I keep getting logged out from everything on Wayland
I recently posted about an issue with Bluetooth and PulseAudio, and I was advised that KDE has made the switch to Wayland. I went ahead and began using it, but I noticed that I am logged out of almost everything, not sure if this is something related to my keys or something similar to cookies in web? Not sure.
Anyhow, I logged in again, but I keep getting logged out, mainly from WhatsApp Web when I restart the laptop. Is there a solution for this?
Hi @Yamo,
I use Plasma with Wayland and I can’t say I’ve had this problem. But I can suggest you clear the cache and see if that helps:
rm -r ~/.cache
And just for good measure reboot.
Hope it helps!
Have you got anything Xorg-related in an autostart or your ~/.zshrc (or the relevant profile for the shell you’re using)?
When I first tried switching over to Wayland. I had such entries in ~/.zshrc and they caused a lot of problems with Wayland sessions (I think it was things like xset, xmodmap, setxkbmap).
I don’t believe so. I searched in my .zshrc config file but I didn’t find anything like that.
Ah well… Worth a try.
Which browser are you using? It sounds more like a cookies issue in the browser if it’s the web version of whatsapp that is affected.
Waiting for someone to blindly ask questions is also counter-productive – typically, nobody has a :crystal_ball: at their disposal – Instead, please help others to make informed suggestions, based on information you provide.
Update Announcements
System Information
inxi --filter --verbosity=8
inxi -zv8
Highly Recommended
Technical Resources
Required Reading
Vivaldi
I have done that, and I believe that it might have resolved it, I will test after a couple of reboots and update you.
Sounds to me like your privacy and/or cookie settings are clearing data on close or perhaps an external program is clearing some data on logout/reboot.
Similar problem with Vivaldi:
@Yamo
You have been asked already for system information.
It’s possible someone will notice something in your details that might be contributing to your issue – inxi output is expected with each new Support topic, or when requested by staff.
Please provide it as per @tracyanne’s post (above).
  Kernel: 6.12.48-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
    clocksource: hpet avail: acpi_pm
    root=UUID=b395b351-d6f7-40f1-88ff-43ee89d7e608 rw
    btusb.enable_autosuspend=n usbcore.autosuspend=-1 quiet acpi_osi=off
    apparmor=1 security=apparmor udev.log_priority=3 acpi_backlight=native
    nowatchdog
  Desktop: KDE Plasma v: 6.3.6 tk: Qt v: N/A info: frameworks v: 6.18.0
  Type: Laptop System: LENOVO product: 82B5 v: Lenovo Legion 5 15ARH05
    serial: <superuser required> Chassis: type: 10 v: Lenovo Legion 5 15ARH05
  Mobo: LENOVO model: LNVNB161216 v: SDK0J40709 WIN
    serial: <superuser required> part-nu: LENOVO_MT_82B5_BU_idea_FM_Legion 5
    15ARH05 uuid: <superuser required> UEFI: LENOVO v: EUCN41WW
    date: 09/20/2023
  ID-1: BAT0 charge: 26.1 Wh (59%) condition: 44.1/60 Wh (73.6%) volts: 15.74
    min: 15.44 model: SMP L19M4PC0 type: Li-poly serial: <filter> charging:
    status: not charging cycles: 1294
  System RAM: total: 16 GiB available: 15 GiB used: 10.45 GiB (69.7%)
    (unregistered) size: 8 GiB speed: 3200 MT/s volts: note: check curr: 1
    min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: Kingston
    part-no: LV32D4S2S8HD-8 serial: <filter>
    min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: Samsung
    part-no: M471A1G44AB0-CWE serial: <filter>
  Info: model: AMD Ryzen 5 4600H with Radeon Graphics bits: 64 type: MT MCP
    arch: Zen 2 gen: 2 level: v3 note: check built: 2020-22
    process: TSMC n7 (7nm) family: 0x17 (23) model-id: 0x60 (96) stepping: 1
    microcode: 0x860010D
    desc: 6x512 KiB L3: 8 MiB desc: 2x4 MiB
  Speed (MHz): avg: 1397 min/max: 1400/3000 boost: enabled scaling:
    driver: acpi-cpufreq governor: ondemand cores: 1: 1397 2: 1397 3: 1397
    4: 1397 5: 1397 6: 1397 7: 1397 8: 1397 9: 1397 10: 1397 11: 1397 12: 1397
    bogomips: 71898
    f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibrs
    ibs irperf lahf_lm lbrv lm mba mca mce misalignsse mmx mmxext monitor
    movbe msr mtrr mwaitx nonstop_tsc nopl npt nrip_save nx osvw
    overflow_recov pae pat pausefilter pclmulqdq pdpe1gb perfctr_core
    perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse pse36 rapl rdpid
    rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni skinit smap smca
    smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock
    syscall tce topoext tsc tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif
    vmcb_clean vme vmmcall wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr
    xsaveopt xtopology
  Type: retbleed mitigation: untrained return thunk; SMT enabled with STIBP
    protection
    always-on; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not affected
  Device-1: NVIDIA TU117M [GeForce GTX 1650 Ti Mobile] vendor: Lenovo
    driver: nvidia v: 580.82.09 alternate: nouveau,nvidia_drm
    non-free: 550-580.xx+ status: current (as of 2025-08; EOL~2026-12-xx)
    arch: Turing code: TUxxx process: TSMC 12nm FF built: 2018-2022 pcie:
    gen: 1 speed: 2.5 GT/s lanes: 8 link-max: gen: 3 speed: 8 GT/s lanes: 16
    ports: active: none empty: DP-1,HDMI-A-1,eDP-2 bus-ID: 01:00.0
    chip-ID: 10de:1f95 class-ID: 0300
  Device-2: Advanced Micro Devices [AMD/ATI] Renoir [Radeon Vega Series /
    Radeon Mobile Series] vendor: Lenovo driver: amdgpu v: kernel arch: GCN-5
    code: Vega process: GF 14nm built: 2017-20 pcie: gen: 4 speed: 16 GT/s
    lanes: 16 ports: active: eDP-1 empty: none bus-ID: 05:00.0
    chip-ID: 1002:1636 class-ID: 0300 temp: 42.0 C
  Device-3: Bison Integrated Camera driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3:2 chip-ID: 5986:212b
    class-ID: 0e02
    compositor: kwin_wayland driver: X: loaded: amdgpu,nvidia
    unloaded: modesetting,nouveau alternate: fbdev,nv,vesa dri: radeonsi
    gpu: amdgpu d-rect: 3840x1080 display-ID: 0
  Monitor-1: Virtual-virtual-xdp-kde-com.obsproject.Studio pos: right res:
    mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 25
    size: 1920x1080mm (75.59x42.52") diag: 2203mm (86.73") modes: N/A
  Monitor-2: eDP-1 pos: primary,left model: AU Optronics 0xd1ed built: 2019
    res: mode: 1920x1080 hz: 120 scale: 100% (1) dpi: 142 gamma: 1.2 chroma:
    red: x: 0.561 y: 0.341 green: x: 0.349 y: 0.573 blue: x: 0.161 y: 0.118
    white: x: 0.314 y: 0.329 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
    ratio: 16:9 modes: 1920x1080, 1680x1050, 1280x1024, 1440x900, 1280x800,
    1280x720, 1024x768, 800x600, 640x480
  API: EGL v: 1.5 hw: drv: nvidia drv: amd radeonsi platforms: device: 0
    drv: nvidia device: 2 drv: radeonsi device: 3 drv: swrast gbm: drv: nvidia
    surfaceless: drv: nvidia wayland: drv: radeonsi x11: drv: radeonsi
    inactive: device-1
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: amd mesa v: 25.2.3-arch1.2
    renoir ACO DRM 3.61 6.12.48-1-MANJARO) device-ID: 1002:1636
    memory: 500 MiB unified: no display-ID: :1.0
  API: Vulkan v: 1.4.321 layers: 7 device: 0 type: integrated-gpu name: AMD
    Radeon Graphics (RADV RENOIR) driver: mesa radv v: 25.2.3-arch1.2
    device-ID: 1002:1636 surfaces: N/A device: 1 type: discrete-gpu
    name: NVIDIA GeForce GTX 1650 Ti driver: nvidia v: 580.82.09
    device-ID: 10de:1f95 surfaces: N/A
    de: kscreen-console,kscreen-doctor gpu: nvidia-smi wl: wayland-info
    x11: xdpyinfo, xprop, xrandr
  Device-1: NVIDIA driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s
    lanes: 8 link-max: lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:10fa
    class-ID: 0403
  Device-2: Advanced Micro Devices [AMD] Audio Coprocessor vendor: Lenovo
    driver: N/A alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x,
    snd_pci_acp6x, snd_acp_pci, snd_rpl_pci_acp6x, snd_pci_ps,
    snd_sof_amd_renoir, snd_sof_amd_rembrandt, snd_sof_amd_vangogh,
    snd_sof_amd_acp63, snd_sof_amd_acp70 pcie: gen: 4 speed: 16 GT/s lanes: 16
    bus-ID: 05:00.5 chip-ID: 1022:15e2 class-ID: 0480
    vendor: Lenovo driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
    lanes: 16 bus-ID: 05:00.6 chip-ID: 1022:15e3 class-ID: 0403
  API: ALSA v: k6.12.48-1-MANJARO status: kernel-api with: 1: aoss
    type: oss-emulator 2: apulse type: pulse-emulator
  Server-2: PipeWire v: 1.4.8 status: off with: wireplumber status: off
    tools: pw-cli,wpctl
  Server-3: PulseAudio v: 17.0-43-g3e2bb status: active with:
    tools: pacat,pactl,pavucontrol,pulsemixer
    vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
    port: 2000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
  Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
    speed: 5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 8086:2723 class-ID: 0280
  IF: wlp4s0 state: up mac: <filter>
  IF-ID-1: CloudflareWARP state: unknown speed: 10000 Mbps duplex: full
    mac: N/A
  IP v4: <filter> scope: global
  IP v6: <filter> scope: global
  IP v6: <filter> virtual: stable-privacy proto kernel_ll scope: link
  IF-ID-2: vmnet1 state: unknown speed: N/A duplex: N/A mac: <filter>
  IP v6: <filter> virtual: proto kernel_ll scope: link
  IF-ID-3: vmnet8 state: unknown speed: N/A duplex: N/A mac: <filter>
  Info: services: NetworkManager, systemd-networkd, systemd-timesyncd,
    wpa_supplicant
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-3:3 chip-ID: 8087:0029
    class-ID: e001
  Report: btmgmt ID: hci0 rfk-id: 2 state: up address: N/A
  Local Storage: total: 1.14 TiB used: 639.09 GiB (54.6%)
    model: MZVLB256HBHQ-000L2 size: 238.47 GiB block-size: physical: 512 B
    fw-rev: 3L1QEXH7 temp: 52.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD10SPSX-08A6W
    tech: HDD rpm: 7200 serial: <filter> fw-rev: 1A01 scheme: GPT
  ID-1: / raw-size: 51.29 GiB size: 50.31 GiB (98.08%) used: 41.8 GiB (83.1%)
    fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:5 label: N/A
    uuid: b395b351-d6f7-40f1-88ff-43ee89d7e608
    used: 52.8 MiB (55.0%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
    label: N/A uuid: 0C75-E2CB
  ID-3: /home raw-size: 68.07 GiB size: 66.45 GiB (97.62%)
    used: 53.79 GiB (80.9%) fs: ext4 dev: /dev/nvme0n1p7 maj-min: 259:7
    label: N/A uuid: 8688e415-56b2-481d-827b-210e7dfd1197
  ID-4: /run/media/yamo/9640794240792A5F raw-size: 97.58 GiB
    size: 97.58 GiB (100.00%) used: 60.69 GiB (62.2%) fs: ntfs
    dev: /dev/nvme0n1p3 maj-min: 259:3 label: N/A uuid: 4C924D4C924D3BA8
  ID-5: /run/media/yamo/EDU raw-size: 292.97 GiB size: 292.97 GiB (100.00%)
    used: 187.73 GiB (64.1%) fs: ntfs dev: /dev/sda3 maj-min: 8:3 label: EDU
    uuid: 366C4A282D6F052F
  ID-6: /run/media/yamo/Main raw-size: 638.53 GiB size: 638.53 GiB (100.00%)
    used: 293.61 GiB (46.0%) fs: ntfs dev: /dev/sda2 maj-min: 8:2 label: Main
    uuid: 3AEC09DCEC099375
  ID-1: swap-1 type: partition size: 20.48 GiB used: 1.41 GiB (6.9%)
    priority: -2 dev: /dev/nvme0n1p6 maj-min: 259:6 label: N/A
    uuid: ae9bb7f8-1320-4d92-9e21-1ebd6e555f8a
  ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-2: /dev/nvme0n1p4 maj-min: 259:4 size: 962 MiB fs: ntfs label: N/A
    uuid: A65C81855C81514B
  ID-3: /dev/sda1 maj-min: 8:1 size: 16 MiB fs: <superuser required>
  Device-1: 1-3:2 info: Bison Integrated Camera type: video driver: uvcvideo
    interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0
    power: 500mA chip-ID: 5986:212b class-ID: 0e02
  Hub-4: 3-1:2 info: Genesys Logic Hub ports: 2 rev: 2.1
  Device-1: 3-1.1:4 info: Razer USA Cobra type: mouse,keyboard
    driver: razermouse,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s)
    lanes: 1 mode: 1.1 power: 500mA chip-ID: 1532:00a3 class-ID: 0300
  Device-2: 3-3:3 info: Intel AX200 Bluetooth type: bluetooth driver: btusb
    power: 100mA chip-ID: 8087:0029 class-ID: e001
  Device-3: 3-4:5 info: Integrated Express ITE Device(8910) type: keyboard
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 048d:c100 class-ID: 0301
  Hub-5: 4-0:1 info: super-speed hub ports: 2 rev: 3.1
  Hub-6: 4-1:2 info: Genesys Logic GL3523 Hub ports: 2 rev: 3.2
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 05e3:0620
  System Temperatures: cpu: 50.6 C mobo: N/A gpu: amdgpu temp: 43.0 C
  Fan Speeds (rpm): N/A
  Packages: 2319 pm: dpkg pkgs: 0 pm: pacman pkgs: 2292 libs: 524
    tools: pamac,yay pm: flatpak pkgs: 12 pm: snap pkgs: 15
    1: https://manjaro.mirror.liquidtelecom.com/stable/$repo/$arch
    2: https://manjarolinux-mirror.cloud.mu/stable/$repo/$arch
Processes:
  CPU top: 5 of 449
  1: cpu: 43.5% command: code pid: 6468 mem: 98.5 MiB (0.6%)
  2: cpu: 39.3% command: cpptools pid: 10264 mem: 534.4 MiB (3.4%)
  3: cpu: 35.5% command: vivaldi-bin pid: 38309 mem: 334.7 MiB (2.1%)
  4: cpu: 32.9% command: vivaldi-bin pid: 36442 mem: 208.3 MiB (1.3%)
  5: cpu: 23.8% command: sda2 started-by: mount.ntfs pid: 2633
    mem: 76.2 MiB (0.4%)
  Memory top: 5 of 449
  1: mem: 985.4 MiB (6.4%) command: vivaldi-bin pid: 5808 cpu: 21.7%
  2: mem: 581.4 MiB (3.7%) command: vivaldi-bin pid: 6609 cpu: 9.6%
  3: mem: 534.4 MiB (3.4%) command: cpptools pid: 10264 cpu: 39.3%
  4: mem: 494.9 MiB (3.2%) command: vivaldi-bin pid: 12178 cpu: 7.5%
  5: mem: 450.0 MiB (2.9%) command: plasmashell pid: 5515 cpu: 2.8%
  Processes: 449 Power: uptime: 14m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 5.97 GiB services: org_kde_powerdevil,upowerd
  Compilers: clang: 20.1.8 gcc: 15.2.1 Shell: Zsh v: 5.9 running-in: kitty
    inxi: 3.3.39
Abandoned Topic (30+ days)
