I just installed Manjaro, yet i am unable to connect to my wifi. It gets repeatedly disconnected.
"System:
Kernel: 5.15.6-2-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=43c122fd-ac37-4365-8533-e2df17cb5011 rw quiet apparmor=1
security=apparmor resume=UUID=cfa3c35e-4889-41e7-9699-1e50c98526d2
udev.log_priority=3
Desktop: KDE Plasma 5.23.4 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop System: Gigabyte product: H110M-H v: N/A
serial: <superuser required>
Mobo: Gigabyte model: H110M-H-CF serial: <superuser required>
UEFI-[Legacy]: American Megatrends v: C4 date: 12/03/2018
Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard
Use of uninitialized value $val2 in string eq at /usr/bin/inxi line 6943.
Use of uninitialized value $val2 in split at /usr/bin/inxi line 6948.
Use of uninitialized value $val2 in concatenation (.) or string at /usr/bin/inxi line 6950.
Use of uninitialized value $val2 in concatenation (.) or string at /usr/bin/inxi line 6953.
Use of uninitialized value $val2 in concatenation (.) or string at /usr/bin/inxi line 6954.
serial: <filter> charge: 55% (should be ignored) rechargeable: yes status:
Device-2: hidpp_battery_1 model: Logitech Wireless Mouse serial: <filter>
Info: model: Intel Core i3-6100 bits: 64 type: MT MCP arch: Skylake-S
family: 6 model-id: 0x5E (94) stepping: 3 microcode: 0xEA
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 800 min/max: 800/3700 scaling: driver: intel_pstate
governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 bogomips: 29608
Type: l1tf
Device-1: Intel HD Graphics 530 vendor: Gigabyte driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:1912 class-ID: 0300
Device-2: WCM_USB WEB CAM type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 1-4:3 chip-ID: 1c3f:2002 class-ID: 0102
Display: x11 server: X.org 1.21.1.1 compositor: kwin_x11 driver:
loaded: modesetting alternate: fbdev,vesa resolution: <missing: xdpyinfo>
Device-1: Intel 100 Series/C230 Series Family HD Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a170
class-ID: 0403
Sound Server-1: ALSA v: k5.15.6-2-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.40 running: yes
vendor: Gigabyte driver: r8169 v: kernel port: e000 bus-ID: 01:00.0
IF: enp1s0 state: down mac: <filter>
Device-2: D-Link DWA-131 Wireless N Nano Adapter (Rev. E1) [Realtek
RTL8192EU]
type: USB driver: rtl8xxxu bus-ID: 1-8:5 chip-ID: 2001:3319 class-ID: 0000
serial: <filter>
IF: wlp0s20f0u8 state: down mac: <filter>
IF-ID-1: bnep0 state: unknown speed: N/A duplex: N/A mac: <filter>
driver: btusb v: 0.8 bus-ID: 1-5:4 chip-ID: 0a12:0001 class-ID: e001
Local Storage: total: 931.51 GiB used: 8.6 GiB (0.9%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000DM010-2EP102
size: 931.51 GiB block-size: physical: 4096 B logical: 512 B
speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter> rev: CC43
scheme: MBR
ID-1: / raw-size: 922.71 GiB size: 907.15 GiB (98.31%) used: 8.6 GiB (0.9%)
fs: ext4 dev: /dev/sda1 maj-min: 8:1
ID-1: swap-1 type: partition size: 8.8 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sda2 maj-min: 8:2
System Temperatures: cpu: 29.8 C mobo: 27.8 C
Processes: 204 Uptime: 57m wakeups: 20 Memory: 7.65 GiB
used: 1.93 GiB (25.2%) Init: systemd v: 249 tool: systemctl Compilers:
gcc: N/A Packages: pacman: 1196 lib: 330 flatpak: 0 Shell: Zsh v: 5.8
default: Bash v: 5.1.12 running-in: konsole inxi: 3.3.10"
From terminal
sudo rfkill list
If you get something like
Soft blocked: yes
Hard blocked: yes
then run
rfkill unblock wifi
https://wiki.archlinux.org/title/Network_configuration/Wireless
