I had to boot my main pc .
● lightdm.service - Light Display Manager
Loaded: loaded (/usr/lib/systemd/system/lightdm.service; enabled; vendor preset: disabled)
Active: active (running) since Tue 2020-12-29 19:20:43 AEST; 1h 38min ago
Docs: man:lightdm(1)
Main PID: 356 (lightdm)
Tasks: 4 (limit: 4247)
CGroup: /system.slice/lightdm.service
├─356 /usr/bin/lightdm
└─367 /usr/lib/Xorg :0 -seat seat0 -auth /run/lightdm/root/:0 -nolisten tcp vt7 -novtswitch
Dec 29 19:20:43 ManPi systemd[1]: Starting Light Display Manager...
Dec 29 19:20:43 ManPi systemd[1]: Started Light Display Manager.
Dec 29 19:20:43 ManPi lightdm[356]: Error getting user list from org.freedesktop.Accounts: GDBus.Error:org.freedesk>
Dec 29 19:20:46 ManPi lightdm[415]: Error getting user list from org.freedesktop.Accounts: GDBus.Error:org.freedesk>
Dec 29 19:20:46 ManPi lightdm[415]: pam_unix(lightdm-greeter:session): session opened for user lightdm(uid=972) by >
Dec 29 19:21:01 ManPi lightdm[463]: pam_systemd_home(lightdm:account): Not a user managed by systemd-homed: No home>
Dec 29 19:21:01 ManPi lightdm[463]: Error getting user list from org.freedesktop.Accounts: GDBus.Error:org.freedesk>
Dec 29 19:21:01 ManPi lightdm[463]: pam_unix(lightdm:session): session opened for user joel(uid=1000) by (uid=0)
Dec 29 19:21:02 ManPi lightdm[463]: Error opening audit socket: Protocol not supported
Dec 29 19:21:02 ManPi lightdm[463]: pam_env(lightdm:session): deprecated reading of user environment enabl
dmesg
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd083]
[ 0.000000] Linux version 5.10.0-rc7-1-MANJARO-ARM (ray@vim3) (aarch64-unknown-linux-gnu-gcc (GCC) 10.2.0, GNU ld (GNU Binutils) 2.35) #1 SMP PREEMPT Mon Dec 7 21:25:58 CST 2020
[ 0.000000] Machine model: Raspberry Pi 4 Model B Rev 1.2
[ 0.000000] efi: UEFI not found.
[ 0.000000] Reserved memory: created CMA memory pool at 0x000000001e800000, size 256 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000000000000-0x000000003fffffff]
[ 0.000000] DMA32 [mem 0x0000000040000000-0x00000000fbffffff]
[ 0.000000] Normal empty
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000000000000-0x000000003bffffff]
[ 0.000000] node 0: [mem 0x0000000040000000-0x00000000fbffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x00000000fbffffff]
[ 0.000000] On node 0 totalpages: 1015808
[ 0.000000] DMA zone: 3840 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 245760 pages, LIFO batch:63
[ 0.000000] DMA32 zone: 12032 pages used for memmap
[ 0.000000] DMA32 zone: 770048 pages, LIFO batch:63
[ 0.000000] percpu: Embedded 32 pages/cpu s91160 r8192 d31720 u131072
[ 0.000000] pcpu-alloc: s91160 r8192 d31720 u131072 alloc=32*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Detected PIPT I-cache on CPU0
[ 0.000000] CPU features: detected: Spectre-v2
[ 0.000000] CPU features: detected: Spectre-v4
[ 0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 999936
[ 0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 video=HDMI-A-1:1920x1080M@60 smsc95xx.macaddr=DC:A6:32:60:BA:44 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 root=LABEL=ROOT_MNJRO rw rootwait console=ttyS0,115200 console=tty1 selinux=0 plymouth.enable=0 smsc95xx.turbo_mode=N dwc_otg.lpm_enable=0 kgdboc=ttyS0,115200 elevator=noop usbhid.mousepoll=8 snd-bcm2835.enable_compat_alsa=0 audit=0
[ 0.000000] Kernel parameter elevator= does not have any effect anymore.
Please use sysfs to set IO scheduler for individual devices.
[ 0.000000] audit: disabled (until reboot)
[ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] software IO TLB: mapped [mem 0x0000000038000000-0x000000003c000000] (64MB)
[ 0.000000] Memory: 3624736K/4063232K available (11520K kernel code, 2390K rwdata, 3956K rodata, 3648K init, 1401K bss, 176352K reserved, 262144K cma-reserved)
[ 0.000000] random: get_random_u64 called from cache_random_seq_create+0x90/0x190 with crng_init=0
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] ftrace: allocating 35772 entries in 140 pages
[ 0.000000] ftrace: allocated 140 pages with 3 groups
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] Rude variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
[ 0.000006] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
[ 0.000262] Console: colour dummy device 80x25
[ 0.000802] printk: console [tty1] enabled
[ 0.000863] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=216000)
[ 0.000905] pid_max: default: 32768 minimum: 301
[ 0.001128] LSM: Security Framework initializing
[ 0.001387] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.001470] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.002975] Disabling memory control group subsystem
[ 0.004900] rcu: Hierarchical SRCU implementation.
[ 0.005966] EFI services will not be available.
[ 0.006492] smp: Bringing up secondary CPUs ...
[ 0.007498] Detected PIPT I-cache on CPU1
[ 0.007581] CPU1: Booted secondary processor 0x0000000001 [0x410fd083]
[ 0.008814] Detected PIPT I-cache on CPU2
[ 0.008862] CPU2: Booted secondary processor 0x0000000002 [0x410fd083]
[ 0.009911] Detected PIPT I-cache on CPU3
[ 0.009959] CPU3: Booted secondary processor 0x0000000003 [0x410fd083]
[ 0.010107] smp: Brought up 1 node, 4 CPUs
[ 0.010196] SMP: Total of 4 processors activated.
[ 0.010219] CPU features: detected: 32-bit EL0 Support
[ 0.010242] CPU features: detected: CRC32 instructions
[ 0.010265] CPU features: detected: 32-bit EL1 Support
[ 0.045392] CPU: All CPU(s) started at EL2
[ 0.045480] alternatives: patching kernel code
[ 0.047438] devtmpfs: initialized
[ 0.058330] Enabled cp15_barrier support
[ 0.058397] Enabled setend support
[ 0.059172] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.059218] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.066886] pinctrl core: initialized pinctrl subsystem
[ 0.067766] DMI not present or invalid.
[ 0.068230] NET: Registered protocol family 16
[ 0.071225] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
[ 0.071505] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.072466] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.073065] thermal_sys: Registered thermal governor 'step_wise'
[ 0.073603] cpuidle: using governor menu
[ 0.073859] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.074040] ASID allocator initialised with 65536 entries
[ 0.074275] Serial: AMBA PL011 UART driver
[ 0.102815] bcm2835-mbox fe00b880.mailbox: mailbox enabled
[ 0.104283] raspberrypi-firmware soc:firmware: Attached to firmware from 2020-12-15T18:28:46, variant start
[ 0.108296] raspberrypi-firmware soc:firmware: Firmware hash is 4b4aff21f72c5b9ba39d83c7b0f8fa910a6ef99b
[ 0.142522] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1
[ 0.146570] vgaarb: loaded
[ 0.147047] SCSI subsystem initialized
[ 0.147301] usbcore: registered new interface driver usbfs
[ 0.147378] usbcore: registered new interface driver hub
[ 0.147523] usbcore: registered new device driver usb
[ 0.147842] usb_phy_generic phy: supply vcc not found, using dummy regulator
[ 0.149560] clocksource: Switched to clocksource arch_sys_counter
[ 1.173182] VFS: Disk quotas dquot_6.6.0
[ 1.173325] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 1.173518] FS-Cache: Loaded
[ 1.173796] CacheFiles: Loaded
[ 1.175083] simple-framebuffer 3e3cf000.framebuffer: framebuffer at 0x3e3cf000, 0x7f8000 bytes, mapped to 0x(____ptrval____)
[ 1.175118] simple-framebuffer 3e3cf000.framebuffer: format=a8r8g8b8, mode=1920x1080x32, linelength=7680
[ 1.187214] Console: switching to colour frame buffer device 240x67
[ 1.198218] simple-framebuffer 3e3cf000.framebuffer: fb0: simplefb registered!
[ 1.208302] NET: Registered protocol family 2
[ 1.209251] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
[ 1.209391] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 1.209734] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear)
[ 1.210309] TCP: Hash tables configured (established 32768 bind 32768)
[ 1.210634] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
[ 1.210781] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
[ 1.211197] NET: Registered protocol family 1
[ 1.212252] RPC: Registered named UNIX socket transport module.
[ 1.212333] RPC: Registered udp transport module.
[ 1.212394] RPC: Registered tcp transport module.
[ 1.212457] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.212546] PCI: CLS 0 bytes, default 64
[ 1.212854] Trying to unpack rootfs image as initramfs...
[ 1.682853] Freeing initrd memory: 6876K
[ 1.684889] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[ 1.685290] kvm [1]: IPA Size Limit: 44 bits
[ 1.686609] kvm [1]: vgic interrupt IRQ9
[ 1.686931] kvm [1]: Hyp mode initialized successfully
[ 1.689335] Initialise system trusted keyrings
[ 1.689802] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[ 1.696405] zbud: loaded
[ 1.698451] FS-Cache: Netfs 'nfs' registered for caching
[ 1.699256] NFS: Registering the id_resolver key type
[ 1.699356] Key type id_resolver registered
[ 1.699412] Key type id_legacy registered
[ 1.699583] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 1.701909] Key type asymmetric registered
[ 1.701978] Asymmetric key parser 'x509' registered
[ 1.702083] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[ 1.702446] io scheduler mq-deadline registered
[ 1.702511] io scheduler kyber registered
[ 1.702698] io scheduler bfq registered
[ 1.706866] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
[ 1.706977] brcm-pcie fd500000.pcie: No bus range found for /scb/pcie@7d500000, using [bus 00-ff]
[ 1.707136] brcm-pcie fd500000.pcie: MEM 0x0600000000..0x063fffffff -> 0x00c0000000
[ 1.710221] brcm-pcie fd500000.pcie: IB MEM 0x0000000000..0x00bfffffff -> 0x0400000000
[ 1.763655] brcm-pcie fd500000.pcie: link up, 5.0 GT/s PCIe x1 (SSC)
[ 1.766889] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
[ 1.769824] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 1.772683] pci_bus 0000:00: root bus resource [mem 0x600000000-0x63fffffff] (bus address [0xc0000000-0xffffffff])
[ 1.775671] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
[ 1.778783] pci 0000:00:00.0: PME# supported from D0 D3hot
[ 1.785332] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
[ 1.788356] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[ 1.791640] pci 0000:01:00.0: PME# supported from D0 D3cold
[ 1.798012] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
[ 1.800807] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
[ 1.803677] pci 0000:00:00.0: PCI bridge to [bus 01]
[ 1.806537] pci 0000:00:00.0: bridge window [mem 0x600000000-0x6000fffff]
[ 1.816710] iproc-rng200 fe104000.rng: hwrng registered
[ 1.819967] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
[ 1.823863] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
[ 1.827204] cacheinfo: Unable to detect cache hierarchy for CPU 0
[ 1.842256] brd: module loaded
[ 1.859182] loop: module loaded
[ 1.863791] Loading iSCSI transport class v2.0-870.
[ 1.868999] libphy: Fixed MDIO Bus: probed
[ 1.873071] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
[ 1.885588] libphy: bcmgenet MII bus: probed
[ 1.941714] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
[ 1.945706] usbcore: registered new interface driver r8152
[ 1.948555] usbcore: registered new interface driver lan78xx
[ 1.951326] usbcore: registered new interface driver smsc95xx
[ 1.956714] pci 0000:00:00.0: enabling device (0000 -> 0002)
[ 1.959445] xhci_hcd 0000:01:00.0: enabling device (0000 -> 0002)
[ 1.962232] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 1.964901] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
[ 1.968305] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0000018000000890
[ 1.972290] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ 1.974999] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.977697] usb usb1: Product: xHCI Host Controller
[ 1.980392] usb usb1: Manufacturer: Linux 5.10.0-rc7-1-MANJARO-ARM xhci-hcd
[ 1.983088] usb usb1: SerialNumber: 0000:01:00.0
[ 1.986549] hub 1-0:1.0: USB hub found
[ 1.989318] hub 1-0:1.0: 1 port detected
[ 1.992700] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 1.995392] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
[ 1.998077] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
[ 2.001152] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[ 2.003888] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.006613] usb usb2: Product: xHCI Host Controller
[ 2.009290] usb usb2: Manufacturer: Linux 5.10.0-rc7-1-MANJARO-ARM xhci-hcd
[ 2.012007] usb usb2: SerialNumber: 0000:01:00.0
[ 2.015375] hub 2-0:1.0: USB hub found
[ 2.018122] hub 2-0:1.0: 4 ports detected
[ 2.022388] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 2.025347] dwc_otg: FIQ enabled
[ 2.025358] dwc_otg: NAK holdoff enabled
[ 2.025368] dwc_otg: FIQ split-transaction FSM enabled
[ 2.025382] Module dwc_common_port init
[ 2.026090] usbcore: registered new interface driver uas
[ 2.028890] usbcore: registered new interface driver usb-storage
[ 2.031801] mousedev: PS/2 mouse device common for all mice
[ 2.036390] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[ 2.042652] sdhci: Secure Digital Host Controller Interface driver
[ 2.045341] sdhci: Copyright(c) Pierre Ossman
[ 2.048714] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferring probe
[ 2.051603] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.054730] ledtrig-cpu: registered to indicate activity on CPUs
[ 2.056167] hid: raw HID events driver (C) Jiri Kosina
[ 2.057528] usbcore: registered new interface driver usbhid
[ 2.058814] usbhid: USB HID core driver
[ 2.060228] ashmem: initialized
[ 2.065397] Initializing XFRM netlink socket
[ 2.066808] NET: Registered protocol family 17
[ 2.068219] Key type dns_resolver registered
[ 2.069872] registered taskstats version 1
[ 2.071331] Loading compiled-in X.509 certificates
[ 2.072949] Key type ._fscrypt registered
[ 2.074197] Key type .fscrypt registered
[ 2.075401] Key type fscrypt-provisioning registered
[ 2.081502] uart-pl011 fe201000.serial: there is not valid maps for state default
[ 2.084629] uart-pl011 fe201000.serial: cts_event_workaround enabled
[ 2.086044] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 21, base_baud = 0) is a PL011 rev2
[ 2.092012] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[ 2.095548] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
[ 2.096807] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
[ 2.123183] of_cfs_init
[ 2.124795] of_cfs_init: OK
[ 2.139756] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 2.142598] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 2.145423] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 2.149463] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 2.152263] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 2.160834] mmc0: SDHCI controller on fe340000.emmc2 [fe340000.emmc2] using ADMA
[ 2.166533] Freeing unused kernel memory: 3648K
[ 2.167817] Run /init as init process
[ 2.168980] with arguments:
[ 2.168985] /init
[ 2.168988] with environment:
[ 2.168992] HOME=/
[ 2.168996] TERM=linux
[ 2.169001] selinux=0
[ 2.169005] kgdboc=ttyS0,115200
[ 2.185635] random: fast init done
[ 2.212279] mmc1: new high speed SDIO card at address 0001
[ 2.264432] mmc0: new ultra high speed DDR50 SDXC card at address aaaa
[ 2.266534] mmcblk0: mmc0:aaaa SC128 119 GiB
[ 2.271169] mmcblk0: p1 p2
[ 2.325600] usb 1-1: new high-speed USB device number 2 using xhci_hcd
[ 2.476234] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
[ 2.477458] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 2.478676] usb 1-1: Product: USB2.0 Hub
[ 2.481730] hub 1-1:1.0: USB hub found
[ 2.483166] hub 1-1:1.0: 4 ports detected
[ 2.682427] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 2.777577] usb 1-1.3: new full-speed USB device number 3 using xhci_hcd
[ 2.892682] usb 1-1.3: New USB device found, idVendor=046d, idProduct=c52b, bcdDevice=12.10
[ 2.895472] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.898117] usb 1-1.3: Product: USB Receiver
[ 2.901038] usb 1-1.3: Manufacturer: Logitech
[ 2.915789] input: Logitech USB Receiver as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.3/1-1.3:1.0/0003:046D:C52B.0001/input/input0
[ 2.982499] hid-generic 0003:046D:C52B.0001: input,hidraw0: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-0000:01:00.0-1.3/input0
[ 2.996502] input: Logitech USB Receiver Mouse as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.3/1-1.3:1.1/0003:046D:C52B.0002/input/input1
[ 3.000302] input: Logitech USB Receiver Consumer Control as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.3/1-1.3:1.1/0003:046D:C52B.0002/input/input2
[ 3.062078] input: Logitech USB Receiver System Control as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.3/1-1.3:1.1/0003:046D:C52B.0002/input/input3
[ 3.066100] hid-generic 0003:046D:C52B.0002: input,hiddev96,hidraw1: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-0000:01:00.0-1.3/input1
[ 3.077749] hid-generic 0003:046D:C52B.0003: hiddev97,hidraw2: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:01:00.0-1.3/input2
[ 3.166004] systemd[1]: System time before build time, advancing clock.
[ 3.265899] NET: Registered protocol family 10
[ 3.270761] Segment Routing with IPv6
[ 3.330022] systemd[1]: systemd 247.2-1-arch running in system mode. (+PAM +AUDIT -SELINUX -IMA -APPARMOR +SMACK -SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +ZSTD +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid)
[ 3.337765] systemd[1]: Detected architecture arm64.
[ 3.386842] systemd[1]: Set hostname to <ManPi>.
[ 4.105929] systemd[1]: /usr/lib/systemd/system/stop-dmesg.service:2: Unknown key name 'USER' in section 'Unit', ignoring.
[ 4.127841] systemd[1]: Queued start job for default target Graphical Interface.
[ 4.130475] random: systemd: uninitialized urandom read (16 bytes read)
[ 4.154292] systemd[1]: Created slice system-getty.slice.
[ 4.158844] random: systemd: uninitialized urandom read (16 bytes read)
[ 4.161951] systemd[1]: Created slice system-modprobe.slice.
[ 4.166138] random: systemd: uninitialized urandom read (16 bytes read)
[ 4.168780] systemd[1]: Created slice User and Session Slice.
[ 4.172862] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 4.176957] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 4.181390] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 4.185399] systemd[1]: Reached target Local Encrypted Volumes.
[ 4.189353] systemd[1]: Reached target Login Prompts.
[ 4.193180] systemd[1]: Reached target Paths.
[ 4.196943] systemd[1]: Reached target Remote Encrypted Volumes.
[ 4.200720] systemd[1]: Reached target Remote File Systems.
[ 4.204523] systemd[1]: Reached target Slices.
[ 4.208326] systemd[1]: Reached target Swap.
[ 4.212259] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[ 4.216335] systemd[1]: Listening on LVM2 metadata daemon socket.
[ 4.220389] systemd[1]: Listening on LVM2 poll daemon socket.
[ 4.229477] systemd[1]: Listening on Process Core Dump Socket.
[ 4.241956] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
[ 4.244610] systemd[1]: Listening on Journal Socket (/dev/log).
[ 4.249612] systemd[1]: Listening on Journal Socket.
[ 4.254633] systemd[1]: Listening on Network Service Netlink Socket.
[ 4.265307] systemd[1]: Listening on udev Control Socket.
[ 4.269640] systemd[1]: Listening on udev Kernel Socket.
[ 4.273807] systemd[1]: Listening on User Database Manager Socket.
[ 4.278028] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
[ 4.282101] systemd[1]: Mounting POSIX Message Queue File System...
[ 4.288338] systemd[1]: Mounting Kernel Debug File System...
[ 4.295089] systemd[1]: Mounting Kernel Trace File System...
[ 4.302198] systemd[1]: Mounting Temporary Directory (/tmp)...
[ 4.308849] systemd[1]: Starting Create list of static device nodes for the current kernel...
[ 4.315581] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
[ 4.321846] systemd[1]: Starting Load Kernel Module configfs...
[ 4.328858] systemd[1]: Starting Load Kernel Module drm...
[ 4.336303] systemd[1]: Starting Load Kernel Module fuse...
[ 4.357255] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[ 4.373796] fuse: init (API version 7.32)
[ 4.375148] systemd[1]: Starting Load Kernel Modules...
[ 4.383712] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 4.388942] systemd[1]: Condition check resulted in Repartition Root Disk being skipped.
[ 4.393475] systemd[1]: Starting Coldplug All udev Devices...
[ 4.402332] systemd[1]: Mounted POSIX Message Queue File System.
[ 4.405906] systemd[1]: Mounted Kernel Debug File System.
[ 4.410009] systemd[1]: Mounted Kernel Trace File System.
[ 4.416425] systemd[1]: Mounted Temporary Directory (/tmp).
[ 4.423624] systemd[1]: Finished Create list of static device nodes for the current kernel.
[ 4.430038] i2c /dev entries driver
[ 4.435767] systemd[1]: modprobe@configfs.service: Succeeded.
[ 4.438418] systemd[1]: Finished Load Kernel Module configfs.
[ 4.443105] systemd[1]: modprobe@drm.service: Succeeded.
[ 4.445938] systemd[1]: Finished Load Kernel Module drm.
[ 4.450188] systemd[1]: modprobe@fuse.service: Succeeded.
[ 4.452578] systemd[1]: Finished Load Kernel Module fuse.
[ 4.457490] systemd[1]: Finished Load Kernel Modules.
[ 4.462089] systemd[1]: Finished Remount Root and Kernel File Systems.
[ 4.468642] systemd[1]: Mounting FUSE Control File System...
[ 4.475127] systemd[1]: Mounting Kernel Configuration File System...
[ 4.479725] systemd[1]: Condition check resulted in First Boot Wizard being skipped.
[ 4.483099] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
[ 4.484925] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
[ 4.489357] systemd[1]: Starting Load/Save Random Seed...
[ 4.495330] systemd[1]: Starting Apply Kernel Variables...
[ 4.499781] systemd[1]: Condition check resulted in Create System Users being skipped.
[ 4.505457] systemd[1]: Starting Create Static Device Nodes in /dev...
[ 4.514523] systemd[1]: Mounted FUSE Control File System.
[ 4.520013] systemd[1]: Mounted Kernel Configuration File System.
[ 4.542262] systemd[1]: Finished Apply Kernel Variables.
[ 4.568613] systemd[1]: Finished Create Static Device Nodes in /dev.
[ 4.575288] systemd[1]: Started Entropy Daemon based on the HAVEGE algorithm.
[ 4.583622] systemd[1]: Starting Journal Service...
[ 4.591743] systemd[1]: Starting Rule-based Manager for Device Events and Files...
[ 4.652182] systemd[1]: Finished Coldplug All udev Devices.
[ 4.724024] systemd[1]: Started Journal Service.
[ 5.171451] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initialised: Registers at 0xfeb00000 length 0x00010000
[ 5.215329] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem initialised: Registers at 0xfeb10000 length 0x00001000
[ 5.220282] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initialised: Registers at 0xfeb20000 length 0x00010000
[ 5.224614] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initialised: Registers at 0xfeb30000 length 0x00010000
[ 5.244207] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.248285] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
[ 5.253458] [vc_sm_connected_init]: start
[ 5.264152] random: crng init done
[ 5.266364] random: 7 urandom warning(s) missed due to ratelimiting
[ 5.272310] [vc_sm_connected_init]: installed successfully
[ 5.285075] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.294622] mc: Linux media interface: v0.10
[ 5.312291] bcm2835_audio bcm2835_audio: card created with 4 channels
[ 5.317261] bcm2835_audio bcm2835_audio: card created with 4 channels
[ 5.354258] videodev: Linux video capture interface: v2.00
[ 5.355154] vc4-drm gpu: bound fe600000.firmwarekms (ops vc4_fkms_ops [vc4])
[ 5.359611] checking generic (3e3cf000 7f8000) vs hw (0 ffffffffffffffff)
[ 5.359622] fb0: switching to vc4drmfb from simple
[ 5.366047] Console: switching to colour dummy device 80x25
[ 5.370017] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 0
[ 5.376849] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 1
[ 5.444344] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 5.465795] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.467048] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.472406] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.473348] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.478446] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.483733] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
[ 5.483758] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
[ 5.484189] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
[ 5.484512] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
[ 5.485328] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
[ 5.486604] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
[ 5.486625] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[ 5.486634] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[ 5.486641] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[ 5.486659] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[ 5.487405] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
[ 5.499177] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
[ 5.500082] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
[ 5.506202] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
[ 5.506225] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
[ 5.539518] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 5.591041] Console: switching to colour frame buffer device 240x67
[ 5.613183] brcmfmac: F1 signature read @0x18000000=0x15264345
[ 5.618148] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 5.618987] usbcore: registered new interface driver brcmfmac
[ 5.620103] vc4-drm gpu: [drm] fb0: vc4drmfb frame buffer device
[ 5.746744] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 5.886104] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 5.896527] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Mar 23 2020 02:19:54 version 7.45.206 (r725000 CY) FWID 01-88ee44ea
[ 6.056834] uart-pl011 fe201000.serial: no DMA platform data
[ 6.255835] zram: Added device: zram0
[ 6.280569] zram0: detected capacity change from 0 to 5986414592
[ 6.361595] Adding 5846104k swap on /dev/zram0. Priority:100 extents:1 across:5846104k SSFS
[ 7.185301] bcmgenet fd580000.ethernet: configuring instance for external RGMII (RX delay)
[ 7.185627] bcmgenet fd580000.ethernet eth0: Link is Down
[ 7.228758] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
[ 8.063800] logitech-djreceiver 0003:046D:C52B.0003: hiddev96,hidraw0: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:01:00.0-1.3/input2
[ 8.190608] input: Logitech Wireless Device PID:406f Keyboard as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.3/1-1.3:1.2/0003:046D:C52B.0003/0003:046D:406F.0004/input/input5
[ 8.191674] input: Logitech Wireless Device PID:406f Mouse as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.3/1-1.3:1.2/0003:046D:C52B.0003/0003:046D:406F.0004/input/input6
[ 8.192217] input: Logitech Wireless Device PID:406f Consumer Control as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.3/1-1.3:1.2/0003:046D:C52B.0003/0003:046D:406F.0004/input/input7
[ 8.192583] input: Logitech Wireless Device PID:406f System Control as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.3/1-1.3:1.2/0003:046D:C52B.0003/0003:046D:406F.0004/input/input8
[ 8.193003] hid-generic 0003:046D:406F.0004: input,hidraw1: USB HID v1.11 Keyboard [Logitech Wireless Device PID:406f] on usb-0000:01:00.0-1.3/input2:2
[ 8.197278] input: Logitech Wireless Device PID:4024 Keyboard as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.3/1-1.3:1.2/0003:046D:C52B.0003/0003:046D:4024.0005/input/input12
[ 8.205892] input: Logitech Wireless Device PID:4024 Mouse as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.3/1-1.3:1.2/0003:046D:C52B.0003/0003:046D:4024.0005/input/input13
[ 8.206665] input: Logitech Wireless Device PID:4024 Consumer Control as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.3/1-1.3:1.2/0003:046D:C52B.0003/0003:046D:4024.0005/input/input14
[ 8.206925] input: Logitech Wireless Device PID:4024 System Control as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.3/1-1.3:1.2/0003:046D:C52B.0003/0003:046D:4024.0005/input/input15
[ 8.207158] hid-generic 0003:046D:4024.0005: input,hidraw2: USB HID v1.11 Keyboard [Logitech Wireless Device PID:4024] on usb-0000:01:00.0-1.3/input2:3
[ 8.509124] input: Logitech MX Ergo as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.3/1-1.3:1.2/0003:046D:C52B.0003/0003:046D:406F.0004/input/input19
[ 8.510075] logitech-hidpp-device 0003:046D:406F.0004: input,hidraw1: USB HID v1.11 Keyboard [Logitech MX Ergo] on usb-0000:01:00.0-1.3/input2:2
[ 8.727625] input: Logitech K400 as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.3/1-1.3:1.2/0003:046D:C52B.0003/0003:046D:4024.0005/input/input20
[ 8.728978] logitech-hidpp-device 0003:046D:4024.0005: input,hidraw2: USB HID v1.11 Keyboard [Logitech K400] on usb-0000:01:00.0-1.3/input2:3
[ 13.297128] logitech-hidpp-device 0003:046D:4024.0005: HID++ 2.0 device connected.
[ 13.808169] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save disabled
[ 28.382313] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 5603.606065] logitech-hidpp-device 0003:046D:406F.0004: HID++ 4.5 device connected.
