I cannot create accents in words
Hello, I use an English keyboard but I need to write emails in Spanish and I can’t create accents in the words like creating the letter ñ. Can anyone help me? thanks in advance.
Hi @alejoDev
Welcome to the Manjaro forum.
TypeIt might be useful. There is also an app called Gnome Characters which has some potential.
sudo pacman -Syu gnome-characters
I hope this helps. Cheers.
Hi @soundofthunder
Thank you very much for the help but I still can’t get what I’m looking for :S I still can’t accentuate the letters.
Cheers!
This site seems to give adequate instructions: How to type letters with accents on Windows, Mac, and Linux.
Additionally, this Character Map package might be of use. Be prepared to learn how to use it, though.
@soundofthunder:
Wow! I think that with this I will be able to configure it, thank you so much!
Cheers!
For Libreoffice writer select Insert > Special Characters and select Latin-1 character block
For HTML/markdown/scripts etc I usually look-up the ascii codes online
https://www.w3schools.com/charsets/ref_utf_latin1_supplement.asp
For this specific character you could use either:
  • Ñ
  • ñ
  • ñ
I find the entity name easiest to remember for asci symbols I use regularly
e.g. for capital letter - Ñ = Ñ
ç
é
¡Hasta mañana!
