I recently installed Manjaro to my PC, earlier I was using Windows 8.1 and at the time of installation made a new partition to install manjaro but after I installed it the file manager is not showing my previous partitions and I have very important files on it. Can I bring them back? If yes, then how?
I have searched the internet regarding the same but I can’t solve my issue.
Please help!
I am attaching screenshots of GParted here.
SCREENSHOTS = imgur. com/a/SjRQlb1
(Remove space between . and com )
It is an impossible question - and data rescue is serious business.
If you get advise from a forum user and it does not work - but unintentionally makes it worse - who will you blame.
Search for data recovery or recover lost partition using your favorite search engine.
First of all - STOP using the device - you are potentially making it much worse to recover data.
To avoid advise which may or may not help you I am closing this topic - as it is a disaster waiting to break loose.
