                              No
Probing for `Winbond WPCD377I'...                           No
Probing for `Analog Devices ADT7470'...                     No
Probing for `Analog Devices ADT7473'...                     No
Probing for `Analog Devices ADT7476'...                     No
Probing for `Analog Devices ADT7490'...                     No
Probing for `Andigilog aSC7611'...                          No
Probing for `Andigilog aSC7621'...                          No
Probing for `National Semiconductor LM87'...                No
Probing for `Analog Devices ADM1024'...                     No
Probing for `National Semiconductor LM93'...                No
Probing for `National Semiconductor LM94 or LM96194'...     No
Probing for `Winbond W83791D'...                            No
Probing for `Winbond W83792D'...                            No
Probing for `Winbond W83793R/G'...                          No
Probing for `Nuvoton W83795G/ADG'...                        No
Probing for `Genesys Logic GL518SM'...                      No
Probing for `Genesys Logic GL520SM'...                      No
Probing for `Analog Devices ADM9240'...                     No
Probing for `Dallas Semiconductor DS1780'...                No
Probing for `National Semiconductor LM81'...                No
Probing for `Analog Devices ADM1026'...                     No
Probing for `Analog Devices ADM1025'...                     No
Probing for `Philips NE1619'...                             No
Probing for `Maxim MAX6639'...                              No
Probing for `Analog Devices ADM1030'...                     No
Probing for `Analog Devices ADM1031'...                     No
Probing for `Analog Devices ADM1022'...                     No
Probing for `Texas Instruments THMC50'...                   No
Probing for `ALi M5879'...                                  No
Probing for `SMSC LPC47M15x/192/292/997'...                 No
Probing for `SMSC DME1737'...                               No
Probing for `SMSC SCH5027D-NW'...                           No
Probing for `Winbond W83791SD'...                           No
Client found at address 0x2d
Probing for `Winbond W83783S'...                            No
Probing for `Nuvoton NCT7904D'...                           No
Probing for `Winbond W83L784R/AR/G'...                      No
Probing for `Winbond W83L785R/G'...                         No
Probing for `Genesys Logic GL525SM'...                      No
Probing for `VIA VT1211 (I2C)'...                           No
Probing for `Fintek F75373S/SG'...                          No
Probing for `Fintek F75375S/SP'...                          No
Probing for `Fintek F75387SG/RG'...                         No
Client found at address 0x2e
Probing for `Analog Devices ADT7467 or ADT7468'...          No
Probing for `Analog Devices ADT7475'...                     No
Probing for `Winbond W83L786NR/NG/R/G'...                   No
Probing for `Winbond W83L785TS-S'...                        No
Probing for `Analog Devices ADM1028'...                     No
Probing for `Texas Instruments THMC51'...                   No
Probing for `SMSC EMC2103'...                               No
Client found at address 0x2f
Probing for `SMSC EMC2104'...                               No
Probing for `Fintek custom power control IC'...             No
Client found at address 0x48
Probing for `National Semiconductor LM75'...                No
Probing for `National Semiconductor LM75A'...               No
Probing for `Dallas Semiconductor DS75'...                  No
Probing for `National Semiconductor LM77'...                No
Probing for `Analog Devices ADT7410/ADT7420'...             No
Probing for `Analog Devices ADT7411'...                     No
Probing for `Maxim MAX6642'...                              No
Probing for `Texas Instruments TMP435'...                   No
Probing for `National Semiconductor LM73'...                No
Probing for `National Semiconductor LM92'...                No
Probing for `National Semiconductor LM76'...                No
Probing for `Maxim MAX6633/MAX6634/MAX6635'...              No
Probing for `NXP/Philips SA56004'...                        No
Probing for `SMSC EMC1023'...                               No
Probing for `SMSC EMC1043'...                               No
Probing for `SMSC EMC1053'...                               No
Probing for `SMSC EMC1063'...                               No
Client found at address 0x49
Client found at address 0x4a
Client found at address 0x4b
Probing for `Analog Devices ADT7481'...                     No
Client found at address 0x4c
Probing for `Analog Devices ADT7466'...                     No
Probing for `Andigilog aSC7511'...                          No
Probing for `Global Mixed-mode Technology G781'...          No
Probing for `National Semiconductor LM90'...                No
Probing for `National Semiconductor LM89/LM99'...           No
Probing for `National Semiconductor LM86'...                No
Probing for `Analog Devices ADM1032'...                     No
Probing for `Maxim MAX6657/MAX6658/MAX6659'...              No
Probing for `Maxim MAX6648/MAX6649/MAX6692'...              No
Probing for `Winbond W83L771W/G'...                         No
Probing for `Winbond W83L771AWG/ASG'...                     No
Probing for `Texas Instruments TMP401'...                   No
Probing for `Texas Instruments TMP411A'...                  No
Probing for `Texas Instruments TMP422'...                   No
Probing for `Texas Instruments TMP423'...                   No
Probing for `Texas Instruments TMP431'...                   No
Probing for `Texas Instruments TMP432'...                   No
Probing for `Texas Instruments TMP442'...                   No
Probing for `Texas Instruments TMP451'...                   No
Probing for `National Semiconductor LM63'...                No
Probing for `National Semiconductor LM96163'...             No
Probing for `Fintek F75363SG'...                            No
Probing for `Analog Devices ADT7461'...                     No
Probing for `Analog Devices ADT7461A, ON Semiconductor NCT1008'... No
Probing for `Fintek F75383S/M'...                           No
Probing for `SMSC EMC1002'...                               No
Probing for `SMSC EMC1033'...                               No
Probing for `SMSC EMC1046'...                               No
Probing for `SMSC EMC1422'...                               No
Probing for `SMSC EMC1423'...                               No
Probing for `SMSC EMC1424'...                               No
Client found at address 0x4d
Probing for `Maxim MAX6659'...                              No
Probing for `Maxim MAX6646'...                              No
Probing for `Texas Instruments TMP411B'...                  No
Probing for `Fintek F75384S/M'...                           No
Client found at address 0x4e
Probing for `Maxim MAX6647'...                              No
Probing for `Texas Instruments TMP411C'...                  No
Probing for `Fintek F75121R/F75122R/RG (VID+GPIO)'...       No
Probing for `Fintek F75111R/RG/N (GPIO)'...                 No
Probing for `ITE IT8201R/IT8203R/IT8206R/IT8266R'...        No
Client found at address 0x77
Probing for `Asus Mozart-2'...                              No
Next adapter: Radeon i2c bit bus 0x96 (i2c-7)
Next adapter: Radeon i2c bit bus 0x97 (i2c-8)
Now follows a summary of the probes I have just done.
Just press ENTER to continue:
Driver `coretemp':
  * Chip `Intel digital thermal sensor' (confidence: 9)
Do you want to overwrite /etc/conf.d/lm_sensors? (YES/no): y
Unloading cpuid... OK
And sensors command shows me:
coretemp-isa-0000
Adapter: ISA adapter
Core 0:       +57.0°C  (high = +95.0°C, crit = +105.0°C)
Core 2:       +53.0°C  (high = +95.0°C, crit = +105.0°C)
radeon-pci-0100
Adapter: PCI adapter
temp1:        +62.0°C  (crit = +120.0°C, hyst = +90.0°C)
Can anyone help me please? (Sorry for my bad English)
This is common on laptops. There are several alternatives you can try. I personally use nbfc (available on AUR - github).
I tried some of those options but my lm_sensors wont detect any sensor to work
sensors_detect only temp cpu , not fans
If sensors_detect detects only cpu temps the how can i detect my fan sensor. The options, most of the option wants lm_sensor and my lm_sensor has only coretemp in it.
Are you sure about that? :wink:
dell_smm-virtual-0
Adapter: Virtual device
fan1:        6200 RPM
I think the main point is that if sensors_detect doesn't detect the fan, then you can't control the fan.
This is very common with laptops where the BIOS takes care of everything and doesn't expose any PWM hardware to the OS.
In my laptop sensors_detect only detects temp sensors but nbfc allow me to control the fan. I even submitted a custom config to the github project. I really advise the OP to take a look at the arch wiki page about this issue, and to nbfc wiki. There are configs for Toshiba Satellite L740 and L745 which might work or require minimal adjustments.
I tried it and i set the fan to 0 on any temp to see if is working but never stopped. nbfc status command shows me this.
Service enabled         : True
Read-only               : False
Selected config name    : Toshiba Satellite L740
Temperature             : 54
Fan display name        : CPU Fan Level
Auto control enabled    : True
Critical mode enabled   : False
Current fan speed       : 0.00
Target fan speed        : 0.00
Fan speed steps         : 2
If the chosen profile doesn't work you need to test registers and figure out the one you need tweak. This is a trial and error approach, takes some reading and can take some time to get right. You can start here.
Another approach is to try an older kernel, since your laptop is old. For example, I'm yet to find a kernel which works better than 4.14 on my laptop. Instead of dealing with solving problems I just hang on this one longer. When the time comes I'll make a transition and deal with the problems which might appear.
journalctl -p3 -b may also provide some insight to something which may be failing.
Last night i run ec-probe monitor --clearly and i find that my fan register is 0xB4 because when i chage its value (ec-probe write 0xB4 0) the fan speed change. I put 180 in WriteRegister and 181 in ReadRegister. I have alla fan speed to 0. I saved the config and i reload the config and start nbfc but the fan never stopped. The last thing i was searching last night was to check DSDT if the register i found was in this file but i stopped to continue today. If i downgrade my kernel is their a chance that nbfc works? journalctl -p3 -b shows me only 2 mei errors
If you found the register you need to probe for the range of values and then establish an up an down ramp in relation to temperature (these are usually exponencial and the upward ramp is usually steeper than the downward ramp).
You may want to always check the status and make sure the service started properly and the profile was loaded.
I use 4.14 and it works flawlessly. With 4.19 it fails sometimes and requires me to rename or delete two nbfc files (I don't remember which).
With upward and downward ramp do you mean this part of the config?
<TemperatureThreshold>
    <FanSpeed>50</FanSpeed>
    <UpThreshold>65</UpThreshold>
    <DownThreshold>56</DownThreshold>
  </TemperatureThreshold>
To adjust the FanSpeed, UpThreshold and DownThreshold? I this that my problem with the config is the MinSpeedValue and MaxSpeedValue because i cant find what value i need to put there.
It's easier to build your config based on an existing one. You can see mine here, but it would be better to base yours on a similar satellite model.
You can find the meaning of the variables on the Wiki. Regarding thresholds, UpThreshold is the temperature on which the selected speed is applied and DownThreshold is the temperature on which the speed falls to the lower limit.
So, in the section you show, you say you want a speed of 50% when temp reaches 65º and falls down to the lower speed (whatever it is) when the temp reaches back 56º.
It's important to keep in mind you need to set the maximum and minimum values yourself, so percentages make sense. Looking at my profile, you can see I define a value of 60 to 0% speed and a value of 37 for 100% speed (yes, the order is really inverted in my laptop's case). These values were defined through probing and testing. Actually, the fan can run faster but for my CPU the value 37 sustains a temperature of 87-90º under full load just fine.
Resuming, study an existing config and characterize your registers and fan properly (and don't forget to test it under load). The Wiki of nbfc is very good, but you might need some time to get into it.
The maximum and minimum value you found them from your fan register. You check its value under load and without load from the ec.probe monitor? And you convert the hexadecimal to decimal to write those value? Sorry that it took me 4 days to reply i was busy for some projects for my university.
The reason I check it under load is to make sure the maximum value is appropriate to cool the laptop when under load.
Yes, I used the ec-probe to figure out these values. Once you find the right registers to control the fan, you speed it up to the maximum and you slow it down to the minimum so you get the boundaries.
Then you test the lowest maximum value which can sustain a reasonable temperature under load. I used prime95 to load the CPUs and monitored the temperature with sensors. I usually aim for 90% of critical temperature. So, my CPU having a maximum measurable temperature of 105ºC, I aimed for less than 94ºC (usually, 88-90ºC is a good aim for any laptop - these values are a lot lower and variable for desktops). This temperature should be sustained for at least one hour under full load (some will say this isn't enough - it depends on what you use the laptop for, but 1hr usually indicates it will sustain much longer periods).
After setting minimum and maximum values you define the upward and downward ramps based on percentages. For example, in my case 50% equals to the value of 48.5 (60-(60-37)*0,5). You won't get the right ramps at the first try. You will make adjustments as you use the system during the first days/weeks. But there's no problem as long as the limits are well set.
On the other hand, you can ignore the search for the lowest maximum speed and just use the top boundary discovered with ec-probe. The downside is more noise, but it also works and is safe.
I find the maximum and minimum from ec-probe. I set the curve to 0 for all the temps but for some reason it doesnt stay stable. It like their is another service that controls my fan but the only thing that i have on my system that has something to do with my fans is lm_sensors. The only thing that have in it is coretemp. I cant find why it is not stable
Why and how have you done this? Can you show the config file and the output of nbfc status -a?
My config is:
<?xml version="1.0"?>
<FanControlConfigV2 xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema">
  <NotebookModel>Toshiba Satellite L740 , Bios v2.60 , EC v2.50</NotebookModel>
  <Author>msafwan</Author>
  <EcPollInterval>100</EcPollInterval>
  <ReadWriteWords>false</ReadWriteWords>
  <CriticalTemperature>75</CriticalTemperature>
  <FanConfigurations>
  <FanConfiguration>
    <ReadRegister>181</ReadRegister>
    <WriteRegister>180</WriteRegister>
    <MinSpeedValue>0</MinSpeedValue>
    <MaxSpeedValue>68</MaxSpeedValue>
    <IndependentReadMinMaxValues>false</IndependentReadMinMaxValues>
    <MinSpeedValueRead>0</MinSpeedValueRead>
    <MaxSpeedValueRead>0</MaxSpeedValueRead>
    <ResetRequired>false</ResetRequired>
    <FanSpeedResetValue>0</FanSpeedResetValue>
    <FanDisplayName>CPU Fan Level</FanDisplayName>
    <TemperatureThresholds>
        <UpThreshold>70</UpThreshold>
        <DownThreshold>70</DownThreshold>
        <FanSpeed>0</FanSpeed>
        <UpThreshold>60</UpThreshold>
        <DownThreshold>60</DownThreshold>
        <UpThreshold>50</UpThreshold>
        <DownThreshold>50</DownThreshold>
        <UpThreshold>20</UpThreshold>
        <DownThreshold>20</DownThreshold>
    </TemperatureThresholds>
    <FanSpeedPercentageOverrides />
  </FanConfiguration>
  </FanConfigurations>
  <RegisterWriteConfigurations />
</FanControlConfigV2>
And the output of nbfc status -a is :
Read-only               : False
Temperature             : 44
Current fan speed       : 67.65
Fan speed steps         : 68
When i pc is on idle and i use nbfc set -s 100 to set my fan to full speed manually or if i set them in the config its like some other program control my fan and is like is going from 0 to 100. Its not stable to 100
You should increase this. 100 ms polling interval is insane!
Well, setting it manually is incompatible with having the service running. You need to make sure nbfc is off when setting things manually. When using the ec-probe tool, the instructions should work. The only I can think of controlling your fan is your ACPI module and I'm not sure you can do anything about it.
I'll have a closer look at your config when I have time.
EDIT: I'm starting to think you may need to fake your thermal zone.
