I have recently made a move from Linux Mint to Manjaro Gnome and wanted to run this app. The latest version as of today is available in AUR but does not load any channels. I have installed EndeavourOS in Gnome Boxes and can see that its working fine in XFCE environment. Has anyone encountered this issue and can anyone please give a pointer to figure me out the issue here?
Manjaro provides the hypnotix package from the repos. Is true that on stable branch is still 1.3 version and only in testing and unstable there is the 1.4 version, but is quite possible the package from AUR has dependencies of packages versions that are still not in stable branch.
My suggestion is to remove the one you installed from AUR and install the one from repos and try again. pamac install hypnotix
You could switch branches and update the system then use the latest version.
I’m running the hypnotix git version from the aur on manjaro-cinnamon, been running it for a few months with zero issues. Jonathan is the maintainer of the git version and he’s active on the Endeavour forums
According to your profile you are on testing branch, hence most likely in line with dependencies versions. Either way, the OP seems to not be able to have any streaming displaying …
I’ve been using it since it was first ported from mint in the aur ,but did have issues with the first release not showing channels. Second release has pretty much worked perfectly since release. Got to be honest I’ve not tried the version from official repos ,just too lazy to switch from the aur version
Just did that and it has installed the following packages:
To install (3):
python-sqlalchemy 1.3.20-3 (Required By: hypnotix) community
python-imdbpy 2020.9.25-3 (Required By: hypnotix) community
hypnotix 1.3-1 community
I am never able to run a single channel (can run in VLC or another arch based VM)
ree-IPTV: Getting playlist…
Free-IPTV: Checking playlist…
Free-IPTV: Loading channels…
All chanels: Getting playlist…
All chanels: Checking playlist…
All chanels: Loading channels…
File “/usr/lib/hypnotix/hypnotix.py”, line 1018, in on_mpv_drawing_area_realize
self.reinit_mpv()
File “/usr/lib/hypnotix/hypnotix.py”, line 1039, in reinit_mpv
input_vo_keyboard=True,osc=True, ytdl=True, wid=str(self.mpv_drawing_area.get_window().get_xid()))
AttributeError: ‘GdkWaylandWindow’ object has no attribute ‘get_xid’
CHANNEL: ‘Blomberg US’ (us_live.m3u8)
Exception in thread Thread-3:
File “/usr/lib/python3.9/threading.py”, line 954, in _bootstrap_inner
self.run()
File “/usr/lib/python3.9/threading.py”, line 892, in run
self._target(*self._args, **self._kwargs)
File “/usr/lib/hypnotix/hypnotix.py”, line 591, in play_async
self.reinit_mpv()
