I get “shutdown failed with the exit code 1” on shutdown and restarts.
Also, my screen frequently starts flickering on boot. I have a nvidia GTX 1650 and am running linux58.
But the system shuts down, does reboot properly?
TheEpicProgrammer:
flickering
I usually recommend this, but of course adapted to your Monitor and connector + the kwin.sh part, and ONLY if we talk about a Desktop PC
The false is under the FREEDRIVER, but due to lack of formatting is hard to spot that
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-nvidia-450xx 2019.10.25 false PCI
Now you see what i mean.
@Rioluu - let me corre…
You could also try this
I believe I’ve found a fix. After toggling “Tearing prevention (vsync)” to “Never” in the compositor settings, the lag has seem to gone away. I rarely noticed tearing. It occasionally tears when dragging windows but that’s about it.
Appreciate you for taking the time to help!
Otherwise we would need more information from you, as described here:
Welcome to Manjaro!
To allow all of us helpful gurus on this forum TO HELP YOU, we need some basic information about your system. This probably means you described the symptoms of your problem, but now we need some more information to know where the origin of your issue is exactly.
Someone probably linked you to this tutorial, so if you’re reading this in response to a question, please click the green link above this text to bring you to the full and unabridged text of the tutorial…
Thanks
bogdancovaciu:
reboot properly?
It reboots with the error message but it still boots.
