Hello everyone!
Recently, my power went out while my computer was on and now, every few minutes or so, my screen freezes for like 5-7 seconds but I can still move my cursor. My power has went out before while my computer was running but this never happened.
Here’s my inxi
output:
Kernel: 6.0.13-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-6.0-x86_64
root=UUID=0ab25861-596e-437d-9297-a220ecf4c5da rw quiet apparmor=1
Desktop: KDE Plasma v: 5.26.4 tk: Qt v: 5.15.7 wm: kwin_x11 vt: 1 dm: SDDM
Mobo: ASUSTeK model: ROG CROSSHAIR VIII FORMULA v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 4201
date: 04/26/2022
Device-1: apple_mfi_fastcharge model: N/A serial: N/A charge: N/A status: N/A
RAM: total: 31.26 GiB used: 7.01 GiB (22.4%)
Info: model: AMD Ryzen 7 3700X bits: 64 type: MT MCP arch: Zen 2 gen: 3
level: v3 note: check built: 2020-22 process: TSMC n7 (7nm) family: 0x17 (23)
model-id: 0x71 (113) stepping: 0 microcode: 0x8701021
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 32 MiB
desc: 2x16 MiB
Speed (MHz): avg: 4126 high: 4275 min/max: 2200/4426 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 4272 2: 3819
3: 4274 4: 4274 5: 4225 6: 3664 7: 4264 8: 4274 9: 4272 10: 3886 11: 4270
12: 4275 13: 4274 14: 3458 15: 4265 16: 4255 bogomips: 115238
f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs
pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
rdtscp rep_good sep sev sev_es sha_ni skinit smap smca smep ssbd sse sse2
sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext
tsc tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme vmmcall
wbnoinvd wdt x2apic xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
Type: retbleed mitigation: untrained return thunk; SMT enabled with STIBP
protection
Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: NVIDIA TU104 [GeForce RTX 2070 SUPER] vendor: ASUSTeK
driver: nvidia v: 525.60.11 alternate: nouveau,nvidia_drm non-free: 525.xx+
status: current (as of 2022-12) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-22 pcie: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 0a:00.0 chip-ID: 10de:1e84 class-ID: 0300
Device-2: Logitech C920 HD Pro Webcam type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 7-1:2 chip-ID: 046d:0892
class-ID: 0102 serial: <filter>
Display: x11 server: X.Org v: 21.1.5 compositor: kwin_x11 driver: N/A
display-ID: :0 screens: 1
Screen-1: 0 s-res: 3440x1440 s-dpi: 109 s-size: 802x342mm (31.57x13.46")
s-diag: 872mm (34.33")
Monitor-1: DP-0 res: 3440x1440 hz: 60 dpi: 109
size: 800x335mm (31.5x13.19") diag: 867mm (34.15") modes: N/A
API: OpenGL v: 4.6.0 NVIDIA 525.60.11 renderer: NVIDIA GeForce RTX 2070
SUPER/PCIe/SSE2 direct render: Yes
Device-1: NVIDIA TU104 HD Audio vendor: ASUSTeK driver: snd_hda_intel
bus-ID: 7-1:2 v: kernel chip-ID: 046d:0892 pcie: gen: 3 class-ID: 0102
serial: <filter> speed: 8 GT/s lanes: 16 bus-ID: 0a:00.1 chip-ID: 10de:10f8
class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: ASUSTeK
bus-ID: 0c:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Logitech C920 HD Pro Webcam type: USB
Sound API: ALSA v: k6.0.13-1-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.63 running: yes
Device-1: Aquantia AQC111 NBase-T/IEEE 802.3bz Ethernet [AQtion]
vendor: ASUSTeK driver: atlantic v: kernel pcie: gen: 3 speed: 8 GT/s
lanes: 1 link-max: lanes: 4 port: N/A bus-ID: 04:00.0 chip-ID: 1d6a:11b1
class-ID: 0200
IF: enp4s0 state: down mac: <filter>
Device-2: Intel I211 Gigabit Network vendor: ASUSTeK driver: igb v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 05:00.0
IF: enp5s0 state: down mac: <filter>
Device-3: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 06:00.0 chip-ID: 8086:2723 class-ID: 0280
IF: wlp6s0 state: up mac: <filter>
IF-ID-1: enp7s0f3u1c4i2 state: down mac: <filter>
IF-ID-2: virbr0 state: down mac: <filter>
Message: Output throttled. IPs: 1; Limit: 10; Override: --limit [1-x;-1
all]
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-6:4
Local Storage: total: 1.2 TiB used: 392.01 GiB (31.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 970 EVO 1TB
lanes: 4 type: SSD serial: <filter> rev: 2B2QEXE7 temp: 29.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST3160318AS
size: 149.01 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
type: HDD rpm: 7200 serial: <filter> rev: CC45 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Intel model: SSDSA2BW160G3L
size: 149.05 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
type: SSD serial: <filter> rev: LE04 scheme: GPT
ID-1: / raw-size: 931.22 GiB size: 915.53 GiB (98.32%)
used: 391.97 GiB (42.8%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: 0ab25861-596e-437d-9297-a220ecf4c5da
used: 34.6 MiB (11.6%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: NO_LABEL uuid: C6BD-8959
ID-1: /dev/sdb1 maj-min: 8:17 size: 16 MiB fs: ext4 label: N/A
uuid: d5998f36-9778-47b0-a94f-e88eca07a6ba
ID-2: /dev/sdb2 maj-min: 8:18 size: 149.03 GiB fs: ntfs label: N/A
uuid: E4429A5D429A3470
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 6 rev: 2.0
Device-1: 1-1:2 info: ThrustMaster T.A320 Pilot type: HID
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 100mA
chip-ID: 044f:0405 class-ID: 0300 serial: <filter>
Hub-2: 1-5:3 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
power: 100mA chip-ID: 05e3:0610 class-ID: 0900
Device-1: 1-5.3:5 info: ASUSTek AURA LED Controller type: HID
driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 16mA
chip-ID: 0b05:18f3 class-ID: 0300 serial: <filter>
Device-2: 1-5.4:6 info: ASUSTek AURA LED Controller type: HID
chip-ID: 0b05:1872 class-ID: 0300 serial: <filter>
Device-3: 1-6:4 info: Intel AX200 Bluetooth type: Bluetooth driver: btusb
class-ID: e001
Hub-3: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-4: 3-0:1 info: Hi-speed hub with single TT ports: 6 rev: 2.0
Device-1: 3-1:5 info: Apple iPhone 5/5C/5S/6/SE type: Still Imaging
driver: ipheth interfaces: 3 rev: 2.0 speed: 480 Mb/s power: 500mA
chip-ID: 05ac:12a8 class-ID: 0601 serial: <filter>
Hub-5: 3-2:2 info: ASMedia ASM1074 High-Speed hub ports: 4 rev: 2.1
speed: 480 Mb/s power: 100mA chip-ID: 174c:2074 class-ID: 0900
Device-1: 3-2.3:4 info: HP HP LaserJet P2035 type: Printer driver: usblp
interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 98mA chip-ID: 03f0:5d17
class-ID: 0701 serial: <filter>
Hub-6: 3-3:3 info: ASMedia ASM1074 High-Speed hub ports: 4 rev: 2.1
Hub-7: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-8: 4-2:2 info: ASMedia ASM1074 SuperSpeed hub ports: 4 rev: 3.0
speed: 5 Gb/s power: 8mA chip-ID: 174c:3074 class-ID: 0900
Hub-9: 4-3:3 info: ASMedia ASM1074 SuperSpeed hub ports: 4 rev: 3.0
Hub-10: 5-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
Hub-11: 6-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-12: 7-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 7-1:2 info: Logitech C920 HD Pro Webcam type: Video,Audio
power: 500mA chip-ID: 046d:0892 class-ID: 0102 serial: <filter>
Device-2: 7-3:3 info: Logitech G502 SE HERO Gaming Mouse type: Mouse,HID
driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 300mA
chip-ID: 046d:c08b class-ID: 0300 serial: <filter>
Device-3: 7-4:4 info: Holtek USB Gaming Keyboard type: Keyboard,HID
driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s power: 100mA
chip-ID: 04d9:a0f8 class-ID: 0300
Hub-13: 8-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 40.0 C mobo: 24.0 C gpu: nvidia temp: 26 C
Fan Speeds (RPM): cpu: 640 fan-1: 717 fan-2: 551 fan-3: 1088 fan-4: 769
fan-5: 0 fan-6: 0 fan-7: 0 gpu: nvidia fan: 24%
Processes: 416 Uptime: 2h 43m wakeups: 3 Init: systemd v: 252
default: graphical tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6
Packages: 1852 pm: pacman pkgs: 1840 libs: 460 tools: pamac pm: flatpak
pkgs: 0 pm: snap pkgs: 12 Shell: Zsh v: 5.9 default: Bash v: 5.1.16
running-in: konsole inxi: 3.3.24
Please let me know if there’s any other information I can provide!
Thanks!
