MAYBL8
12 February 2026 14:29
1
(3/3) Remove DKMS modules
Error! nvidia/565.57.01: Missing the module source directory or the symbolic link pointing to it.
Manual intervention is required!
Error! nvidia/565.77: Missing the module source directory or the symbolic link pointing to it.
Error! nvidia/570.124.04: Missing the module source directory or the symbolic link pointing to it.
On my system I am using the nvidia 580 from the aur
more context prior to this partial message is probably needed
… this message was the result of which command?
DKMS driver modules require the kernel headers for the kernel(s) they are to be used with. So perhaps you had already removed the kernel headers packages?
In order to be sure, you’ll have to tell us what command you used that spawned these error messages.
MAYBL8
12 February 2026 15:00
4
Kernel update running just before this error:
Packages (2) linux612-6.12.70-1 linux612-headers-6.12.70-1
Total Download Size: 174.89 MiB
Total Installed Size: 283.35 MiB
Net Upgrade Size: 0.13 MiB
:: Retrieving packages...
linux612-6.12.70-1-x86_64 139.7 MiB 13.3 MiB/s 00:11 [----------------------------------------------------] 100%
linux612-headers-6.12.70-1-x86_64 35.2 MiB 934 KiB/s 00:39 [----------------------------------------------------] 100%
Total (2/2) 174.9 MiB 4.52 MiB/s 00:39 [----------------------------------------------------] 100%
(2/2) checking keys in keyring [----------------------------------------------------] 100%
(2/2) checking package integrity [----------------------------------------------------] 100%
(2/2) loading package files [----------------------------------------------------] 100%
(2/2) checking for file conflicts [----------------------------------------------------] 100%
(2/2) checking available disk space [----------------------------------------------------] 100%
(1/3) Saving Linux kernel modules...
(2/3) Removing linux initcpios...
I would try removing nvidia-dkms without checking dependencies.
sudo pacman -Rdd nvidia-dkms
MAYBL8
12 February 2026 15:06
6
[demo@Manjaro ~]$ sudo pacman -Rdd nvidia-dkms
error: target not found: nvidia-dkms
Well, which Nvidia packages do you have installed, then?
pacman -Qn | grep -i nvidia
If the list is too long to easily copy and paste directly from the terminal, then you can redirect that into a file.
pacman -Qn | grep -i nvidia > nvidiapkgs.txt
… and then you can open that in an editor and copy/paste from there.
MAYBL8
12 February 2026 15:19
8
[demo@Manjaro RustDesk-AppImage-Enhanced]$ pacman -Qn | grep -i nvidia
linux-firmware-nvidia 20260110-1
nvidia-580xx-dkms 580.126.09-2
nvidia-580xx-settings 580.126.09-1
nvidia-580xx-utils 580.126.09-2
nvidia-prime 1.0-5
I thought you said you installed the Nvidia driver from the AUR? The command I gave you only checks for packages from the repository.
MAYBL8
12 February 2026 15:33
10
9 aur/nvidia-580xx-dkms 580.126.09-2 (+55 24.45) (Installed)
NVIDIA kernel modules - module sources (580xx)
8 aur/nvidia-580xx-utils 580.126.09-2 (+55 24.45) (Installed)
NVIDIA drivers utilities (580xx)
Where does that output come from?
Just because you installed something through yay does not mean it comes from the AUR. yay is only a wrapper around pacman.
The output of the pacman command I gave you clearly shows that those Nvidia packages are from the repository.
MAYBL8
12 February 2026 15:52
14
Looks like there are files here I need to remove:
[demo@Manjaro ~]$ cd /var/lib/dkms
[demo@Manjaro dkms]$ ls
mok.key mok.pub nvidia vboxhost
[demo@Manjaro dkms]$ cd nvidia
[demo@Manjaro nvidia]$ ls
565.57.01 570.124.04 kernel-6.11.1-1-MANJARO-x86_64 kernel-6.12.1-4-MANJARO-x86_64 kernel-6.13.4-1-MANJARO-x86_64
565.77 580.126.09 kernel-6.12.10-1-MANJARO-x86_64 kernel-6.12.70-1-MANJARO-x86_64 original_module
j8a
12 February 2026 15:53
15
Hi @MAYBL8 ,
I wonder whether you could read this post in the last stable update about your nvidia driver, in order to solve your problem.
‘[Stable Update] 2026-02-01 - Kernels, COSMIC, Plasma, GNOME, Mesa - #2 by discobot ’
There is an answer for this In the 2025-12-15 Known issues and solution section.
Hope it help,
Regards,
MAYBL8
12 February 2026 16:22
16
my driver is loaded:
[demo@Manjaro ~]$ inxi -G
Device-1: Intel CometLake-U GT2 [UHD Graphics] driver: i915 v: kernel
Device-2: NVIDIA GP108M [GeForce MX250] driver: nvidia v: 580.126.09
Device-3: Chicony HP Wide Vision FHD Camera driver: uvcvideo type: USB
Display: x11 server: X.Org v: 21.1.21 with: Xwayland v: 24.1.9 driver: X:
loaded: modesetting,nvidia dri: iris gpu: i915 resolution: 3840x2160~60Hz
API: EGL v: 1.5 drivers: iris,nvidia,swrast
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 580.126.09
renderer: NVIDIA GeForce MX250/PCIe/SSE2
API: Vulkan v: 1.4.341 drivers: nvidia,intel surfaces: N/A
and I am on version 580.126.09 and am not noticing any flickering
You need to clean out all of this…
565.57.01
565.77
570.124.04
MAYBL8
12 February 2026 17:02
18
That’s the answer I was looking for.
Done thanks.
I knew I had done this before but didn’t remember where the files were I needed to clean up.
system
Closed
15 February 2026 17:03
19
