Hello everybody,
I ran into some bug today. When I logged in everything seems normal, until manjaro loads. When I log in for a second or two the screen turns black and then in comes back.
Firstly, my wallpaper is gone. I only see the standard manjaro wallpaper. Secondly, there are no more apps (I used shortcuts to open the terminal). A similar problem occurred to me a few days ago and it was magically fixed when I created a new user (when new user was created the main account worked normally), but now this trick doesn’t work. I also just realize that on the terminal it says ‘‘zsh: corrupt history file /home/vajinbuu/.zhistory’’.
edit: I don’t have the zsh error anymore, but still have the issue of no icons.
Can someone help solve this problem?
Here are my specs:
Kernel: 6.1.41-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
root=UUID=8e0e212d-3399-41b6-9b0f-83f4032ed28f rw quiet splash
udev.log_priority=3
Desktop: KDE Plasma v: 5.27.6 tk: Qt v: 5.15.10 wm: kwin_x11 vt: 2 dm: SDDM
Type: Desktop System: Gigabyte product: B450M DS3H v: N/A
serial: <superuser required>
Mobo: Gigabyte model: B450M DS3H-CF v: x.x serial: <superuser required>
UEFI-[Legacy]: American Megatrends v: F51 date: 07/29/2020
Device-1: hidpp_battery_0 model: Logitech G304 Lightspeed Wireless Gaming
Mouse serial: <filter> charge: 100% (should be ignored) rechargeable: yes
status: discharging
Device-2: nintendo_switch_controller_battery_0005:057E:2009.0009 model: N/A
serial: N/A charge: High status: discharging
System RAM: total: 24 GiB available: 23.42 GiB used: 8.93 GiB (38.1%)
Info: model: AMD Ryzen 5 1600 bits: 64 type: MT MCP arch: Zen+ gen: 2
level: v3 note: check built: 2018-21 process: GF 12nm family: 0x17 (23)
model-id: 8 stepping: 2 microcode: 0x800820D
L1: 576 KiB desc: d-6x32 KiB; i-6x64 KiB L2: 3 MiB desc: 6x512 KiB L3: 16 MiB
desc: 2x8 MiB
Speed (MHz): avg: 3000 high: 3303 min/max: 1550/3200 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 2820 2: 3303
3: 3149 4: 2474 5: 2679 6: 3200 7: 3200 8: 3200 9: 3200 10: 3200 11: 3200
12: 2384 bogomips: 76691
bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb
cpuid cr8_legacy cx16 cx8 de decodeassists extapic extd_apicid f16c
flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf
lahf_lm lbrv lm mca mce misalignsse mmx mmxext monitor movbe msr mtrr
mwaitx nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat
pausefilter pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb
pfthreshold pge pni popcnt pse pse36 rapl rdrand rdseed rdtscp rep_good
sep sev sev_es sha_ni skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2
sse4a ssse3 succor svm svm_lock syscall tce topoext tsc tsc_scale
v_vmsave_vmload vgif vmcb_clean vme vmmcall wdt xgetbv1 xsave xsavec
xsaveerptr xsaveopt
Type: retbleed mitigation: untrained return thunk; SMT vulnerable
Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
disabled, RSB filling, PBRSB-eIBRS: Not affected
Device-1: NVIDIA GA106 [GeForce RTX 3060] vendor: Gigabyte driver: nvidia
v: 535.86.05 alternate: nouveau,nvidia_drm non-free: 535.xx+
status: current (as of 2023-07) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 3 speed: 8 GT/s lanes: 16
link-max: gen: 4 speed: 16 GT/s bus-ID: 07:00.0 chip-ID: 10de:2503
class-ID: 0300
Display: x11 server: X.Org v: 21.1.8 with: Xwayland v: 23.1.2
compositor: kwin_x11 driver: X: loaded: nvidia gpu: nvidia display-ID: :0
screens: 1
Screen-1: 0 s-res: 2560x1440 s-dpi: 108 s-size: 602x342mm (23.70x13.46")
s-diag: 692mm (27.26")
Monitor-1: HDMI-0 res: 2560x1440 hz: 60 dpi: 109
size: 597x336mm (23.5x13.23") diag: 685mm (26.97") modes: N/A
API: OpenGL v: 4.6.0 NVIDIA 535.86.05 renderer: NVIDIA GeForce RTX
3060/PCIe/SSE2 direct-render: Yes
Device-1: NVIDIA GA106 High Definition Audio vendor: Gigabyte
link-max: gen: 4 speed: 16 GT/s bus-ID: 07:00.1 chip-ID: 10de:228e
class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: Gigabyte driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 09:00.3
chip-ID: 1022:1457 class-ID: 0403
API: ALSA v: k6.1.41-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.75 status: active with: 1: pipewire-pulse
4: pw-jack type: plugin tools: pactl,pw-cat,pw-cli,wpctl
lanes: 1 port: f000 bus-ID: 05:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp5s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Device-1: Cambridge Silicon Radio Bluetooth Dongle (HCI mode) driver: btusb
v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-1:2
chip-ID: 0a12:0001 class-ID: e001
Local Storage: total: 2.26 TiB used: 286.72 GiB (12.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 1TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 2B4QFXO7 temp: 36.9 C
scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Kingston model: SA400S37480G
size: 447.13 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 0102 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Crucial model: CT1000BX500SSD1
tech: SSD serial: <filter> fw-rev: 061 scheme: GPT
ID-1: / raw-size: 420.9 GiB size: 413.22 GiB (98.18%)
used: 286.72 GiB (69.4%) fs: ext4 dev: /dev/nvme0n1p3 maj-min: 259:3
label: N/A uuid: 8e0e212d-3399-41b6-9b0f-83f4032ed28f
ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 510.6 GiB fs: ntfs label: N/A
uuid: B28C5F2D8C5EEB7D
ID-3: /dev/sda1 maj-min: 8:1 size: 300 MiB fs: vfat label: NO_LABEL
uuid: 48E9-9123
ID-4: /dev/sda2 maj-min: 8:2 size: 16 MiB fs: ext4 label: N/A
uuid: b5286a27-a013-40c2-be78-0c34e8dfde9a
ID-5: /dev/sda3 maj-min: 8:3 size: 446.26 GiB fs: ntfs label: N/A
uuid: F62EAFF22EAFA9D7
ID-6: /dev/sda4 maj-min: 8:4 size: 577 MiB fs: ntfs label: N/A
uuid: 2ECE61ABCE616C51
ID-7: /dev/sdb1 maj-min: 8:17 size: 100 MiB fs: vfat label: N/A
uuid: 0002-DBC1
ID-8: /dev/sdb2 maj-min: 8:18 size: 16 MiB fs: <superuser required>
ID-9: /dev/sdb3 maj-min: 8:19 size: 930.74 GiB fs: ntfs label: N/A
uuid: 820A0B7A0A0B6A8D
ID-10: /dev/sdb4 maj-min: 8:20 size: 674 MiB fs: ntfs label: N/A
uuid: 38228E8F228E51B4
Device-1: 1-4:2 info: 8BitDo Ultimate Wireless Controller type: HID
lanes: 1 mode: 1.1 power: 500mA chip-ID: 2dc8:3109 class-ID: 0300
serial: <filter>
Device-2: 1-8:3 info: Apple Aluminium Keyboard (ANSI) type: keyboard,HID
driver: apple,usbhid interfaces: 3 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 100mA chip-ID: 05ac:024f class-ID: 0300
Device-1: 3-1:2 info: Cambridge Silicon Radio Bluetooth Dongle (HCI mode)
type: bluetooth driver: btusb interfaces: 2 rev: 2.0
speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 chip-ID: 0a12:0001
class-ID: e001
Device-2: 3-4:3 info: Logitech USB Receiver type: keyboard,mouse,HID
driver: logitech-djreceiver,usbhid interfaces: 3 rev: 2.0
chip-ID: 046d:c53f class-ID: 0300
Hub-4: 4-0:1 info: super-speed hub ports: 4 rev: 3.0
System Temperatures: cpu: 45.5 C mobo: 32.0 C gpu: nvidia temp: 42 C
Processes: 351 Uptime: 49m wakeups: 4 Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7 Packages: 1538
pm: pacman pkgs: 1521 libs: 477 tools: pamac pm: flatpak pkgs: 14 pm: snap
pkgs: 3 Shell: Zsh v: 5.9 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.28
also maybe this can help (journalctl -b -p3 )
Aug 11 00:13:04 vajinbuu-b450mds3h kernel: usb 1-3: device descriptor read/64, error -71
Aug 11 00:13:04 vajinbuu-b450mds3h kernel: kvm: support for 'kvm_amd' disabled by bios
Aug 11 00:13:05 vajinbuu-b450mds3h kernel:
Aug 11 00:13:33 vajinbuu-b450mds3h konsole[1386]: kf.xmlgui: Shortcut for action "" "Show SSH Manager" set with QAction::setShortcut()! Use KActionCollection::setDefaultShortcut(s) instead.
Aug 11 00:13:33 vajinbuu-b450mds3h konsole[1386]: kf.xmlgui: Shortcut for action "" "Show Quick Commands" set with QAction::setShortcut()! Use KActionCollection::setDefaultShortcut(s) instead.
Aug 11 00:25:14 vajinbuu-b450mds3h konsole[2284]: kf.xmlgui: Shortcut for action "" "Show SSH Manager" set with QAction::setShortcut()! Use KActionCollection::setDefaultShortcut(s) instead.
Aug 11 00:25:14 vajinbuu-b450mds3h konsole[2284]: kf.xmlgui: Shortcut for action "" "Show Quick Commands" set with QAction::setShortcut()! Use KActionCollection::setDefaultShortcut(s) instead.
