I’m sorry to come bother you with such a common problem but it is annoying and I cannot find the missing configuration … I am the happy owner of an RTX 2060 on my fixed pc (which also has an igpu intel i5-8600) but I only use the 3 displayport ports of my graphics card (nothing connected to the hdmi output of the igpu). I disabled the igpu on my bios (no way to check if it really disables it). When I boot I have no image but only a tty. Currently I just have to log in, run this command (mhwd -i pci video-hybrid-intel-nvidia-455xx-prime -f
) to reinstall the drivers and tadam it works.
My first mistake is maybe that I am using the hybrid driver but since the igpu is deactivated I should rather turn to the nvidia only? Because of the too recent kernel? I still have to install the reverse prime despite the fact that the igpu is disabled?
As you will see inxi -G isn’t able to find the driver
Here are some order returns that may help you find the missing thing (commands launched before re-installing the drivers) :
mhwd-kernel -li
e[32mCurrently running:e[0m 5.9.8-2-MANJARO (linux59)
* linux58
* linux59
mhwd -li
e[1me[31m> e[mInstalled PCI configs:
NAME VERSION FREEDRIVER TYPE
video-hybrid-intel-nvidia-450xx-prime 2020.10.04 false PCI
video-modesetting 2020.01.13 true PCI
e[1me[31mWarning: e[mNo installed USB configs!
inxi -G
Graphics: Device-1: NVIDIA TU106 [GeForce RTX 2060 Rev. A] driver: N/A
Display: server: X.org 1.20.9 driver: nvidia unloaded: modesetting tty: 128x48
Message: Advanced graphics data unavailable in console for root.
inxi -Fazy
Kernel: 5.9.8-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/vmlinuz-5.9-x86_64
root=UUID=94b527ce-2de5-44d9-b369-cd21e29f0c41 rw quiet
resume=UUID=e477cbf6-e47c-4bd6-8e89-8a7aece4814f
Console: tty 2 Distro: Manjaro Linux
Type: Desktop System: Gigabyte product: H370AORUSGAMING3WIFI v: N/A
serial: N/A
Mobo: Gigabyte model: H370 AORUS GAMING 3 WIFI-CF serial: N/A
UEFI: American Megatrends v: F12a date: 01/18/2019
Info: 6-Core model: Intel Core i5-8600 socket: LGA1151 (U3E1) note: check
bits: 64 type: MCP arch: Kaby Lake family: 6 model-id: 9E (158)
stepping: A (10) microcode: DE L1 cache: 384 KiB L2 cache: 9216 KiB
L3 cache: 9000 KiB
bogomips: 37213
Speed: 800 MHz min/max: 800/4300 MHz base/boost: 4059/8300 volts: 1.1 V
ext-clock: 100 MHz Core speeds (MHz): 1: 800 2: 800 3: 800 4: 800 5: 800
6: 800
Type: l1tf
Type: tsx_async_abort mitigation: Clear CPU buffers; SMT disabled
Device-1: NVIDIA TU106 [GeForce RTX 2060 Rev. A] vendor: Micro-Star MSI
driver: N/A alternate: nouveau, nvidia_drm, nvidia bus ID: 01:00.0
chip ID: 10de:1f08
alternate: fbdev,nouveau,nv,vesa tty: 128x48
Device-1: Intel Cannon Lake PCH cAVS vendor: Gigabyte driver: snd_hda_intel
v: kernel alternate: snd_soc_skl,snd_sof_pci bus ID: 00:1f.3
chip ID: 8086:a348
Sound Server: ALSA v: k5.9.8-2-MANJARO
Device-1: Intel Wireless-AC 9560 [Jefferson Peak] driver: iwlwifi v: kernel
bus ID: 00:14.3 chip ID: 8086:a370
IF: wlo1 state: down mac: <filter>
Device-2: Intel Ethernet I219-V vendor: Gigabyte driver: e1000e v: kernel
port: efa0 bus ID: 00:1f.6 chip ID: 8086:15bc
IF: eno2 state: up speed: 1000 Mbps duplex: full mac: <filter>
IF-ID-1: br-67cad597028c state: down mac: <filter>
IF-ID-2: br-82702b02d64f state: down mac: <filter>
IF-ID-3: br-93afd3d0a9b5 state: down mac: <filter>
IF-ID-4: br-efea58eda626 state: down mac: <filter>
IF-ID-5: docker0 state: down mac: <filter>
Local Storage: total: 3.18 TiB used: 64.54 GiB (2.0%)
ID-1: /dev/sda vendor: Seagate model: ST2000DM006-2DM164
family: Barracuda 3.5 size: 1.82 TiB block size: physical: 4096 B
logical: 512 B sata: 3.1 speed: 6.0 Gb/s rotation: 7200 rpm serial: <filter>
rev: CC26 temp: 36 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 238d 4h cycles: 1096
read: 112.65 TiB written: 7.46 TiB Pre-Fail: attribute: Spin_Retry_Count
value: 100 worst: 100 threshold: 97
ID-2: /dev/sdb vendor: Samsung model: SSD 860 EVO 500GB family: based SSDs
size: 465.76 GiB block size: physical: 512 B logical: 512 B sata: 3.1
speed: 6.0 Gb/s serial: <filter> rev: 1B6Q temp: 27 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 238d 10h cycles: 1101
written: 29.50 TiB
ID-3: /dev/sdc vendor: Western Digital model: WD10EZRX-00L4HB0 family: Green
size: 931.51 GiB block size: physical: 4096 B logical: 512 B sata: 3.0
speed: 6.0 Gb/s rotation: 5400 rpm serial: <filter> rev: 1A01 temp: 32 C
scheme: MBR
SMART: yes state: enabled health: PASSED on: 161d 23h cycles: 1232 Old-Age:
UDMA CRC errors: 154
ID-1: / raw size: 99.40 GiB size: 97.34 GiB (97.93%) used: 43.98 GiB (45.2%)
fs: ext4 block size: 4096 B dev: /dev/sdb5
ID-2: /boot raw size: 1.00 GiB size: 975.9 MiB (95.21%)
used: 112.3 MiB (11.5%) fs: ext4 block size: 4096 B dev: /dev/sdb1
ID-3: /home raw size: 100.00 GiB size: 97.93 GiB (97.93%)
used: 20.43 GiB (20.9%) fs: ext4 block size: 4096 B dev: /dev/sda1
ID-1: swap-1 type: partition size: 10.00 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sdb8
System Temperatures: cpu: 44.0 C mobo: 27.8 C
Processes: 177 Uptime: 3m Memory: 47.00 GiB used: 289.8 MiB (0.6%)
Init: systemd v: 246 Compilers: gcc: 10.2.0 Packages: apt: 0 pacman: 1372
lib: 385 flatpak: 0 Shell: Bash v: 5.0.18 running in: tty 2 inxi: 3.1.08
mhwd-gpu --status
:: status
xorg configuration file: ‘/etc/X11/mhwd.d/nvidia.conf’
cat /etc/modprobe.d/mhwd-gpu.conf
## Generated by mhwd - Manjaro Hardware Detection
blacklist nouveau
blacklist ttm
blacklist drm_kms_helper
blacklist drm
options nvidia "NVreg_DynamicPowerManagement=0x02"
cat /etc/X11/mhwd.d/nvidia.conf
(empty file)
Thanks for you help !
