Because of my stupidity, I lost .zshrc.
Now I don’t know how to change it back to its original state. Can anyone tell me what the content of this file is
I have never modified it. It should still be the default
If you have manjaro-zsh-config
installed, you can restore the original from /etc/skel/
cp /etc/skel/.zshrc ~/
Then source the file to load it in your current terminal:
source ~/.zshrc
Sounds like it’s a good time to start creating regular backups.
Thank you very much. The problem has been solved.
Yes, I also think it is a good time to set up a regular backup to avoid similar problems
