systemctl status smb.service
Γ smb.service - Samba SMB Daemon
Loaded: loaded (/usr/lib/systemd/system/smb.service; enabled; vendor prese>
Active: failed (Result: exit-code) since Thu 2022-01-27 16:04:38 EET; 1min>
Docs: man:smbd(8)
man:samba(7)
man:smb.conf(5)
Process: 2356 ExecStart=/usr/bin/smbd --foreground --no-process-group $SMBD>
Main PID: 2356 (code=exited, status=1/FAILURE)
CPU: 62ms
Jan 27 16:04:38 manjo-empty systemd[1]: Starting Samba SMB Daemon...
Jan 27 16:04:38 manjo-empty systemd[1]: smb.service: Main process exited, code=>
Jan 27 16:04:38 manjo-empty systemd[1]: smb.service: Failed with result 'exit-c>
Jan 27 16:04:38 manjo-empty systemd[1]: Failed to start Samba SMB Daemon.
lines 1-14/14 (END)...skipping...
Loaded: loaded (/usr/lib/systemd/system/smb.service; enabled; vendor preset: disabled)
Active: failed (Result: exit-code) since Thu 2022-01-27 16:04:38 EET; 1min 33s ago
Docs: man:smbd(8)
man:samba(7)
man:smb.conf(5)
Process: 2356 ExecStart=/usr/bin/smbd --foreground --no-process-group $SMBDOPTIONS (code=exited, status=1/FAILURE)
CPU: 62ms
Jan 27 16:04:38 manjo-empty systemd[1]: smb.service: Main process exited, code=exited, status=1/FAILURE
Jan 27 16:04:38 manjo-empty systemd[1]: smb.service: Failed with result 'exit-code'.
Run testparm in terminal to see if there is a problem with your smb.conf which is located in /etc/samba. I am assuming that you have manjaro-settings-samba installed.
Take a look at these:
https://wiki.manjaro.org/index.php/Using_Samba_in_your_File_Manager
Thanks, after using pamac install caja-share manjaro-settings-samba and pamac install gvfs-smb it start
sudo systemctl status smb
β smb.service - Samba SMB Daemon
Active: active (running) since Thu 2022-01-27 16:27:18 EET; 1min 11s ago
Docs: man:smbd(8)
man:samba(7)
man:smb.conf(5)
Main PID: 683 (smbd)
Status: "smbd: ready to serve connections..."
Tasks: 3 (limit: 7090)
Memory: 14.9M
CPU: 160ms
CGroup: /system.slice/smb.service
ββ683 /usr/bin/smbd --foreground --no-process-group
ββ696 /usr/bin/smbd --foreground --no-process-group
ββ697 /usr/bin/smbd --foreground --no-process-group
Jan 27 16:27:15 manjo-empty systemd[1]: Starting Samba SMB Daemon...
Jan 27 16:27:16 manjo-empty smbd[683]: [2022/01/27 16:27:16.598727, 0] ../../s>
Jan 27 16:27:16 manjo-empty smbd[683]: smbd version 4.15.3 started.
Jan 27 16:27:16 manjo-empty smbd[683]: Copyright Andrew Tridgell and the Samb>
Jan 27 16:27:18 manjo-empty systemd[1]: Started Samba SMB Daemon.
lines 1-21/21 (END)...skipping...
Docs: man:smbd(8)
man:samba(7)
man:smb.conf(5)
Memory: 14.9M
CPU: 160ms
Jan 27 16:27:16 manjo-empty smbd[683]: [2022/01/27 16:27:16.598727, 0] ../../source3/smbd/server.c:1739(main)
Jan 27 16:27:16 manjo-empty smbd[683]: Copyright Andrew Tridgell and the Samba Team 1992-2021
Tip: When pasting terminal output on Discourse forums, one can eitherβ¦
Use the Preformatted text </> toolbar button.
Add three backticks ` above and below the text (Markdown):
type or paste code here
Use HTML:
<pre><code>
</pre></code>
Iβve done it for you this time.
