i am trying to open my display and dont know what video drivers i need
i have a Intel Core2 Duo E7500 @ 2x 2.933GHz processor and have installed manjaro xfce and my gpu is Mesa DRI Intel(R) G33 but the resolution only opens the screen at
1280x768 if i go higher in doesn't stretch it all the way
ok with inxi -Fxxxza --no-host
Kernel: 5.2.21-rt13-MANJARO x86_64 bits: 64 compiler: gcc v: 9.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.2-rt-x86_64
root=UUID=2ec01b02-d263-4eaa-a27d-8b326b129c4e rw quiet apparmor=1
security=apparmor resume=UUID=1b5a8f44-cc61-4f13-b6b6-1c64b1e94986
udev.log_priority=3
Desktop: Xfce 4.14.1 tk: Gtk 3.24.12 info: xfce4-panel wm: xfwm4
dm: LightDM 1.30.0 Distro: Manjaro Linux
Type: Desktop Mobo: Gigabyte model: G31M-ES2L serial: BIOS: Award
v: FF date: 10/13/2009
Topology: Dual Core model: Intel Core2 Duo E7500 bits: 64 type: MCP
arch: Penryn family: 6 model-id: 17 (23) stepping: A (10) microcode: A0B
L2 cache: 3072 KiB
flags: lm nx pae sse sse2 sse3 sse4_1 ssse3 bogomips: 11738
Speed: 1600 MHz min/max: 1600/2933 MHz Core speeds (MHz): 1: 2140 2: 2255
Vulnerabilities: Type: l1tf mitigation: PTE Inversion
Type: mds
status: Vulnerable: Clear CPU buffers attempted, no microcode; SMT disabled
Type: spectre_v2
mitigation: Full generic retpoline, STIBP: disabled, RSB filling
Device-1: Intel 82G33/G31 Express Integrated Graphics vendor: Gigabyte
driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:29c2
Display: x11 server: X.Org 1.20.5 driver: intel unloaded: modesetting
alternate: fbdev,vesa resolution: 1280x768~60Hz
OpenGL: renderer: Mesa DRI Intel G33 v: 1.4 Mesa 19.2.6 direct render: Yes
Device-1: Intel NM10/ICH7 Family High Definition Audio
vendor: Gigabyte GA-D525TUD driver: snd_hda_intel v: kernel
bus ID: 00:1b.0 chip ID: 8086:27d8
Sound Server: ALSA v: k5.2.21-rt13-MANJARO
Device-1: Qualcomm Atheros AR8131 Gigabit Ethernet
vendor: Gigabyte GA-G31M-ES2L driver: atl1c v: 1.0.1.1-NAPI port: bf00
bus ID: 02:00.0 chip ID: 1969:1063
IF: enp2s0 state: up speed: 100 Mbps duplex: full mac:
Local Storage: total: 931.51 GiB used: 755.98 GiB (81.2%)
ID-1: /dev/sda vendor: Western Digital model: WD10EACS-00D6B1
size: 931.51 GiB block size: physical: 512 B logical: 512 B
speed: serial: rev: 1A01 scheme: MBR
ID-1: / raw size: 927.25 GiB size: 911.67 GiB (98.32%)
used: 755.93 GiB (82.9%) fs: ext4 dev: /dev/sda1
ID-2: swap-1 size: 4.26 GiB used: 47.8 MiB (1.1%) fs: swap
swappiness: 1 (default 60) cache pressure: 100 (default) dev: /dev/sda2
System Temperatures: cpu: 32.0 C mobo: N/A
Processes: 153 Uptime: 2h 08m Memory: 1.94 GiB used: 846.0 MiB (42.7%)
Init: systemd v: 242 Compilers: gcc: 9.2.0 Shell: bash v: 5.0.11
running in: xfce4-terminal inxi: 3.0.36
That mainboard has a new bios available
Any particular reason to use that kernel ?
Do you have xf86-video-intel installed ?
no i dont i am using it with the default drivers
i just installed the xf86 video intell and the resolution is at 1600x1024 so uninstalled it plus there where some screen tearing at boot do i have to make a resolution with x randr?with the vesa drivers on the defaulys viideo linux there is a resolution of 1920x10980 the screen just doesn stretch all the way
You could tweak the config file
https://bbs.archlinux.org/viewtopic.php?id=199191
https://wiki.archlinux.org/index.php/intel_graphics#Tearing
Mind you, with the
There might persist the issue you have.
Yes, you can add custom resolutions with xrandr or simply use arandr as is a visual front end for xrandr.
well the thing is with the vesa drivers there is no refresh rate and there is only one resolution for some reason. it said no resolution only default ..... so il stick with video linux drivers so i have to edit the config to open up the screen at 1920x10980?
hi i am trying to edit my xorg.conf file properly in arch to just set the primary display on my hdmi and not my laptop screen i use arandr but it always goes back to default as i am using openbox as a de now i edited the autostart with xrandr --output HDMI1 --mode 1920x1080 but doest work &
xrandr --output HDMI1 --mode 1920x1080 _60 ***
