I’m going to assume that this is related to my graphics card (Nvidia GeForce 830M) but I can’t be sure so feel free to tell me where I should post this instead.
The issue I’m dealing with is only occurring after running the command optimus-manager --switch nvidia
If i wait, for about 10 minutes without touching my computer, it will put itself in standby except I don’t seem to be able to do anything except shutting down my pc by pressing for several seconds the power button (i don’t know if it really is in standby because the power button will still be lit, and the screen is blank but not off)
This caused me some issues when it happened during the installation of a package, I had to shut down the pc and it led to some issues with missing files necessary to booting
I’d like to run my programs on my nvidia card and not have to shut down my pc everytime i leave it 10 minutes, so any help is appreciated.
xrandr output (i don’t know if that’s relevant)
Screen 0: minimum 320 x 200, current 1366 x 768, maximum 16384 x 16384
eDP-1 connected primary 1366x768+0+0 (normal left inverted right x axis y axis) 309mm x 173mm
1366x768 60.00*+ 48.00
1280x720 60.00 59.99 59.86 59.74
1024x768 60.04 60.00
960x720 60.00
928x696 60.05
896x672 60.01
1024x576 59.95 59.96 59.90 59.82
960x600 59.93 60.00
960x540 59.96 59.99 59.63 59.82
800x600 60.00 60.32 56.25
840x525 60.01 59.88
864x486 59.92 59.57
700x525 59.98
800x450 59.95 59.82
640x512 60.02
700x450 59.96 59.88
640x480 60.00 59.94
720x405 59.51 58.99
684x384 59.88 59.85
640x400 59.88 59.98
640x360 59.86 59.83 59.84 59.32
512x384 60.00
512x288 60.00 59.92
480x270 59.63 59.82
400x300 60.32 56.34
432x243 59.92 59.57
320x240 60.05
360x202 59.51 59.13
320x180 59.84 59.32
HDMI-1 disconnected (normal left inverted right x axis y axis)
DP-1 disconnected (normal left inverted right x axis y axis)
HDMI-2 disconnected (normal left inverted right x axis y axis)
output of : inxi --admin --verbosity=7 --filter --width
Kernel: 5.15.49-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=f4c74f99-4d25-41cc-ab23-54fd74606ad3 rw nouveau.modset=0 quiet
Desktop: Xfce v: 4.16.0 tk: Gtk v: 3.24.29 info: xfce4-panel wm: xfwm
v: 4.16.1 vt: 7 dm: LightDM v: 1.30.0 Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: Dell product: Latitude E5450 v: N/A
serial: <superuser required> Chassis: type: 9 serial: <superuser required>
Mobo: Dell model: 06J17N v: A00 serial: <superuser required>
UEFI-[Legacy]: Dell v: A15 date: 05/09/2017
ID-1: BAT0 charge: 38.0 Wh (100.0%) condition: 38.0/51.7 Wh (73.5%)
volts: 8.4 min: 7.6 model: Samsung SDI DELL 1KY05D9 type: Li-poly
serial: <filter> status: full
RAM: total: 3.72 GiB used: 2.8 GiB (75.3%)
RAM Report:
Info: model: Intel Core i5-5300U bits: 64 type: MT MCP arch: Broadwell
gen: core 5 built: 2015-18 process: Intel 14nm family: 6 model-id: 0x3D (61)
stepping: 4 microcode: 0x2F
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 1131 high: 1692 min/max: 500/2900 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 1692 2: 799 3: 1237
4: 798 bogomips: 18367
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon
avx avx2 bmi1 bmi2 bts clflush cmov constant_tsc cpuid cpuid_fault cx16 cx8
de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
flush_l1d fma fpu fsgsbase fxsr hle ht ibpb ibrs ida intel_pt invpcid
invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe msr mtrr
nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln
pni popcnt pse pse36 pti pts rdrand rdseed rdtscp rep_good rtm sdbg sep
smap smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
xsave xsaveopt xtopology xtpr
Type: l1tf
Type: tsx_async_abort mitigation: Clear CPU buffers; SMT vulnerable
Device-1: Intel HD Graphics 5500 vendor: Dell driver: i915 v: kernel
arch: Gen8 process: Intel 14nm built: 2014-15 ports: active: eDP-1
empty: DP-1,HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:1616
class-ID: 0300
Device-2: NVIDIA GM108M [GeForce 830M] vendor: Dell driver: N/A
alternate: nouveau, nvidia_drm, nvidia non-free: 515.xx+
status: current (as of 2022-06) arch: Maxwell process: TSMC 28nm
built: 2014-19 pcie: gen: 2 speed: 5 GT/s lanes: 4 link-max: gen: 3
speed: 8 GT/s bus-ID: 03:00.0 chip-ID: 10de:1340 class-ID: 0302
Device-3: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo
bus-ID: 1-1.6:4 chip-ID: 0c45:6709 class-ID: 0e02
Display: x11 server: X.Org v: 21.1.3 compositor: xfwm v: 4.16.1 driver: X:
loaded: modesetting gpu: i915 display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.21x7.99")
s-diag: 414mm (16.31")
Monitor-1: eDP-1 model: BOE Display 0x05f3 built: 2013 res: 1366x768
hz: 60 dpi: 112 gamma: 1.2 size: 309x173mm (12.17x6.81") diag: 354mm (13.9")
ratio: 16:9 modes: 1366x768
OpenGL: renderer: Mesa Intel HD Graphics 5500 (BDW GT2) v: 4.6 Mesa 22.1.2
direct render: Yes
Device-1: Intel Broadwell-U Audio vendor: Dell driver: snd_hda_intel
v: kernel bus-ID: 00:03.0 chip-ID: 8086:160c class-ID: 0403
Device-2: Intel Wildcat Point-LP High Definition Audio vendor: Dell
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:9ca0
class-ID: 0403
Sound Server-1: ALSA v: k5.15.49-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.52 running: yes
Device-1: Intel Ethernet I218-LM driver: N/A modules: e1000e port: f080
bus-ID: 00:19.0 chip-ID: 8086:155a class-ID: 0200
Device-2: Intel Wireless 7265 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 8086:095a class-ID: 0280
bus-ID: 1-1.3:3 chip-ID: 8087:0a2a class-ID: e001
Report: rfkill ID: hci0 rfk-id: 3 state: down bt-service: enabled,running
Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
v: 3.0 port: f060 bus-ID: 00:1f.2 chip-ID: 8086:282a rev: N/A class-ID: 0104
Local Storage: total: 465.76 GiB used: 203.47 GiB (43.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST500LM030-2E717D
size: 465.76 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
type: HDD rpm: 5400 serial: <filter> rev: SDM1 scheme: MBR
ID-1: / raw-size: 465.76 GiB size: 457.38 GiB (98.20%)
used: 203.47 GiB (44.5%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: f4c74f99-4d25-41cc-ab23-54fd74606ad3
Hub-1: 1-0:1 info: Full speed or root hub ports: 2 rev: 2.0 speed: 480 Mb/s
Hub-2: 1-1:2 info: Intel Integrated Hub ports: 8 rev: 2.0 speed: 480 Mb/s
chip-ID: 8087:8001 class-ID: 0900
Device-1: 1-1.3:3 info: Intel Bluetooth wireless interface type: Bluetooth
Device-2: 1-1.6:4 info: Microdia Integrated_Webcam_HD type: Video
Device-3: 1-1.7:5 info: Broadcom BCM5880 Secure Applications Processor
with fingerprint swipe sensor
type: Smart Card driver: N/A interfaces: 4 rev: 1.1 speed: 12 Mb/s
power: 100mA chip-ID: 0a5c:5804 class-ID: 0b00 serial: <filter>
Hub-3: 2-0:1 info: Hi-speed hub with single TT ports: 11 rev: 2.0
Device-1: 2-2:2 info: Lite-On USB Optical Mouse type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s
power: 100mA chip-ID: 04ca:0061 class-ID: 0301
Hub-4: 3-0:1 info: Super-speed hub ports: 4 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 48.0 C mobo: 45.0 C sodimm: SODIMM C
Fan Speeds (RPM): cpu: 2480
Processes: 221 Uptime: 24m wakeups: 2 Init: systemd v: 251
default: graphical tool: systemctl Compilers: gcc: 12.1.0 clang: 13.0.1
Packages: 1407 pacman: 1373 lib: 477 flatpak: 12 snap: 22 Shell: Bash
v: 5.1.16 running-in: xfce4-terminal inxi: 3.3.19
