Hi!
After I installed perhaps mkinitcpio update and updated mkinitcpio.conf, I can’t boot Manjaro OS: I choose what kernel/timeshift image to boot (I selected ordinary kernel boot) and after some time I got the screen below:
ERROR: device `/dev/mapper/luks-... not found. Skipping fsck.
mount: /new_root: no filesystem type specified.
You are now being dropped into an emergency shell.
What I did to make this happen
pacman.log
[2022-07-05T00:32:41+0300] [PAMAC] synchronizing package lists
[2022-07-05T19:31:32+0300] [PACMAN] Running 'pacman -Syu'
[2022-07-05T19:31:32+0300] [PACMAN] synchronizing package lists
[2022-07-05T19:31:36+0300] [PACMAN] starting full system upgrade
[2022-07-05T19:32:07+0300] [ALPM] running '00-timeshift-autosnap.hook'...
[2022-07-05T19:32:07+0300] [ALPM-SCRIPTLET] First run mode (config file not found)
[2022-07-05T19:32:07+0300] [ALPM-SCRIPTLET] Selected default snapshot type: BTRFS
[2022-07-05T19:32:07+0300] [ALPM-SCRIPTLET] Using system disk as snapshot device for creating snapshots in BTRFS mode
[2022-07-05T19:32:07+0300] [ALPM-SCRIPTLET] Mounted '/dev/dm-0 (sda1)' at '/run/timeshift/190955/backup'
[2022-07-05T19:32:08+0300] [ALPM-SCRIPTLET] Creating new backup...(BTRFS)
[2022-07-05T19:32:08+0300] [ALPM-SCRIPTLET] Saving to device: /dev/dm-0, mounted at path: /run/timeshift/190955/backup
[2022-07-05T19:32:08+0300] [ALPM-SCRIPTLET] Created directory: /run/timeshift/190955/backup/timeshift-btrfs/snapshots/2022-07-05_19-32-08
[2022-07-05T19:32:09+0300] [ALPM-SCRIPTLET] Created subvolume snapshot: /run/timeshift/190955/backup/timeshift-btrfs/snapshots/2022-07-05_19-32-08/@
[2022-07-05T19:32:09+0300] [ALPM-SCRIPTLET] Created control file: /run/timeshift/190955/backup/timeshift-btrfs/snapshots/2022-07-05_19-32-08/info.json
[2022-07-05T19:32:09+0300] [ALPM-SCRIPTLET] BTRFS Snapshot saved successfully (0s)
[2022-07-05T19:32:09+0300] [ALPM-SCRIPTLET] Tagged snapshot '2022-07-05_19-32-08': ondemand
[2022-07-05T19:32:09+0300] [ALPM-SCRIPTLET] ------------------------------------------------------------------------------
[2022-07-05T19:32:09+0300] [ALPM-SCRIPTLET] Found stale mount for device '/dev/dm-0' at path '/run/timeshift/190955/backup'
[2022-07-05T19:32:09+0300] [ALPM-SCRIPTLET] Unmounted successfully
[2022-07-05T19:32:10+0300] [ALPM-SCRIPTLET] First run mode (config file not found)
[2022-07-05T19:32:10+0300] [ALPM-SCRIPTLET] Selected default snapshot type: BTRFS
[2022-07-05T19:32:10+0300] [ALPM-SCRIPTLET] Mounted '/dev/dm-0 (sda1)' at '/run/timeshift/191102/backup'
[2022-07-05T19:32:10+0300] [ALPM-SCRIPTLET] Selected default snapshot device: /dev/dm-0
[2022-07-05T19:32:10+0300] [ALPM-SCRIPTLET] ------------------------------------------------------------------------------
[2022-07-05T19:32:10+0300] [ALPM-SCRIPTLET] Removing snapshot: 2022-07-04_10-43-59
[2022-07-05T19:32:10+0300] [ALPM-SCRIPTLET] Deleting subvolume: @ (Id:472)
[2022-07-05T19:32:11+0300] [ALPM-SCRIPTLET] Deleted subvolume: @ (Id:472)
[2022-07-05T19:32:11+0300] [ALPM-SCRIPTLET] Deleted directory: /run/timeshift/191102/backup/timeshift-btrfs/snapshots/2022-07-04_10-43-59
[2022-07-05T19:32:11+0300] [ALPM-SCRIPTLET] Removed snapshot: 2022-07-04_10-43-59
[2022-07-05T19:32:11+0300] [ALPM-SCRIPTLET] ------------------------------------------------------------------------------
[2022-07-05T19:32:11+0300] [ALPM-SCRIPTLET] Found stale mount for device '/dev/dm-0' at path '/run/timeshift/191102/backup'
[2022-07-05T19:32:11+0300] [ALPM-SCRIPTLET] Unmounted successfully
[2022-07-05T19:32:12+0300] [ALPM-SCRIPTLET] Generating grub configuration file ...
[2022-07-05T19:32:12+0300] [ALPM-SCRIPTLET] Found theme: /usr/share/grub/themes/manjaro/theme.txt
[2022-07-05T19:32:13+0300] [ALPM-SCRIPTLET] Found linux image: /boot/vmlinuz-5.18-x86_64
[2022-07-05T19:32:13+0300] [ALPM-SCRIPTLET] Found initrd image: /boot/intel-ucode.img /boot/initramfs-5.18-x86_64.img
[2022-07-05T19:32:13+0300] [ALPM-SCRIPTLET] Found initrd fallback image: /boot/initramfs-5.18-x86_64-fallback.img
[2022-07-05T19:32:13+0300] [ALPM-SCRIPTLET] Warning: os-prober will not be executed to detect other bootable partitions.
[2022-07-05T19:32:13+0300] [ALPM-SCRIPTLET] Systems on them will not be added to the GRUB boot configuration.
[2022-07-05T19:32:13+0300] [ALPM-SCRIPTLET] Check GRUB_DISABLE_OS_PROBER documentation entry.
[2022-07-05T19:32:13+0300] [ALPM-SCRIPTLET] Detecting snapshots ...
[2022-07-05T19:32:14+0300] [ALPM-SCRIPTLET] Found snapshot: 2022-07-05 19:32:08 | timeshift-btrfs/snapshots/2022-07-05_19-32-08/@ | ondemand | {timeshift-autosnap} {created before upgrade} |
[2022-07-05T19:32:14+0300] [ALPM-SCRIPTLET] Found snapshot: 2022-07-05 00:32:10 | timeshift-btrfs/snapshots/2022-07-05_00-32-09/@ | ondemand | {timeshift-autosnap} {created before upgrade} |
[2022-07-05T19:32:14+0300] [ALPM-SCRIPTLET] Found snapshot: 2022-07-04 22:31:12 | timeshift-btrfs/snapshots/2022-07-04_22-31-12/@ | ondemand | {timeshift-autosnap} {created before upgrade} |
[2022-07-05T19:32:14+0300] [ALPM-SCRIPTLET] Found 3 snapshot(s)
[2022-07-05T19:32:14+0300] [ALPM-SCRIPTLET] Unmount /tmp/grub-btrfs.qPeHfJT8gz .. Success
[2022-07-05T19:32:14+0300] [ALPM-SCRIPTLET] Found memtest86+ image: /boot/memtest86+/memtest.bin
[2022-07-05T19:32:14+0300] [ALPM-SCRIPTLET] done
[2022-07-05T19:32:14+0300] [ALPM] transaction started
[2022-07-05T19:32:15+0300] [ALPM] upgraded hwdata (0.360-1 -> 0.361-1)
[2022-07-05T19:32:17+0300] [ALPM] upgraded libgphoto2 (2.5.29-1 -> 2.5.30-1)
[2022-07-05T19:32:17+0300] [ALPM] warning: /etc/mkinitcpio.conf installed as /etc/mkinitcpio.conf.pacnew
[2022-07-05T19:32:17+0300] [ALPM] upgraded mkinitcpio (31-2 -> 31-2.0)
[2022-07-05T19:32:18+0300] [ALPM] upgraded opensnitch-git (1.6.0rc1.r16.6666eb8-1 -> 1.6.0rc1.r18.560f5c3-1)
[2022-07-05T19:32:18+0300] [ALPM-SCRIPTLET]
[2022-07-05T19:32:18+0300] [ALPM-SCRIPTLET] Restart opensnitchd service:
[2022-07-05T19:32:18+0300] [ALPM-SCRIPTLET] systemctl daemon-reload
[2022-07-05T19:32:18+0300] [ALPM-SCRIPTLET] systemctl restart opensnitchd
[2022-07-05T19:32:19+0300] [ALPM] upgraded perl-alien-build (2.48-3 -> 2.49-1)
[2022-07-05T19:32:20+0300] [ALPM] upgraded webkit2gtk (2.36.3-1 -> 2.36.4-1)
[2022-07-05T19:32:21+0300] [ALPM] upgraded webkit2gtk-4.1 (2.36.3-1 -> 2.36.4-1)
[2022-07-05T19:32:29+0300] [ALPM] transaction completed
[2022-07-05T19:32:29+0300] [ALPM] running '30-systemd-daemon-reload.hook'...
[2022-07-05T19:32:31+0300] [ALPM] running '30-systemd-hwdb.hook'...
[2022-07-05T19:32:34+0300] [ALPM] running '30-systemd-tmpfiles.hook'...
[2022-07-05T19:32:34+0300] [ALPM] running '30-systemd-udev-reload.hook'...
[2022-07-05T19:32:34+0300] [ALPM] running '30-systemd-update.hook'...
[2022-07-05T19:32:35+0300] [ALPM] running '90-mkinitcpio-install.hook'...
[2022-07-05T19:32:35+0300] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux518.preset: 'default'
[2022-07-05T19:32:35+0300] [ALPM-SCRIPTLET] -> -k /boot/vmlinuz-5.18-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.18-x86_64.img
[2022-07-05T19:32:35+0300] [ALPM-SCRIPTLET] ==> Starting build: 5.18.9-1-MANJARO
[2022-07-05T19:32:35+0300] [ALPM-SCRIPTLET] -> Running build hook: [base]
[2022-07-05T19:32:36+0300] [ALPM-SCRIPTLET] -> Running build hook: [udev]
[2022-07-05T19:32:37+0300] [ALPM-SCRIPTLET] -> Running build hook: [autodetect]
[2022-07-05T19:32:37+0300] [ALPM-SCRIPTLET] -> Running build hook: [modconf]
[2022-07-05T19:32:38+0300] [ALPM-SCRIPTLET] -> Running build hook: [block]
[2022-07-05T19:32:39+0300] [ALPM-SCRIPTLET] -> Running build hook: [keyboard]
[2022-07-05T19:32:40+0300] [ALPM-SCRIPTLET] -> Running build hook: [keymap]
[2022-07-05T19:32:40+0300] [ALPM-SCRIPTLET] -> Running build hook: [consolefont]
[2022-07-05T19:32:40+0300] [ALPM-SCRIPTLET] ==> WARNING: consolefont: no font found in configuration
[2022-07-05T19:32:40+0300] [ALPM-SCRIPTLET] -> Running build hook: [encrypt]
[2022-07-05T19:32:51+0300] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: qat_4xxx
[2022-07-05T19:32:52+0300] [ALPM-SCRIPTLET] -> Running build hook: [filesystems]
[2022-07-05T19:32:53+0300] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2022-07-05T19:32:53+0300] [ALPM-SCRIPTLET] ==> Creating gzip-compressed initcpio image: /boot/initramfs-5.18-x86_64.img
[2022-07-05T19:32:57+0300] [ALPM-SCRIPTLET] ==> Image generation successful
[2022-07-05T19:32:57+0300] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux518.preset: 'fallback'
[2022-07-05T19:32:57+0300] [ALPM-SCRIPTLET] -> -k /boot/vmlinuz-5.18-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.18-x86_64-fallback.img -S autodetect
[2022-07-05T19:32:57+0300] [ALPM-SCRIPTLET] ==> Starting build: 5.18.9-1-MANJARO
[2022-07-05T19:32:57+0300] [ALPM-SCRIPTLET] -> Running build hook: [base]
[2022-07-05T19:32:58+0300] [ALPM-SCRIPTLET] -> Running build hook: [udev]
[2022-07-05T19:32:59+0300] [ALPM-SCRIPTLET] -> Running build hook: [modconf]
[2022-07-05T19:32:59+0300] [ALPM-SCRIPTLET] -> Running build hook: [block]
[2022-07-05T19:33:01+0300] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: bfa
[2022-07-05T19:33:02+0300] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: qed
[2022-07-05T19:33:03+0300] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: qla1280
[2022-07-05T19:33:03+0300] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: qla2xxx
[2022-07-05T19:33:04+0300] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: xhci_pci
[2022-07-05T19:33:06+0300] [ALPM-SCRIPTLET] -> Running build hook: [keyboard]
[2022-07-05T19:33:09+0300] [ALPM-SCRIPTLET] -> Running build hook: [keymap]
[2022-07-05T19:33:09+0300] [ALPM-SCRIPTLET] -> Running build hook: [consolefont]
[2022-07-05T19:33:09+0300] [ALPM-SCRIPTLET] ==> WARNING: consolefont: no font found in configuration
[2022-07-05T19:33:09+0300] [ALPM-SCRIPTLET] -> Running build hook: [encrypt]
[2022-07-05T19:33:11+0300] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: qat_4xxx
[2022-07-05T19:33:12+0300] [ALPM-SCRIPTLET] -> Running build hook: [filesystems]
[2022-07-05T19:33:18+0300] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2022-07-05T19:33:18+0300] [ALPM-SCRIPTLET] ==> Creating gzip-compressed initcpio image: /boot/initramfs-5.18-x86_64-fallback.img
[2022-07-05T19:33:32+0300] [ALPM-SCRIPTLET] ==> Image generation successful
[2022-07-05T19:33:32+0300] [ALPM] running '90-packagekit-refresh.hook'...
[2022-07-05T19:33:32+0300] [ALPM] running 'detect-old-perl-modules.hook'...
[2022-07-05T19:33:32+0300] [ALPM] running 'gtk-update-icon-cache.hook'...
[2022-07-05T19:33:32+0300] [ALPM] running 'update-desktop-database.hook'...
[2022-07-05T19:34:38+0300] [PACMAN] Running 'pacman -S mkinitcpio'
[2022-07-05T19:34:40+0300] [ALPM] running '00-timeshift-autosnap.hook'...
[2022-07-05T19:34:40+0300] [ALPM-SCRIPTLET] First run mode (config file not found)
[2022-07-05T19:34:40+0300] [ALPM-SCRIPTLET] Selected default snapshot type: BTRFS
[2022-07-05T19:34:40+0300] [ALPM-SCRIPTLET] Using system disk as snapshot device for creating snapshots in BTRFS mode
[2022-07-05T19:34:40+0300] [ALPM-SCRIPTLET] Mounted '/dev/dm-0 (sda1)' at '/run/timeshift/195722/backup'
[2022-07-05T19:34:40+0300] [ALPM-SCRIPTLET] Creating new backup...(BTRFS)
[2022-07-05T19:34:40+0300] [ALPM-SCRIPTLET] Saving to device: /dev/dm-0, mounted at path: /run/timeshift/195722/backup
[2022-07-05T19:34:40+0300] [ALPM-SCRIPTLET] Created directory: /run/timeshift/195722/backup/timeshift-btrfs/snapshots/2022-07-05_19-34-40
[2022-07-05T19:34:40+0300] [ALPM-SCRIPTLET] Created subvolume snapshot: /run/timeshift/195722/backup/timeshift-btrfs/snapshots/2022-07-05_19-34-40/@
[2022-07-05T19:34:40+0300] [ALPM-SCRIPTLET] Created control file: /run/timeshift/195722/backup/timeshift-btrfs/snapshots/2022-07-05_19-34-40/info.json
[2022-07-05T19:34:40+0300] [ALPM-SCRIPTLET] BTRFS Snapshot saved successfully (0s)
[2022-07-05T19:34:40+0300] [ALPM-SCRIPTLET] Tagged snapshot '2022-07-05_19-34-40': ondemand
[2022-07-05T19:34:40+0300] [ALPM-SCRIPTLET] ------------------------------------------------------------------------------
[2022-07-05T19:34:41+0300] [ALPM-SCRIPTLET]
[2022-07-05T19:34:41+0300] [ALPM-SCRIPTLET] Found stale mount for device '/dev/dm-0' at path '/run/timeshift/195722/backup'
[2022-07-05T19:34:41+0300] [ALPM-SCRIPTLET] Unmounted successfully
[2022-07-05T19:34:42+0300] [ALPM-SCRIPTLET] First run mode (config file not found)
[2022-07-05T19:34:42+0300] [ALPM-SCRIPTLET] Selected default snapshot type: BTRFS
[2022-07-05T19:34:42+0300] [ALPM-SCRIPTLET] Mounted '/dev/dm-0 (sda1)' at '/run/timeshift/195864/backup'
[2022-07-05T19:34:42+0300] [ALPM-SCRIPTLET] Selected default snapshot device: /dev/dm-0
[2022-07-05T19:34:42+0300] [ALPM-SCRIPTLET] ------------------------------------------------------------------------------
[2022-07-05T19:34:42+0300] [ALPM-SCRIPTLET] Removing snapshot: 2022-07-04_22-31-12
[2022-07-05T19:34:42+0300] [ALPM-SCRIPTLET] Deleting subvolume: @ (Id:473)
[2022-07-05T19:34:42+0300] [ALPM-SCRIPTLET] Deleted subvolume: @ (Id:473)
[2022-07-05T19:34:42+0300] [ALPM-SCRIPTLET] Deleted directory: /run/timeshift/195864/backup/timeshift-btrfs/snapshots/2022-07-04_22-31-12
[2022-07-05T19:34:42+0300] [ALPM-SCRIPTLET] Removed snapshot: 2022-07-04_22-31-12
[2022-07-05T19:34:42+0300] [ALPM-SCRIPTLET] Found stale mount for device '/dev/dm-0' at path '/run/timeshift/195864/backup'
[2022-07-05T19:34:42+0300] [ALPM-SCRIPTLET] Unmounted successfully
[2022-07-05T19:34:43+0300] [ALPM-SCRIPTLET] Generating grub configuration file ...
[2022-07-05T19:34:43+0300] [ALPM-SCRIPTLET] Found theme: /usr/share/grub/themes/manjaro/theme.txt
[2022-07-05T19:34:43+0300] [ALPM-SCRIPTLET] Found linux image: /boot/vmlinuz-5.18-x86_64
[2022-07-05T19:34:44+0300] [ALPM-SCRIPTLET] Found initrd image: /boot/intel-ucode.img /boot/initramfs-5.18-x86_64.img
[2022-07-05T19:34:44+0300] [ALPM-SCRIPTLET] Found initrd fallback image: /boot/initramfs-5.18-x86_64-fallback.img
[2022-07-05T19:34:44+0300] [ALPM-SCRIPTLET] Warning: os-prober will not be executed to detect other bootable partitions.
[2022-07-05T19:34:44+0300] [ALPM-SCRIPTLET] Systems on them will not be added to the GRUB boot configuration.
[2022-07-05T19:34:44+0300] [ALPM-SCRIPTLET] Check GRUB_DISABLE_OS_PROBER documentation entry.
[2022-07-05T19:34:44+0300] [ALPM-SCRIPTLET] Detecting snapshots ...
[2022-07-05T19:34:45+0300] [ALPM-SCRIPTLET] Found snapshot: 2022-07-05 19:34:40 | timeshift-btrfs/snapshots/2022-07-05_19-34-40/@ | ondemand | {timeshift-autosnap} {created before upgrade} |
[2022-07-05T19:34:45+0300] [ALPM-SCRIPTLET] Found snapshot: 2022-07-05 19:32:08 | timeshift-btrfs/snapshots/2022-07-05_19-32-08/@ | ondemand | {timeshift-autosnap} {created before upgrade} |
[2022-07-05T19:34:45+0300] [ALPM-SCRIPTLET] Found snapshot: 2022-07-05 00:32:10 | timeshift-btrfs/snapshots/2022-07-05_00-32-09/@ | ondemand | {timeshift-autosnap} {created before upgrade} |
[2022-07-05T19:34:45+0300] [ALPM-SCRIPTLET] Found 3 snapshot(s)
[2022-07-05T19:34:45+0300] [ALPM-SCRIPTLET] Unmount /tmp/grub-btrfs.kGgpHMrAdL .. Success
[2022-07-05T19:34:45+0300] [ALPM-SCRIPTLET] Found memtest86+ image: /boot/memtest86+/memtest.bin
[2022-07-05T19:34:45+0300] [ALPM-SCRIPTLET] done
[2022-07-05T19:34:45+0300] [ALPM] transaction started
[2022-07-05T19:34:45+0300] [ALPM] reinstalled mkinitcpio (31-2.0)
[2022-07-05T19:34:45+0300] [ALPM] transaction completed
[2022-07-05T19:34:45+0300] [ALPM] running '30-systemd-daemon-reload.hook'...
[2022-07-05T19:34:46+0300] [ALPM] running '30-systemd-tmpfiles.hook'...
[2022-07-05T19:34:46+0300] [ALPM] running '30-systemd-update.hook'...
[2022-07-05T19:34:46+0300] [ALPM] running '90-mkinitcpio-install.hook'...
[2022-07-05T19:34:46+0300] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux518.preset: 'default'
[2022-07-05T19:34:46+0300] [ALPM-SCRIPTLET] -> -k /boot/vmlinuz-5.18-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.18-x86_64.img
[2022-07-05T19:34:46+0300] [ALPM-SCRIPTLET] ==> Starting build: 5.18.9-1-MANJARO
[2022-07-05T19:34:47+0300] [ALPM-SCRIPTLET] -> Running build hook: [base]
[2022-07-05T19:34:47+0300] [ALPM-SCRIPTLET] -> Running build hook: [udev]
[2022-07-05T19:34:48+0300] [ALPM-SCRIPTLET] -> Running build hook: [autodetect]
[2022-07-05T19:34:49+0300] [ALPM-SCRIPTLET] -> Running build hook: [modconf]
[2022-07-05T19:34:49+0300] [ALPM-SCRIPTLET] -> Running build hook: [block]
[2022-07-05T19:34:50+0300] [ALPM-SCRIPTLET] -> Running build hook: [filesystems]
[2022-07-05T19:34:51+0300] [ALPM-SCRIPTLET] -> Running build hook: [keyboard]
[2022-07-05T19:34:51+0300] [ALPM-SCRIPTLET] -> Running build hook: [fsck]
[2022-07-05T19:34:52+0300] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2022-07-05T19:34:52+0300] [ALPM-SCRIPTLET] ==> Creating gzip-compressed initcpio image: /boot/initramfs-5.18-x86_64.img
[2022-07-05T19:34:55+0300] [ALPM-SCRIPTLET] ==> Image generation successful
[2022-07-05T19:34:55+0300] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux518.preset: 'fallback'
[2022-07-05T19:34:55+0300] [ALPM-SCRIPTLET] -> -k /boot/vmlinuz-5.18-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.18-x86_64-fallback.img -S autodetect
[2022-07-05T19:34:55+0300] [ALPM-SCRIPTLET] ==> Starting build: 5.18.9-1-MANJARO
[2022-07-05T19:34:55+0300] [ALPM-SCRIPTLET] -> Running build hook: [base]
[2022-07-05T19:34:56+0300] [ALPM-SCRIPTLET] -> Running build hook: [udev]
[2022-07-05T19:34:57+0300] [ALPM-SCRIPTLET] -> Running build hook: [modconf]
[2022-07-05T19:34:57+0300] [ALPM-SCRIPTLET] -> Running build hook: [block]
[2022-07-05T19:34:59+0300] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: bfa
[2022-07-05T19:35:01+0300] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: qed
[2022-07-05T19:35:01+0300] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: qla1280
[2022-07-05T19:35:01+0300] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: qla2xxx
[2022-07-05T19:35:03+0300] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: xhci_pci
[2022-07-05T19:35:05+0300] [ALPM-SCRIPTLET] -> Running build hook: [filesystems]
[2022-07-05T19:35:08+0300] [ALPM-SCRIPTLET] -> Running build hook: [keyboard]
[2022-07-05T19:35:11+0300] [ALPM-SCRIPTLET] -> Running build hook: [fsck]
[2022-07-05T19:35:15+0300] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2022-07-05T19:35:15+0300] [ALPM-SCRIPTLET] ==> Creating gzip-compressed initcpio image: /boot/initramfs-5.18-x86_64-fallback.img
[2022-07-05T19:35:33+0300] [ALPM-SCRIPTLET] ==> Image generation successful
[2022-07-05T19:35:34+0300] [ALPM] running '90-packagekit-refresh.hook'...
~/Desktop ❯
I have BTRFS, encrypted installation of Manjaro OS.
- First, I got the update of some packages incl.
- During this update I got warning about pacnew file of the
mkinitcpio.conf
. - I ran
sudo DIFFPROG=meld pacdiff
and replaced the old one with new one.
- After replacement I ran
sudo pacman -S mkinitcpio
in hope to apply new config. - After PC reboot I got the error posted in the first image.
a) What I did wrong?
b) How could I fix it?
Thanks!
