Hi there! I seem to be having a similar problem as in this thread. I am trying to install 5.15 (79-1 as I write) to no avail. pamac-mirrorlist.timer is active and I had also ran
sudo pacman-mirrors --fasttrack
In case it helps, here is my inxi:
Kernel: 5.10.155-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=20705b87-eec6-4fb3-8353-031c51df1cac ro quiet splash apparmor=1
security=apparmor udev.log_priority=3 nvidia_drm.modeset=1
Desktop: GNOME v: 43.1 tk: GTK v: 3.24.34 wm: gnome-shell dm: GDM v: 43.0
Type: Desktop Mobo: ASUSTeK model: ROG STRIX X570-E GAMING v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 4403
date: 04/27/2022
Device-1: hidpp_battery_0 model: Logitech Wireless Touch Keyboard K400 Plus
status: discharging
RAM: total: 15.6 GiB used: 3.71 GiB (23.8%)
Info: model: AMD Ryzen 9 5900X bits: 64 type: MT MCP arch: Zen 3 gen: 4
level: v3 note: check built: 2021-22 process: TSMC n7 (7nm) family: 0x19 (25)
model-id: 0x21 (33) stepping: 0 microcode: 0xA201016
Topology: cpus: 1x cores: 12 tpc: 2 threads: 24 smt: enabled cache:
L1: 768 KiB desc: d-12x32 KiB; i-12x32 KiB L2: 6 MiB desc: 12x512 KiB
L3: 64 MiB desc: 2x32 MiB
Speed (MHz): avg: 2947 high: 3950
min/max: 2200/6442:6146:5994:5846:6294:4950:5698:5102:5398:5250:5550
boost: enabled scaling: driver: acpi-cpufreq governor: schedutil cores:
1: 2284 2: 2563 3: 2870 4: 2873 5: 2868 6: 2874 7: 2861 8: 3593 9: 2868
10: 2866 11: 2872 12: 2867 13: 3588 14: 2869 15: 2872 16: 2873 17: 2873
18: 2868 19: 2869 20: 3950 21: 2874 22: 3703 23: 2768 24: 2364
bogomips: 177322
cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms extapic
extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt
pse pse36 rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
svm svm_lock syscall tce topoext tsc tsc_scale umip v_vmsave_vmload vaes
vgif vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt x2apic xgetbv1 xsave
xsavec xsaveerptr xsaveopt xsaves
prctl and seccomp
STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: Nanjing Magewell Eco Capture Dual HDMI M.2 vendor: SafeNet
driver: Eco Capture v: N/A alternate: MWEcoCapture pcie: gen: 2 speed: 5 GT/s
lanes: 4 bus-ID: 04:00.0 chip-ID: 1cd7:0051 class-ID: 0400
Device-2: NVIDIA TU116 [GeForce GTX 1660 Ti] vendor: Micro-Star MSI
driver: nvidia v: 520.56.06 alternate: nouveau,nvidia_drm non-free: 520.xx+
status: current (as of 2022-10) arch: Turing code: TUxxx process: TSMC 12nm
built: 2018-22 pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3
speed: 8 GT/s ports: active: none off: DP-1,DP-2,DP-3 empty: HDMI-A-1
bus-ID: 0b:00.0 chip-ID: 10de:2182 class-ID: 0300
Display: x11 server: X.Org v: 21.1.4 with: Xwayland v: 22.1.5
compositor: gnome-shell driver: X: loaded: nvidia gpu: nvidia,nvidia-nvswitch
display-ID: :1 screens: 1
Screen-1: 0 s-res: 5440x1080 s-dpi: 96 s-size: 1439x286mm (56.65x11.26")
s-diag: 1467mm (57.76")
Monitor-1: DP-1 mapped: DP-0 note: disabled pos: right model: Dell P2418HT
serial: <filter> built: 2019 res: 1920x1080 hz: 60 dpi: 93 gamma: 1.2
size: 527x296mm (20.75x11.65") diag: 604mm (23.8") ratio: 16:9 modes:
max: 1920x1080 min: 640x480
Monitor-2: DP-2 note: disabled pos: center model: HS133PC built: 2020
res: 1920x1080 hz: 60 dpi: 166 gamma: 1.2 size: 294x166mm (11.57x6.54")
diag: 338mm (13.3") ratio: 3:2, 4:3 modes: max: 1920x1080 min: 640x480
Monitor-3: DP-3 mapped: DP-4 note: disabled pos: primary,left
model: HP E202 serial: <filter> built: 2020 res: 1600x900 hz: 60 dpi: 92
gamma: 1.2 size: 443x249mm (17.44x9.8") diag: 508mm (20") ratio: 16:9
modes: max: 1600x900 min: 640x480
API: OpenGL Message: Unable to show GL data. Required tool glxinfo missing.
driver: Eco Capture bus-ID: 7-3:3 alternate: MWEcoCapture pcie:
chip-ID: 0951:16ed class-ID: 0300 gen: 2 speed: 5 GT/s serial: <filter>
Device-2: NVIDIA TU116 High Definition Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 16
link-max: gen: 3 speed: 8 GT/s bus-ID: 0b:00.1 chip-ID: 10de:1aeb
class-ID: 0403
Device-3: AMD Starship/Matisse HD Audio vendor: ASUSTeK
bus-ID: 0d:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-4: Kingston HyperX Cloud Alpha S type: USB
driver: hid-generic,snd-usb-audio,usbhid
Sound API: ALSA v: k5.10.155-1-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.60 running: no
Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 05:00.0 chip-ID: 8086:2723 class-ID: 0280
IF: wlp5s0 state: up mac: <filter>
Device-2: Realtek RTL8125 2.5GbE vendor: ASUSTeK driver: r8169 v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: e000 bus-ID: 06:00.0
IF: enp6s0 state: down mac: <filter>
Device-3: Intel I211 Gigabit Network vendor: ASUSTeK driver: igb v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 07:00.0
IF: enp7s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
IF-ID-1: br-ac907f97584b state: down mac: <filter>
Message: Output throttled. IPs: 1; Limit: 10; Override: --limit [1-x;-1
all]
IF-ID-2: docker0 state: up speed: 10000 Mbps duplex: unknown mac: <filter>
Message: Output throttled. IPs: 2; Limit: 10; Override: --limit [1-x;-1
all]
IF-ID-3: vetha3f7226 state: up speed: 10000 Mbps duplex: full mac: <filter>
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-6:3
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
Local Storage: total: 465.76 GiB used: 345.1 GiB (74.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Corsair model: Force MP600
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 type: SSD serial: <filter> rev: EGFM13.0 temp: 41.9 C scheme: GPT
ID-1: / raw-size: 465.46 GiB size: 457.09 GiB (98.20%)
used: 345.1 GiB (75.5%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: 20705b87-eec6-4fb3-8353-031c51df1cac
used: 312 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: 6206-C799
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 6 rev: 2.0
Hub-2: 1-5:2 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
power: 100mA chip-ID: 05e3:0610 class-ID: 0900
Device-1: 1-6:3 info: Intel AX200 Bluetooth type: Bluetooth driver: btusb
class-ID: e001
Hub-3: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-4: 3-0:1 info: Hi-speed hub with single TT ports: 6 rev: 2.0
Device-1: 3-4:2 info: ASUSTek AURA LED Controller type: HID
driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 16mA
chip-ID: 0b05:18f3 class-ID: 0300 serial: <filter>
Hub-5: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-6: 5-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
Hub-7: 6-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-8: 7-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 7-1:2 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID
power: 98mA chip-ID: 046d:c52b class-ID: 0300
Device-2: 7-3:3 info: Kingston HyperX Cloud Alpha S type: Audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 6 rev: 2.0
speed: 12 Mb/s power: 100mA chip-ID: 0951:16ed class-ID: 0300
serial: <filter>
Hub-9: 7-4:4 info: Microchip (formerly SMSC) USB2734 ports: 5 rev: 2.1
speed: 480 Mb/s chip-ID: 0424:2734 class-ID: 0900
Hub-10: 7-4.2:5 info: Microchip (formerly SMSC) Hub ports: 2 rev: 2.0
speed: 480 Mb/s power: 2mA chip-ID: 0424:2412 class-ID: 0900
Device-1: 7-4.2.1:10 info: Melfas LGD AIT Touch Controller type: HID
driver: hid-generic,hid-multitouch,usbhid interfaces: 2 rev: 2.0
speed: 12 Mb/s power: 100mA chip-ID: 1fd2:6103 class-ID: 0300
Device-2: 7-4.3:6 info: Apple Magic Trackpad 2 type: HID,Mouse
driver: magicmouse,usbhid interfaces: 4 rev: 2.0 speed: 12 Mb/s power: 500mA
chip-ID: 05ac:0265 class-ID: 0300 serial: <filter>
Device-3: 7-4.5:8 info: Microchip (formerly SMSC) Hub Controller type: HID
driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 480 Mb/s
chip-ID: 0424:274c class-ID: 0300
Hub-11: 8-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-12: 8-4:2 info: Microchip (formerly SMSC) USB5734 ports: 4 rev: 3.1
speed: 5 Gb/s chip-ID: 0424:5734 class-ID: 0900
System Temperatures: cpu: 48.1 C mobo: N/A gpu: nvidia temp: 36 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 41%
Processes: 474 Uptime: 6m wakeups: 2 Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: 1699 pm: dpkg
pkgs: 0 pm: pacman pkgs: 1687 libs: 429 tools: gnome-software,pacaur,pamac
pm: flatpak pkgs: 5 pm: snap pkgs: 7 Shell: Zsh v: 5.9
running-in: gnome-terminal inxi: 3.3.23
Thanks for your help!
Alan
