I cant make a "on startup" virtual machine
xfce
#1
on manjaro-xfce-18.0.4-stable i cant make start up virtual machine that's name mikrotik from session & start up
when i reboot its do nothing
my virtual machine name is mikrotik
sorry my english language isn't well
Which software are you using?
There are categories for #other-languages . Posting in your native language is preferable to very broken English (even if you're trying to improve - highly technical subjects are not the best way to learn English).
#3
**i use virtual box 6 **
**i speaking arabic theres no one speaking manjaro :heart_eyes: **
all speaking ubuntu :sweat_smile:
#4
I don't know what you tried so far, but this command should work for you:
VBoxManage startvm "mikrotik"
To add that to the host startup, create the file mikrotik_vb_startup.desktop (but you can chose whatever name you want), and add this lines to it:
[Desktop Entry]
Name=mikrotik
Type=Application
Exec=VBoxManage startvm "mikrotik"
Terminal=false
Icon=virtualbox
Comment=start mikrotik virtual machine at startup
Save it and reboot.
#5
thanks for replying
Where do I put mikrotik_vb_startup.desktop
like home/new/something ?
#6
My bad, i forgot the most important ... you put it in /home/youruser/.config/autostart/
