I have my primary (default) OS as manjaro (installed in my internal 256gb ssd). I have also installed windows 10 and ubuntu on a 1tb external hard disk. Currently, I have to press F9 everytime while I reboot my system if I want to boot into ubuntu or windows. I just want my laptop to ask me everytime about the OS I want to boot into whenever I reboot/power-on it.
I’ve search the web for this but they refer to software like easyBCD which is not working for me as I installed windows after installing manjaro in my system. So, i was wondering if there is a solution to this problem?
thanks in advance
thank you for your reply. I am a beginner and I don’t even know what role UEFI plays in the booting process . But, I think I can give the alternative answer a go. I am currently updating after a long time and i think it;s gonna take a while. I’ll give you an update once I try this.
Enter the UEFI settings and look at the boot options. I cannot tell you how or where because of how many different UEFI implementations there are.
Usually you enter the settings by pressing F10 or Del or something during cold boot. The documentation of the motherboard or laptop should tell you that, and there should even be a message on the screen during boot.
Check out the rEFInd boot manager. It’s very easy to install, and gives you a nice GUI screen with different icons to choose from every time you boot. There are even different themes available, so you can customize the way it looks if you want. Here’s an example of a screenshot:
