I have installed Manjaro arm Plasma 22.04 twice on my Pinebook Pro, and both times I end up having the same problem. The system can’t boot because it can’t find the root partition. On the other hand, when I boot by inserting the microSD, the system detects the root partition of the emmc and boots without any problem from emmc, not from microSD.
I have done what you propose before. In fact, I have flashed 2 times the new OS on the emmc, and I have been very careful to avoid errors. It’s not a problem with the uboot, at least not a problem derived from having broken the uboot.
I thought a few days ago that the emmc was not correctly fitted in the motherboard, and that could explain this anomaly in the boot. So I removed it, formatted it on a laptop and reinstalled the system after making sure that the emmc was properly attached to the motherboard.
What’s more. I have found that sometimes the system boots correctly from the emmc without inserting the microSD. It is absolutely random. This makes me think that there is something wrong with the software, and I am very much looking forward to the release of an update.
That seems a nasty problem. If I understand correctly, you are flashing the emmc from de microsSD right? Have you tried JumpDrive? This is a little program that you boot from your microSD and it exposes the emmc to a computer that you plug to your Pinephone. Then you can dd an OS onto the emmc.
This is how I have been installing OSs on my Pinephone and it has been working. Maybe you could try it out.
My problem is with a Pinebook Pro, not a Pinephone. I have looked at the website of the software you have indicated and I don’t see that it can also be used with the laptop.
I confirm that I have flashed 2 times the emmc from the microSD, being very careful to choose mmcblk2 from the Manjaro installer.
I understand but without knowing what is happening on the background it is nearly impossible to know how to fix it.
Updated version may or may not solve the unique issue you’re facing.
As no one else have reported this issue.
Lets break down the steps your following with detailed explanation and sharing each command you pass on the device with me on this forum then we can see if there is anything going wrong in here from flashing point of view.
I hope that will help us find the root cause of the problem.
Boot from sdcard and share the output of the following commands
As I have explained before, when I start by inserting the sdcard the Pinebook boots … from the emmc. At the moment I don’t have the tools to physically open the laptop and disable the emmc, as I’m far from home, so I’m sending you the outputs of the commands I have obtained working from the emmc:
lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS
mmcblk2 179:0 0 58,2G 0 disk
├─mmcblk2p1 179:1 0 213,6M 0 part /boot
└─mmcblk2p2 179:2 0 58G 0 part /
mmcblk2boot0 179:32 0 4M 1 disk
mmcblk2boot1 179:64 0 4M 1 disk
mmcblk1 179:96 0 29,8G 0 disk
├─mmcblk1p1 179:97 0 213,6M 0 part
└─mmcblk1p2 179:98 0 29,6G 0 part
zram0 252:0 0 5,7G 0 disk [SWAP]
zram1 252:1 0 4,7G 0 disk [SWAP]
uname -a
Linux pinebookpro 5.17.1-4-MANJARO-ARM #1 SMP PREEMPT Sat Apr 2 20:18:36 UTC 2022 aarch64 GNU/Linux
While I was writing all this, the Pinebook froze completely, and didn’t respond to any input. I had to force a reboot by pressing the start/shutdown key for several seconds. It’s not the first time this has happened since I installed 22.04, although it’s not usual.
Sometimes (also randomly), when I shut down the laptop, a virtual console appears asking me for root permission, but it doesn’t accept any input. I have found that by typing Alt - F3 and then Alt - F1 the laptop continues with its shutdown sequence.
This morning I gathered my courage and reinstalled Manjaro Plasma ARM 22.04 again on the emmc. It was a shame to lose the nice configuration I had achieved, but the goal was worth it. However, this time I did it differently: I didn’t install the system on the sdcard first and then reinstalled it on the emmc. This time, the installation was direct on the emmc, thanks to an emmc-USB device I have at home. Of course, I had to remove the emmc from the motherboard, but I’m used to that.
The result, finally, has been the same: sometimes the system doesn’t boot if I don’t insert the old sdcard, and sometimes it does.
I’m starting to think that maybe I should re-download the .img file with the system, to rule out that the first download I did wasn’t corrupted.
I have installed on a microSD again this same distro, from another PC, using the manjaro-arm-installer application. This has allowed me to install a live version of Manjaro ARM Plasma, different from the one I had already downloaded a few days ago. However, the problem with the boot on the Pinebook Pro continues.
I have come to suspect that the problem is not in the uboot package installed on the eMMC nor on the microSD, but in the SPI flash. For some reason, the PBP starts up and tries to find a system device, without finding it (or it does, it’s random). I have erased the SPI flash card, following the Pine64 forum. I haven’t managed to fix it.
I think it is more likely that the system device is detected once the PBP reaches a certain temperature. For example, when I have managed to boot the OS and spend a few minutes working with it, when I reboot the PBP there is no problem and the system boots normally.
When booting the system, among the messages that appear on the screen there is sometimes one indicating that it has not detected any card with the set voltage of -110V. When this happens, the system usually does not start up.
One more question … Is it normal that there is 30.50 MiB of unallocated space in the eMMC at the beginning? Exactly the same thing happens on the microSD …
