I have not been able to update the system for a month or more
I’m tired of seeing this message.
I have not been able to update my system for a month or more. Not sure what to do
This is the message that appears when I type the command
sudo pacman -Syy         ✔
[sudo] password for hamid:
 core-rel.db failed to download
error: failed retrieving file 'core-rel.db' from mirrors.manjaro.org : The requested URL returned error: 404
error: failed retrieving file 'core-rel.db' from ftp.linux.org.tr : The requested URL returned error: 404
error: failed retrieving file 'core-rel.db' from coresite.mm.fcix.net : The requested URL returned error: 404
error: failed retrieving file 'core-rel.db' from mirrors.ustc.edu.cn : The requested URL returned error: 404
error: failed retrieving file 'core-rel.db' from mirror.xenyth.net : The requested URL returned error: 404
error: failed to synchronize all databases (failed to retrieve some files)
I’ve read something about manually removing some repos, but I don’t know how to do that.
I appreciate your help.
For one, remove the Steam Deck repo(s), they are not supported.
The same way you added them.
Could you please tell me how I can delete these repositories?
I don’t know the correct way. I don’t even have a Steam Deck!!
since you are on kde, open the file with kate:
kate /etc/pacman.conf
locate the repos, remove them; save the file, and refresh your mirrors + update:
sudo pacman-mirrors --fasttrack 5 && sudo pacman -Syyu
Did you mean the sudo pacman -Syu command?
A 404 error means you cannot reach the server… either the server is down or something in your network is blocking access to the site.
A quick solution is to try using a VPN, or connecting to your Mobile device etc.
Cannot reach the thing somehow.
In this case … probably because manjaro mirrors dont serve any version of core-rel.db
Have you tried what @brahma proposed? Most likely you have an entry with
[core-rel]
in your /etc/pacman.conf.
@DR.MODY, otherwise you need to find out how you got something installed which asks for core-rel.db. Did you use PIP or other commands to install something?
