im byond lost in what the instructions are and i feel silly about it
can someone help me (sorry for being dumb but i really cant find any tutorials or help setting it up, litteraly all it shows up is how to disable mouse accel for windows)
the reason why i want this is because i use a costume mouse accel for gaming and regular use.
i hope someone can help me
From cursory reading
it tells you to run a specific script
which will create a PKGBUILD
file
which is used to build the kernel module.
What is not
explicitly mentioned is that there are prerequisites to be able to build packages
(see how to use the AUR
β¦)
You need to have the base-devel
package group installed
and in addition, since you are building a kernel module, you need the kernel headers and also the infrastructure to re-build these modules when a kernel changes.
This is DKMS
- you need that one too.
do you know the commands of what to install to start?
im really new to linux
i installed the headers but i dont find the base-devel on my add or remove programs thingie
Yes I do.
But since there is a little more (slight understatement) to it than just copy/pasting commands,
namely: knowing what you are doing β¦
Iβd rather not give you commands and then end up guiding you through the whole process.
Look up the Arch wiki - on how to use makepkg
, on how to install and use dkms
β¦
Sorry
one exception:
sudo pacman -S base-devel
(install all of these)
on your
you activate AUR support
dont worry i know somewhat of what im doing but i just cant find where the base-devel file is located or found to install but is ok if you dont wanna explain the whole process, ty for helping me the bit that you did
itβs not a file - it is a whole group of packages
collectively referred to by that name
needed to build (compile) software
see the previous comment
ok i just downloaded all of them tysm
just need to do the thing now
take your time
you may ask here when you get stuck
if you do, tell what you did, what you expected to achieve with it, and what you got instead
so others (including me) may be able to assist
With AUR packages you are generally on your own (in this forum) - and this one is not even in the AUR - although it might as well be, from what I read in the link you provided.
im genuinely clueless on what to do im reading this and it just scares the hell out of me.
id need someone in call with me to help in that case because idk how someone is expected to know this to switch to linux. how do you even learn this
β¦ by doing
learning sometimes takes time
i really dont feel like spending the entire day learning this so i can finally use linux, im extremely tiered from the stupid hours my school makes me go through
You can (and are) already using linux.
Just not the pretty special mouse driver that you desire.
It may take a bit more than a day
depending on your level of genius, and dedication vs frustration seeming to have taken over
Dynamic Kernel Module Support - ArchWiki
makepkg - ArchWiki
β¦ and here I am, starting to do what I said I would not β¦
i genuinely dont know what the instructions of leetmouse are asking me to do, im extremely lost
Alternatively, you could edit the standard configuration.
https://wiki.archlinux.org/title/Mouse_acceleration
you download this thing from the website:
the green βCodeβ button top right β Download zip
unzip the file - change into the directory you unpacked it to
and run:
./scripts/build_arch.sh
This relies on you having dkms set up and working
and the kernel headers for all your installed kernels too
after the script ran successfully - it builds the kernel module you are after - you find the installable package in the directory named βpkgβ
and can install it using:
sudo pacman -U pkg/build/leetmouse*.zst
(like the description on that website says)
I have played quake - a long time ago.
what is quake-live, I donβt know
what this driver is supposed to do for you, I donβt know
My normal mouse driver worked just fine.
β¦ and you can adjust the acceleration - no special driver needed β¦
i got someone to help me in discord and i did it, pretty easy just needed a step by step guide to do it
I will not grant you that comment as a solution as you marked it. Either you indeed provide the how in your comment, so others will benefit from it, or else we can close the topic as is, but just that comment will not work as solution here.
