When I run sudo pacman -Syu.
It appears to work. But then it gives this error.
:: installing nvidia-utils (530.41.03-4) breaks dependency 'nvidia-utils=525.89.02' required by linux60-nvidia
Can I have some help here?
Manjaro Testing
6.0 is EOL (End of Life), remove it then update.
See:
Are you sure about that? The new NVIDIA driver is only in the unstable branch thus far.
Remove linux60
and linux60-nvidia
. It is EOL anyway.
Hope you are running a recent kernel.
Sorry I meant Manjaro Unstable. I will try that.
It seems to be updating. Thank you for your help.
system
Closed
6
