I ran all three of those commands and it’s finished. What’s next?
A reboot and then you can check if its working and/or another inxi:
inxi -Nazy
Device-1: Realtek vendor: AzureWave driver: N/A pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: f000 bus-ID: 01:00.0 chip-ID: 10ec:b852 class-ID: 0280```
Ok…
pamac build rtw89-dkms-git
Then same - reboot and check.
(I mistakenly thought the previous driver was for the wireless of your device because it is listed in the description … in fact it is just the bluetooth component of a wireless driver that does not list your device though it is apparently the correct one… if you wanted an explanation )
I have no idea what that means LOL but i don’t care because oh my goodness the wifi is working. Thank you so much. I probably would never have figured this out on my own.
Hurrah. Glad its working.
Happy linuxing
thank you again. so happy to finally be able to give the middle finger to windows
while I’m here, what about installing all the kernels? i noticed there are some available in the kernel manager, do I need those?
You dont need them. But I always suggest having one known-working LTS (long term support) plus one other you are trying out … maybe a special kernel or just newer.
So keep that 6.1 and maybe also install 6.3 or 6.4 … you have newer hardware so it makes sense to try the newer kernels.
You can use the GUI manjaro-settings-manager, or use mhwd
in the terminal, ex:
sudo mhwd-kernel -i linux64
PS. You can always check kernel.org for the state of kernels and projected end of life, etc.
