I suddenly get logged out
#1
I am running cinnamon desktop, and sometimes, in the middle of me using it, I get logged out. How can I fix this?
Suddenly got logged out. Window manager got auto killed when out of memory situation (I think)
Multitouch on pad crashes Cinnamon
[Testing Update] 2018-02-28 - Kernels, Mesa, Browser, Haskell, Python
#2
I have the same issue. I’m running KDE and kernel 4.15
#3
I thought it was just me who experience it. I am also running an i3 desktop. Can someone help us to resolve this issue?
#4
Try downgrading the libinput to 1.9.4. It stopped random crash in my system.
#5
And I thought it was me unintentionally pressing some key-combination with $mod I wasn’t aware of yesterday when the same thing happened to me. Did the downgrade as well and will see if something like it is happening again.
#7
may be check journalctl & var/log/Xorg.0log
#8
Did anyone solve this problem for you? I could mark it as solved.
#9
I found out after testing many desktops of manjaro that it usually is present on UEFI systems.
Please tell me if you have this issue often on a BIOS system and I will do more research.
#10
I checked system logs and I think this is the cause:
[ 16124.471] (EE) client bug: timer event8 keyboard: offset negative (-1ms)
Can you help me decode this message?
#11
It just happened to me again. This time with kernel 4.16 and libinput 1.9.4 when opening the lid after a suspend of ca. 30 min. I could hear, I think, 2 sec. of the podcast I was listening to before closing the lid, and then the sudden logout happened. So I think downgrading libinput wasn’t really the solution. I will upgrade it again and wait when it will affect me again.
Until then, can someone tell which tools I should use in this case to troubleshoot?
#12
Have you guys tried to install libinput-gestures
Take a look at this
#13
