My problem is trivial yet annoying. I was switching themes just to get back to the original breath, yet the lock screen is still possessed by one of the previous themes; the initial login page is perfectly fine and looks as i would like to see the lock page. How do i force this transition?
Sadly that only changes the background and the splash, the things are different when i get to the point where i enter the password. The lock screen is quite different from what i have on my laptop with pristine installation and certainly comes from another theme, up to the point that the panel on top has a clock that never updates (which is most certainly not something from the official distribution).
Sadly i was in the login / sddm section, kscreenlockerrc looks pretty much the same, yet i certainly have a different login form and screen. Theme change also doesn’t help.
I hate noisy blurry abhorrent shots as anyone else, but i guess this calls for an illustration. Bottom is a pristine installation that i want, top is what i get. I guess it’s worth noticing that the installation is pretty old, ~2020 or something (obviously regularly updated, but this may be a backwards compatibility thing)
On that note … what theme are you using?
(the old breath was replaced by breath2, and later renamed to breath-classic, with breath2 becoming breath … maybe related?)
(the old breath was replaced by breath2 , and later renamed to breath-classic , with breath2 becoming breath … maybe related?)
Breath. I’m not sure which one it is in terms of id, but in my current setup i have Breath, Breath Dark, Breath Light; i’ve tried switching to all of them with no effect.
When you say you switched themes … how/what did you change?
Normally it seems to me that kscreenlocker changes with the Desktop Theme (“Plasma Style”)… but if that does not work for you, have you tried applying a look-and-feel (“Global”) theme ?
That was an ancient change, maybe a year ago (i just got fed up by this), but pretty sure it was applying global theme. Tried switching SDDM login screen as well, but can’t see any changes (will try to reboot later, but i doubt it will help)
