Hi
I right click my hardrive to enable me read and right. I then reboot my system. But unfortunately it won’t login me in with the right password
Please kindly assist
Hi
Hello,
You did what? Changed permissions and ownership of the entire system files?
Backup your files and try this command from runlevel 3 TTY
for i in `pacman -Q | cut -f1 -d " "` ; do pacman -S --noconfirm "$i" ; done
If that doesn’t work then reinstall … and don’t change permissions and ownership of system files ever again.
Thanks
Its solve I reinstalled manjaro
