I can't run Bitwarden's appimage with kernel 5.4.0-2
I installed the new kernel 5.4.0-2 and I see that my Bitwarden appimage doesn't start. I use costume launcher for it and it doesn't do anything now. I started it from terminal and I get:
$ ./Bitwarden-1.16.6-x86_64.AppImage
[1361:1129/135353.658006:FATAL:setuid_sandbox_host.cc(157)]
The SUID sandbox helper binary was found, but is not configured correctly.
Rather than run without sandboxing I'm aborting now.
You need to make sure that /tmp/.mount_BitwarzH6nu6/chrome-sandbox is owned by root and has mode 4755.
Trace/breakpoint trap (core dumped)
I looked and there is no /tmp/.mount_BitwarzH6nu6/chrome-sandbox.
I didn't have this problem with kernel 5.3.13-1. I can go back to that kernel but if there is a solution I'll be thankful for help.
Wait for 5.4.1-2 or edit some setting to allow appimage to work.
btw. Bitwarden is also available in the AUR...
https://aur.archlinux.org/packages/bitwarden-bin
I have run it from AUR for years, no issues.
Thank you for your advice! I updated to 5.4.1-2 just now and Bitwarden starts and runs well.
